Best-value Cloud Controlled Wi-Fi Router
GL-SF1200, the best-value gigabit wireless router combined with security features protecting your internet privacy. It comes with dual-band Wi-Fi and four external high-gain antennas, perfect for families and businesses looking for powerful Wi-Fi but cost effective network security options.
4 x Gigabit Ports
Excellent Security with VPN & IPv6
Hot-rod Your Home Network
with Multi-Gigabit Ports Router
Support Cloud-Management Platform for Remote Access
Get Stronger Wi-Fi Signals with External Antennas
Connects up to 50+ devices
Secure Your Home Network
GL-SF1200 provides the best encryption and authentication with OpenVPN & WireGuard®, just like the other GL.iNet products. Keeping your Internet connection private with multiple VPN protocol support.
With our Web UI 3.0, you can set up a VPN server easily and access your files securely in a remote site as if you are at home.
WireGuardOpenVPN
* OpenVPN speeds will be slower when running the device as a server. Results above are in client mode.
Speedy But Secure
Comes with 4 gigabit Ethernet ports
With 4 external Wi-Fi antennas
Everyday Life Just Got Easier
Perfect for families and businesses
Dual-band
Wi-Fi
VPN Client /
Server
IPv6
OpenWrt
Pre-installed
Gigabit
Ethernet
Multi-User
MIMO
Specification
| Interface |
1 x WAN Ethernet port 3 x LAN Ethernet ports 1 x Reset button 1 x Power port |
| CPU | SF19A2890, Dual-Core @1GHz |
| Memory / Storage | DDR2 128MB / NOR Flash 16MB |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 300Mbps (2.4GHz), 867Mbps (5GHz) |
| Ethernet Speed | 10/100/1000Mbps |
| Antennas | 4 x External omnidirectional antennas |
| LEDs | 7 x LED, white (Power/WAN/LAN 1~3/2.4G/5G) |
| Power Input | DC 12V/1A |
| Operating Temperature | 0 ~ 40°C (32 ~ 104°F) |
| Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) |
| Dimension / Weight | 210 x 145 x 28mm / 285g | Tools & Downloadables | Firmware | App | Set up video | Tutorials |
