Collie (GL-X300B) Industrial 4G Gateway | RS485 | EG25-G Global Version
$125.99
Original price $125.99 - Original price $125.99
$125.99
Current price $125.99
Collie / GL-X300B
GL-X300B-BLE / GL-X300B-GPS / GL-X300B-RS485
Meet Collie
4G LTE Industrial Wireless IoT Gateway
4G LTE Industrial Wireless Gateway
Collie (GL-X300B) is an industrial cellular gateway designed to operate under high temperatures and scenarios with potential physical hazards. There are two versions of Collie, designed to operate in indoor stationary facilities, or in transportation vehicles. Collie is perfect for machine-to-machine communications between electrical devices in high electrical noise environments.
Built-in 4G Module
Built for Stationary IoT or Vehicle Location Tracking
Built-in Hardware Watchdog
Learn More View Online Guide
Model Comparison
GL-X300B-RS485
GL-X300B-BLE*
GL-X300B-GPS*
CPU QCA9531, @650MHz SoC QCA9531, @650MHz SoC QCA9531, @650MHz SoC
Memory / Storage DDR2 128MB / NOR Flash 16MB DDR2 128MB / NOR Flash 16MB DDR2 128MB / NOR Flash 16MB
2.4G Wi-Fi 300Mbps 150Mbps 300Mbps
Wi-Fi Antennas (2.4GHz) 2 1 2
4G LTE Antennas 1 1 2
BLE Antennas 1
GPS Antennas 1
4G Module CAT 4 CAT 4 CAT 4
Ethernet Ports 2 x 10/100Mbps 2 x 10/100Mbps 2 x 10/100Mbps
SIM Card Slot
Hardware Watchdog
*The BLE and GPS versions are available with a minimum order quantity
Powerful Antennas For Maintaining Stable Networks
GL-X300B-GPS is equipped with five external antennas, including two 2.4GHz Wi-Fi, two 4G LTE, and one GPS Antenna. The extendable wired antennas are perfect for having multiple reception placements within a vehicle, minimizing reception black spots when traveling through high network density cities.
GL-X300B-BLE is equipped with three external omnidirectional antennas for 2.4GHz Wi-Fi, 4G LTE, and BLE communication, receiving signals from all directions, and providing high flexibility in installation placement within an industrial environment.
GL-X300B-RS485 includes an RS485 chip with RS485 interface. The module supports bi-directional data transmission of various devices in the field of industrial automation and IoT, thus realizing the functions of data acquisition, control and monitoring.
For Wall Mounted Applications
Collie's mounting platform has screw slots for wall mounting in an industrial environment, conveniently deploy the device in a safe position with minimal physical interference for reliable wireless connection.
For DIN Rail Mounted Applications
Collie's mounting platform is conveniently designed to fit in a DIN rail along with other electrical equipment, simplifying the deployment of an organized wiring design within an electrical enclosure or in other industrial environments.
Collie (GL-X300B) is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. When a VPN connection is configured and active, traffic routed through the router's VPN tunnel is encrypted, including traffic from connected guest or client devices that are not capable of running a VPN themselves. Collie (GL-X300B) can also act as a VPN server, redirecting traffic from client devices in remote locations to the VPN server via a VPN tunnel before accessing the public internet.
WireGuard
Max. 38Mbps
OpenVPN
Max. 10Mbps
30+ Commercial VPN services provider
Remote Access and Management
Collie comes with GL.iNet's GoodCloud remote device & networks management platform, providing users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates, enabling users to manage devices efficiently.
Experience seamless connectivity with the Collie, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
Robust VPN Gateway for Remote Access
Industrial Grade LTE Module
A Comprehensive Range of Connectivity Hardware and Software
Expand your service portfolio and widen your solution coverage by using Collie (GL-X300B) in your business operations. Our proven success in design and manufacturing multi-purpose routers & IoT gateways as well as delivering customized software solutions will be a seamless integration to your service portfolio.
Pre-Design - Application Scenario and Goals
Design Specifications
Solution Prototype and Testing
Mass Production or Scalable Integration
Vehicles Location Tracking Using GL-X300B-GPS
GL-X300B-GPS includes a location tracking feature with an external GPS antenna. The module provides location data accessible on GoodCloud, and customisable to develop long-range asset tracking applications such as viewing public transport movement.
RV
Providing stable cellular networks to RV vehicles travelling in remote locations with minimal network infrastructure, and providing real-time location data.
Public Transport
Offering reliable cellular services and providing real-time vehicle location data at minimal interference on public transportation in high network density city environments.
Logistics Monitoring
Collecting and uploading data from vehicle charging stations to the cloud, and providing real-time status updates using third party applications.
Emergency Service Vehicles
Syncing data from on-board service equipment to cloud servers for hastened response and tracking vehicle location in real time.
IoT Machine-to-Machine Communication Using GL-X300B-BLE
GL-X300B-BLE includes a BLE module with an external BLE Antenna. The module supports heavy-duty IoT machine-to-machine network communication for a wide range of IoT devices and applications, including equipment management, HVAC configuration, and large-scale logistical management scenarios.
Warehouse Logistics
Regulates indoor assets by tracking its storage location, indoor movement, and making real time adjustments to HVAC sensors and regulators.
Manufacturing
Establishing machine-to-machine communications and making real-time micro-adjustments to equipment according to sensor data.
Vehicle Charging Stations
Clinics and Hospitals
Tracking device data from medical sensors and equipment, remote monitoring patient vitals and receiving emergency notifications.
VPN Client/Server
VPN Client /
Server
4G LTE Module
4G LTE
Module
Hardware Watchdog
Hardware
Watchdog
BLE
BLE1
GPS
GPS2
1Only applicable for GL-X300B-BLE| 2Only applicable for GL-X300B-GPS
Specifications
Interface 1 x WAN Ethernet Port
1 x LAN Ethernet Port
1 X Standard SIM Card Slot
1 x Power Port
1 x Reset Button
Memory / Storage DDR2 128MB + NOR Flash 16MB
External Antennas GL-X300B-BLE: 1 x 2.4G Antenna, 1 x 4G LTE Antenna, 1 x BLE Antenna
GL-X300B-GPS: 2 x 2.4G Antennas, 2 x 4G LTE Antennas, 1 x GPS Antenna
GL-X300B-RS485: 2 x 2.4G Antennas, 1 x 4G LTE Antennas
Wi-Fi Protocol IEEE 802.11b/g/n
Wi-Fi Speed GL-X300B-BLE: 150Mbps (2.4GHz) / GL-X300B-GPS: 300Mbps (2.4GHz) / GL-X300B-RS485: 300Mbps (2.4GHz)
Ethernet Speed 10/100Mbps
LEDs Power, Wi-Fi, 4G and WAN
Power Supply DC5521, 12V/1A (5.5*2.1mm) [default adapter] / 9~36V
Power Consumption <4W
Operating Temperature -20 ~ 55°C (-4 ~ 131°F)
Storage Temperature -30 ~ 70°C (-22 ~ 158°F)
Dimension / Weight 104 x 113 x 28mm / 235g
Tools & Downloadables Datasheet | Firmware | App | Tutorials | Media Kit
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 4.857143 / 5 from 14 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["quality","service","connection","works","issues","firmware","device","piece of kit"].
Review highlights
Reviews
a well hidden gem with manageable flaws
"Better than you would assume. I love the concept and the design all in all and finally it's full aluminum and is chill while I'm non stop usage as well so not overheating as the hermetically sealed plastic Mudi. The firmware, security patches is the weak point as you cannot flash vanilla Openwrt or you lose features like esim or so and they don't maintain and release up to date patched stable firmwares but only betas over a year and for swim support you must downgrade to a special non public older beta."
— Eastvan (5/5)
Excellent
"It took a lot of patience and experimenting, but when everything worked, it was just great."
— Kris B. (5/5)
Excellent Router for remote access and field service
"Well priced, easy to set up. ZEROTIER is a BIG PLUS Would like this to be a 5 G Router asap"
— Peter F. (5/5)
— Sami H. (5/5)
Quality products and quality support.
"I wanted to take the time and share how good GL-inet customer service is. I had an issue with a unit, after a brief troubleshooting, Daisy Yuan shipped a replacement with no issues, kept me in the loop during the whole shipping process and followed up after it was delivered, it is hard to find such service. Thank you for a great product and fantastic post sales service."
— Patrick (5/5)
Works well. The SIM card
"Works well. The SIM card slot is really fiddly, I originally intended to use a nanoSIM with an adapter, but I had no luck at all. The full sized SIM just about fits. Everything else works well and the product feels solid. Not lightning speed, but a reliable connection."
— Jake H. (4/5)
Remote location for IOT
"Seems to work great. Good price! Easy setup and does not consume random data as one would expect from openwrt."
— Martin V. (5/5)
Good Product, But. . .
"The product arrived fine, and is as expected. It will serve its purpose nicely. The only real issue I have is not with the company, but with the local shipping company they use. Aramex (formally NZ Couriers), are one of the slowest and least reputable in the country. I would recommend looking to use an alternative such as Courierpost. I'd also suggest doing signature on delivery, as sometimes they tend to dump a package and run. Otherwise, a good experience. Thank you."
— Nick T. (4/5)
Worthwhile purchase
"Solid build quality, fast transmission, updatable firmware with good customization option, and the three powerful antennas. This product exceeded my expectations and is doing the job superbly for what it was intended for. Thank you for making a great product!"
— Sandy L. (5/5)
Nice system, nice quality, reliable
"Nice system overall, very reliable and fast, also great build quality and software/hardware stability"
— David F. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
