Brume 2 (GL-MT2500/MT2500A) VPN Security Gateway | ABS Plastic | Aluminium Alloy
$77.99
Original price $0.00 - Original price $0.00
$77.99 - $89.99
Current price $77.99
GL-MT2500 / GL-MT2500A
MEET Brume 2
Security Gateway for Remote Access
Powerful VPN Gateway for Home Office and Remote Work
Brume 2 (GL-MT2500/GL-MT2500A) is a lightweight and powerful VPN Gateway. It is compactly designed to host a VPN server at home, or run SD-WAN (Site-to-Site) for small and medium-sized enterprises.
Supports VPN Cascading
VPN Speed of 150 Mbps (OpenVPN) & 355 Mbps (WireGuard®)
Ideal for hosting VPN server
Learn More View Online Guide
VPN Cascading on Brume 2
Brume 2 is pre-installed with OpenVPN and WireGuard®, it supports running VPN server and client at the same time within the same device, enabling users to remote access local network resources like Wi-Fi printers or local web servers, and accessing the public internet as a VPN client at the same time.
Fast and Secure Browsing with OpenVPN and WireGuard®
Brume 2 features built-in VPN support, allowing users to choose from 30+ VPN service providers to optimize their network experience. It automatically redirects all network traffic within the connected network to your VPN service or server, including guest devices and client devices that are not capable of running VPN.
WireGuard
Max. 355Mbps
OpenVPN
Max. 150Mbps
30+ Commercial VPN services provider
Host Your Own VPN Server & Client at Home or Office
Brume 2 runs fast VPN speed which allows you to access your home network away from home securely and easily. It is equipped with a USB 3.0 port to provide a significant advancement in data transfer speed and give you the flexibility to upgrade your server storage whenever you want.
Use Brume 2 together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Learn More
Incredibly Lightweight & Stylish design
Brume 2 comes in two versions: a frosted metabolic case and light weight plastic case made of ABS plastic.
Stylish
GL-MT2500A
GL-MT2500A
Aluminium alloy
VS
Best Value
GL-MT2500
GL-MT2500
ABS plastic
Staff working at home can access internal resources and sensitive information stored under a corporate private network via encrypted VPN tunnels.
Build your own VPN server with Brume 2. It provides a cost efficient way to access local files away from home securely and bypass geo-blocking.
Form a virtual office between head office and branch offices effortlessly and all the internal communications are protected by VPN encryption.
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
Visit AdGuard
Brume 2 (GL-MT2500) Reviews
  • Video 0
    The SMALLEST VPN Gateway - GL.iNet Brume2
  • Video 1
    2023! Eigenes VPN gratis für die Reise mit FRITZ!Box oder GL.iNet Brume 2
  • Video 2
    Servidor VPN, AdGuard, TOR e Muito Mais! O Gateway de Segurança! | BRUME 2 (GL.inet GL-MT2500)
  • Video 3
    Neues von GL.iNET Brume 2 & Beryl AX // Man in the Middle Attack
  • Video 4
    Brume 2 WireGuard VPN Setup to connect with @SpaceinvaderOne
VPN Client/Server
VPN Client/
Server
USB 3.0 Port
USB 3.0
Port
Tor Anonymity
Tor Anonymity
AdGuard Home
AdGuard Home
SD-WAN
SD-WAN
Specification
1 x LAN Ethernet port
1 x Reset button
1 x Type-C power port
1 x USB 3.0 port
CPU MediaTek MT7981B Dual-core, @1.3GHz
Memory / Storage DDR4 1GB / EMMC 8GB
Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000 Mbps
Power Input Type-C, 5V/2A
Power Consumption <2.6W
Dimension / Weight GL-MT2500: 70 x 70 x 22 mm / 60g, GL-MT2500A: 70 x 70 x 22 mm / 157g
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 4.954023 / 5 from 87 reviews.
AI Generated Review Summary
The Brume 2 VPN Security Gateway offers seamless setup, compact design, and reliable support, making it ideal for secure remote access and VPN hosting.
Summary topics
  • Setup Ease (16%): Many customers pointed out that the setup of the product was seamless, making it a breeze.
  • Customer Support (13%): Customers raved about the great support provided by the company, which was mentioned multiple times in the reviews.
  • VPN Performance (19%): Many customers loved the iNet Brume 2 for its ease of setup and secure remote access.
Review topics: [delivery, support, setup, issues, connection, performance, service, price, interface, speed, features, use, value, device, vpn, works, router, gateway, box, access, team, server, customization, solution, unit, capabilities, version, configuration, network, brume 2].
Review highlights
  • "Worked perfectly, setup was simple, and the VPN has been working perfectly." — Jason C.
  • "iNet Brume 2 Security Gateway is an excellent lightweight VPN gateway designed for secure remote access." — Shawn
  • "Excellent devices very quick shipping will use again thanks" — Kevin
Reviews
great product, outstanding support!
"The Brume 2 is an excellent product with solid performance, rich features, and outstanding reliability. Its technical capabilities make it a great choice for anyone looking for a powerful and flexible networking/gateway/vpn solution. In addtion,w hat impressed me even more was the support experience: technical support responded quickly and helped when I had an issue efficiently. Customer service was equally outstanding, professional, and genuinely customer-focused. Great product, backed by a company that truly stands behind its customers!"
— Mario (5/5)
Excellent VPN Endpoint
"I have several of these little boxes in use as VPN endpoints in various countries. There are exactly what I need: very small footprint, low power use, very easy to set up, and easily hit the performance (i. e. wireguard throughput) I need. My main use for the Brume 2s are as 'spokes' in my hub-and-spoke network model whereby I have a pfsense router at the centre, and have created wireguard tunnels to several Brume 2s in various countries. Policy based routing on the pfsense router then directs traffic to specific tunnels so I can use geolocated services more easily. As noted, they are very low maintenance. The Glinet software frontend is beginner friendly, but as the Brume 2 runs openwrt it allows me to add more complex configurations. A shout out also to Zoey in Glinet customer service who has been extremely helpful."
— John A. (5/5)
An awesome piece of tech
"I’ve set up my personal VPN server at home and now travel across the globe with my employer thinking I’m home. Convenient, thank you gl-Inet."
— Daniil (5/5)
Amazing!
"Running 24/7, 0 issues, super happy with the product. In case of any issues I highly recommend to get in touch with the support team, mega professionals!"
— Ionut (5/5)
Fantastic experience
"I met with Riley. And oh my god! What a great help it was. She was really knowledgeable, patient and helpful. Honestly, the best customer service experience I have ever received."
— Mehdi J. (5/5)
Very compact
"I love the small compact size. And the aluminum case is very stylish! I attached it directly to the side of my modem using some command strips."
— User32 (5/5)
awesome!
"10/10 i linked my brume 2 to oregon and I am using the mt3000 travel router in new york and its pinging my IP to oregon while connecting in another state. amazing!"
— Zachary R. (5/5)
great vpn gateway
"This product is great. I managed to easily configure/install it. I am using it for 4 months now, and I am very satisfied with the stability, speed, and usage. Remote vpn connection is very stable unlike some VPN service providers offer. Great work!"
— Baki (5/5)
Amazing support
"I needed a VPN solution for remote access on a 4G router that uses GNAT, meaning no public IP. Easy to shop, fast shipping and well instruction for setup the VPN boxes, MT2500. I had VPN running instantly - from client/remote site to main site - but not the other way. I couldnt find the issue, and reached out to support team. The error was on my side, had parallel routers on main site, that generated the issue. I got all the instructions to solve my setup, that had nothing to do with the product - I'm very happy and thankfull as well. TOP CLASS"
— Preben L. (5/5)
Powerful in a small footprint
"Absolutely love my Brume 2, I hesitated a lot in ordering it because I feared that it may struggle with my 24 devices LAN but it is handling it like a champion. In addition to that, during testing, the SMB server performed at the max speed the hdd I used to test with allowed and even recently I had an ISP fiber outage and the Brume 2 saved me from struggling much as I could just connect an old iPhone to it and use that as WAN until the ISP could recover and Brume 2 switch back to the PPPoE my ISP offers."
— Alexandru C. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
