SIMPoYo eSIM Physical Card | Data Only
Sold out
$19.90
$19.90
Current price $19.90
What is SIMPoYo eSIM
Physical Card
SIMPoYo eSIM Physical Card may look like a regular SIM card, but it’s packed with advanced eSIM functionality. Easily switch between up to 8 eSIM profiles without ever swapping cards. Preloaded with 1GB U.S./EU + 100MB Global data, it's ideal for frequent travelers, developers, and privacy-conscious users.
SIMPoYo eSIM
Explore More Features with the SIMPoYo eSIM Physical Card
4G/5G Compatible
No activation required - ready to use instantly
Connect to fast, stable 4G/5G networks worldwide
Multi-Profile Support
Store and manage up to 8 eSIM profiles in one card
Add, delete, or switch profiles with ease
Device Compatibility
GL.iNet routers: Easily manage eSIM profiles through the GL.iNet Admin Panel
Android phones: Unlock eSIM functionality on supported devices using our partner-developed app
Developer-Friendly
Unlimited profile rewrites - no write restrictions or locks
Fully open for integration, testing, and customization
Flexible Recharge
Top up with Global plans
Compatible with third-party eSIM profiles
Privacy-Focused
No personal information
No SIM registration
How Does the eSIM Physical Card Work with GL.iNet Routers?
How to Set Up Your eSIM Physical Cards for the First Time?
How to Set Up the SIMPoYo eSIM Physical Card with GL.iNet Router?
Prefer to read the full guide? Check out our documentation here
How to Set Up the SIMPoYo eSIM Physical Card with Android Devices?
Overall rating: 4.857143 / 5 from 14 reviews.
AI Generated Review Summary
Summary topics
Review topics: [service, support, works, issues, esim, team].
Review highlights
Reviews
Works well but no profile switching on Android
"Works well and I am able to install and switch profiles using a card reader and my Mac. However, neither the EIOTClub application nor apps such as NekokoLPA work on Android directly, neither with the SIM inserted, nor through the (same) card reader. EIOTClub sees the activated slot and even the default profile and 1 GB plan, but trying to activate another (Quibity) one they claim the eSIM is not inserted or that the card is not eUICC compatible. Might be my phone though, it is an old CAT S92 Pro running Android 11. Unfortunately I don't have an access to a newer one to test there."
Stano (4/5)
Super, versatile, works flawlessly. 1 month posting
"pros: works well! works flawlessly with multi sim and all automatically without hassle as per GL-inet statement it's actually a no log card at their side cons: EID is visible printed on the back of the packaging. . . along with a QR code including the EID, also printed on the card itself. . . the pre installed seed is actually a two sided knife, you need net for activation of your esims but this pre installed seed is linked to the EID so when you use it (auto connects) you already linked your device ID to your EID. . . and so on. you cannot delete the ore installed sim only disable via the web admin but need an external card reader to do that if you want that works only with older beta firmwares, so you cannot update to the most secure router firmwares Shipping service GL-inet offers is nightmare, 3-4+ weeks in Europe, by the cheapest postal service, no option for courier."
Eastvan (4/5)
Alternativ
"A great alternativ for not eSIM compatible devices"
Jan G. (5/5)
eSim Issues
"I initially experienced some issues with the eSIM on my GL-X3000. After contacting customer service, I was quickly connected to tech support. They discovered a compatibility issue between the installed eSIM and the North American profiles I was trying to set up, and promptly sent me a replacement eSIM. Both customer and technical support were extremely helpful. Outstanding service!"
Robert (5/5)
Does what it says on the tin. .
"Provides eSIM capability for a device without it - what more is there to say"
Karl L. (5/5)
Great product, recommend!
"Great physical eSIM on which I can add many of my eSIMs. It works on my Android phone when I install eIOT Club application, providing easy switch between your profiles. Comes with 1GB of world wide data."
Florin (5/5)
At the moment we have
"At the moment we have only used it to test out Spitz plus glx 2000. I had problems initially and contacted customer service who put me in touch with tech support. Both members of staff were brilliant a credit to your company"
Andy K. (5/5)
Very handy, currently using in
"Very handy, currently using in pet tracker"
Mr S. (5/5)
Easy and Effortless
"Very easy and effortless to install eSIM on Simpoyo physical card using E750V2"
Bsrtx S. (5/5)
compatible with the Vodafone OneNumber service
"I originally ordered "eSIM - GL. iNet physical eSIM," which unfortunately was not compatible with the Vodafone OneNumber eSIM service (specifically in Czechia, but probably also with other OneNumber services in other countries). Support therefore sent me this SIMPoYo card to try out, which works without any problems. The eSIM profile was successfully installed directly in the updated Puli AX router."
Martin (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
