ATX Board
ATX Board
$15.90
Original price $15.90 - Original price $15.90
$15.90
Current price $15.90
Refined Product Selling Points:
Revolutionize Remote PC Management with ATX Boards
Empower your remote operations with the ability to boot and manage PCs even from a complete shutdown state, ensuring uninterrupted access and control.
Key Features:
Remote Power Control
Boot from Shutdown: Remotely power on PCs that are completely turned off, eliminating the need for physical access.
Crash Recovery: Manually restart your computer in the event of a system crash or freeze to ensure continued operation.
Seamless Integration
Comet Compatibility: Seamlessly integrates with Comet (GL-RM1) to remotely control startup and reboot, as well as perform a forced reboot in the event of a computer failure.
Enhanced Reliability
Hardware-Level Control: Operates independently of the operating system, providing robust control even during system failures.
24/7 Accessibility: Ensure your PCs are always accessible, reducing downtime and improving operational efficiency.
Applications:
Remote Workforces: Manage and support remote employees' PCs without physical intervention.
IT Administrators: Simplify large-scale PC management in enterprises and data centers.
Digital Signage: Maintain uptime for digital displays and kiosks.
Industrial Systems: Ensure continuous operation of critical industrial PCs.
Why Choose ATX Boards?
Unmatched Flexibility: Take full control of PC power states, regardless of their current condition.
Reliable Performance: Built for stability, ensuring your systems are always within reach.
Easy Setup: Direct connection to the motherboard and Comet ensures quick deployment and integration.
Installation:
Simply connect the ATX board to the PC motherboard and Comet (GL-RM1) to unlock advanced remote management capabilities.
Transform Your Remote Operations:
With ATX boards, experience unparalleled control over your PCs, ensuring they are always available when you need them—no matter the state. Perfect for IT professionals, remote teams, and businesses seeking reliable, hardware-level remote management solutions.
Overall rating: 5.0 / 5 from 10 reviews.
AI Generated Review Summary
Summary topics
Review topics: [works, server, addition, machine, computer, inet, job gl].
Review highlights
Reviews
it is very good
"it is very good"
YOU A. (5/5)
Great product
"I bought this because I wanted to have remote access at my parents running open media vault. I had another product that wasn't providing video output at all and gave this a shot. This product did exactly what I wanted. Once I set it up, I was able to view my server remotely and everything worked. No issues with boot screen like the other product. I did have a minor hiccup when Installing the atx accessory board. I had to flip the polarity wires on my Asus z77 sabertooth motherboard. Once that was done, it worked as expected being able to turn the PC on and off remotely. Price was great. If you can wait, then wait around black Friday. I'd also got to give a shout out to the customer service team. They are 😎! Keep up the great work!"
Thanh D. (5/5)
ใช้งานได้ดีมาก ไม่มีปัญหา
"ฝาครอบ atx ไม่สามารถใช้กับเคสแบบ ATX คาดว่าจะใช้กับเคสแบบ mini atx ในส่วนการใช้งาผ่าน web อยากให้ปรับ virtual keyboard สามารถเปลี่ยนภาษาได้"
Kanit W. (5/5)
Very happy with the product.
"Very happy with the product."
JOHN R. (5/5)
Great
"Added with gl-rm1 it works perfectly"
Benjamin G. (5/5)
Simple and works.
"Does what it says it should do. Connects nicely to the Comet so that you can turn on the computer from the Comet web GUI."
Matt C. (5/5)
Great and convienient
"Super convenient to have this with the PoE to remotely start the computer. Great, highly recommend."
Matthew S. (5/5)
Works great for headless media server and off-site remote backup server
"Works great for headless media server and off-site remote backup server, startup, shutdown and diagnostics are now made easy. Good job GL."
Tenneil S. (5/5)
Just works, like it should
"Its nice when things just work, and gl. inet figured this one out again."
Joseph J. (5/5)
Awesome Addition to their KVM
"I added the ATX Board to my Desktop PC so I can remotely boot my machine, works flawlessly."
Alexander S. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
