M2 5G Development Board
$59.90
Original price $59.90 - Original price $225.00
$59.90 - $225.00
Current price $59.90
GL-M2 5G Development Board
MEET GL-M2
5G Development Board for Customization
Expand the Horizon of Your Network Connection
With the GL-M2 Development Board, you can effortlessly upgrade your GL.iNet routers* to harness the power of 5G networks. GL-M2 is designed for individuals interested in constructing their personalized networking solution. The device supports the addition of 5G antennas to enhance signal reception and connectivity. Designed with DIY enthusiasts in mind, this innovative board allows you to fully customize your GL.iNet router for various purposes, opening up a world of possibilities.
Supports 5G Module (RM520N-GL)
Learn More
Seamless Integration
The M2 Development Board seamlessly integrates with your GL.iNet travel router*, making installation a breeze. Simply attach the board to your router, and you're ready to experience the power of 5G connectivity.
*M2 is compatible with the following devices:
- Slate AX (GL-AXT1800), Beryl AX (GL-MT3000) & Brume 2 (GL-MT2500) : Firmware version 4.2.1 and above.
- Flint (GL-AX1800): Firmware version 4.2.3 or above
- Flint 2 (GL-MT6000) : Firmware version 4.5.1 or above.
Lightning-Fast Speeds
Harness the full potential of 5G* technology and enjoy lightning-fast speeds for all your online activities. Stream high-definition videos, participate in video conferences, or download large files with ease, all at breathtaking speeds.
*The network connectivity is subjected to ISP’s 5G network coverage provision. If 5G service is not available in certain areas, the network connectivity might experience a decrease in network service speed from 5G NR to 4G LTE or below.
Global Compatibility
Our 5G module supports a wide range of frequency bands, ensuring compatibility with major carriers worldwide. Wherever you are, you can rely on the M2 Development Board to keep you connected.
Extended Coverage
Our 5G antennas are designed to maximize signal reception, extending the range of your cellular connectivity. Stay connected even in areas with weak network coverage and enjoy uninterrupted access to the internet.
DIY Mobile Router
With M2 and its 5G antennas, you can enable your DIY mobile router to a new level of connectivity. You can enhance your GL.iNet router connectivity just by connecting it to your M2 development board with USB 3.0. In other application scenarios, you may have to customize your internet driver to allow your computer, router, and IoT devices to attain a 5G network connection to enhance connectivity and capability.
5G NR Module
5G NR
Module
SMA Antennas
SMA
Antennas
Type-C
Type-C
Nano SIM Card Slot
Nano SIM
Card Slot
Specification
Interface 1 x DC Power Socket
1 x Type-C
1 x M.2 Key-B port
1 x Nano SIM Card Slot
1 x Reset Button
Power Supply DC5521, 12V/1.5A (5.5*2.1mm)
Operating Temperature 0~40°C (32~104°F)
Dimension / Weight 91 x 57.5 x 1.6mm / 150g (With 5G Module)
(M2 Dev Board 39g, 4 x 5G Antennas 102g, 5G Module 9g)
Tools & Downloadables Datasheet | Unboxing | Tutorials | Media Kit
Overall rating: 4.923077 / 5 from 13 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["connection","works","downside","case","device","sim card","5g board"].
Review highlights
Reviews
Excellent products, even better customer service!
"I've only purchased GLiNet products because they performed great but I recently had a small issue and needed support. That issue was resolved so quickly and effortlessly that it put other companies to shame. Highly recommend GLiNet for all your networking needs!"
— Peter G. (5/5)
Excellent Performance and High Quality
"This M2 5G Development Board exceeded my expectations. The build quality is fantastic, and the 5G connectivity is fast and stable. Highly recommended for developery"
— Bassel B. (5/5)
It has arrived after a
"It has arrived after a long journey. I haven't tested yet, but I think GL. iNet is coolest company and really supports people worldwide wanting the best wireless internet components and systems."
— Charles M. (5/5)
Stable, Reliable, Speedy
"I bought this to enable 5G SA for my Flint 2. It's been 2 weeks since and my 5G connectivity has been rock steady. I did not regret cancelling my broadband subscription for this."
— Julian C. (5/5)
Works well
"Works well"
— Justin L. (5/5)
exelect thank you ,
"exelect thank you ,"
— Marcin C. (5/5)
Great product
"For be honest I had some doubts with this purchase, but works great, I can use it with my router and with my computer, it’s highly recommended"
— Sergio R. (5/5)
What an excellent device! I
"What an excellent device! I have very poor 5G and quite poor 4G but the modem stepped down to 4G seamlessly and I have a rock-steady connection. I did have to research the correct APN settings for my SIM cards and enter them manually. Tested with Brume2, Slate AX, Beryl AX and Flint V1 and all good. Using it primarily as a failover for my PPoE connection on my Brume2 to. On simulating a line drop it kicked in really quickly. Now to make a case for it!"
— Adrian K. (5/5)
It's great. Very pleased.
"It's great. Very pleased. Only downside is the lack of commercially available case."
— Christian (5/5)
Excellent!!!
"Works as expected. . you connect it to your home router and all of your connections will get 5g. You dont need the sim card if connected to your home internet, the sim is only when your away and dont have internet connection."
— Yair A. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
