GL-S10 BLE IoT Gateway
MEET GL-S10
Connecting IoT Devices to the Cloud
Shop Now Contact Sales
Bluetooth IoT Gateway
GL-S10 is an ESP32-powered BLE to MQTT IoT gateway. It can be used to facilitate communication between your beacons and servers, such as MQTT broker and AWS IoT. GL-S10 also comes with an optional beacon for testing and a tool app for fast and easy deployment.
Built-in Bluetooth Module
Support MQTT and PoE Power Supply
Built with ESP32
*This product cannot be used as a WiFi Access Point
Learn More View Online Guide
How GL-S10 Works
The GL-S10 is an IoT gateway device that supports BLE and Wi-Fi, providing a cost-effective solution for transmitting BLE broadcast data to the cloud. BLE supports GAP and GATT certification. GL-S10 can use Wi-Fi as a Station to connect to a parent route or can connect to the Internet through a WAN port. It has a built-in standard MQTT Client that can connect to any standard MQTT Servers to forward incoming BLE messages to the cloud server.
How S10 Works
ESP32-D0WD Chipset
ESP32 is a single-chip integrated with 2.4GHz Wi-Fi and BLE. It features ultra-high RF performance, with high stability, versatility, and ultra-low power consumption. GL-S10 is suitable for a wide variety of application scenarios.
GL-S10 deployed in warehouses
A Minimalist IoT Communication Solution
GL-S10 is a compact BLE IoT gateway that supports Wi-Fi and MQTT protocols. It is designed to be an essential, low power consumption and low-cost transmission device.
Comes with a Tool App
for easy set up & configuration
  • app-store
  • google play
Application Scenarios
Bluetooth 4.2
Bluetooth 4.2
AWS IoT
AWS IoT
PoE
PoE
MQTT
MQTT
Real-time Scanning
Real-time Scanning
Wi-Fi 150Mbps
Wi-Fi 150Mbps
Specification
Interface1 x Ethernet port
3 x LEDs
1 x Reset Button
CPUESP32-D0WD
Memory / StorageSRAM 520KB + PSRAM 8MB / NOR Flash 4MB
ProtocolIEEE 802.11 b/g/n
Wi-Fi Speed150Mbps (2.4GHz)
Ethernet Speed1 x 10/100Mbps
LEDsPower / BLE / Network
BluetoothV4.2, BLE
Power InputMicro USB, 5V/1A or PoE Power Input
Power ConsumptionNormal Operating Consumption: <0.5W / Operating at Full Capacity: <1.5W
Operating Temperature0~40°C (32~104°F)
Storage Temperature-20~70°C (-4~158°F)
Dimension / Weight57 x 57 x 25mm / 53.6g
Tools & Downloadables Datasheet | App | Product video | Tutorials | Media Kit
Our team are ready to support your projects
Talk to an expert in bluetooth gateway technology
Contact Us
