Edge Computing Gateway
Brume (GL-MV1000) and Brume-W (GL-MV1000W)* are powerful and stable networking products designed to do cutting-edge computing. With the Marvell high-performance chipset, the Brume and Brume-W* can run state-of-the-art cryptography at impressive speeds for an excellent VPN routing experience. Pre-installed OpenWrt and supported Ubuntu, Brume and Brume-W* allows in-depth developments for commercial IoT projects.
Brume-W (GL-MV1000W)* is the special edition of Brume (GL-MV1000) that comes with an embedded Wi-Fi module, which delivers high-speed WiFi performance on 2.4GHz Wi-Fi with up to 300Mbps Wi-Fi speed.
256GB Max MicroSD
8GB eMMC
Your Privacy is Safe with Us
Brume keeps your Internet connection private with multiple VPN protocol support. It provides the encryption and authentication with OpenVPN. Meanwhile, WireGuard gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography. You can even configure your router to act as a VPN server and you can access the server whenever you want.
Learn More
GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, setup VPN server and client, manage client connection list, and more through the App or web admin panel.
Learn More
Web Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Remote SSH
Work or Play Securely from Anywhere, Anytime
Apart from its powerful built-in firewall, Brume also supports OpenVPN, WireGuard and customized DNS server to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely via a remote site as if you are at home.
WireGuard® is a registered trademark of Jason A. Donenfeld.
WireGuardOpenVPN
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
High-speed Wi-Fi Performance
Brume-W comes with an embedded Wi-Fi module, which delivers 2.4GHz Wi-Fi with up to 300Mbps Wi-Fi speed. By using 1GB DDR4 RAM, it ensures the high-performed operation of the system.
OpenWrt
Pre-installed
Ubuntu
AdGuard
Home
Tor
Anonymity
VPN Client /
Server
External
Storage
Large
Storage
Gigabit
Ethernet
Specifications
| Interface |
1 x WAN Ethernet port 2 x LAN Ethernet port 1 x USB 2.0 port 1 x Type-C power port 1 x MicroSD card slot 1 x Reset button 1 x Toggle button |
| CPU | Marvell Armada 88F3720, Dual-Core ARM Cortex-A53 @1.0GHz |
| Memory / Storage | DDR4 1GB / NOR Flash 16MB + EMMC 8GB |
| WiFi Speed | Brume-W only: 300Mbps (2.4GHz) |
| Ethernet Speed | 10/100/1000Mbps |
| LEDs | Power, WAN/WIFI, VPN |
| Power Input | Type-C, 5V/3A |
| Operating Temperature | 0~40°C (32~104°F) |
| Storage Temperature | -20~70°C (-4~158°F) |
| Dimension / Weight | Brume: 88 x 68 x 24mm / 105g, Brume-W: 102 x 68 x 24mm / 115g |
| Tools & Downloadables |
Firmware
App (for GL-MV1000W) Tutorials (for GL-MV1000) Tutorials (for GL-MV1000W) |
Looking for Bulk Purchase?
Contact Our Sales Manager-
Free Local Shipping
Fast delivery
Rewards on Every Order
2 points for every $1 spent
2-Year Warranty
Reliable product coverage
30-Day Returns
Fast and easy refunds
