GL-MT750
This item is discontinued.- Powered by MTK 7620A + MT7610E
- 2.4G + 5G dual radio
- 750Mbps high speed, 802.11ac
- Large RAM up to 128M
- OpenWrt pre-installed
- IO ports reserved for function extending
- Optional PoE support
| CPU | MTK 7620A @580Mhz |
| Memory/Storage | DDR2 128MB/ FLASH 16MB |
| Interfaces | 1 WAN, 4 LAN, 1 USB2.0, 1 Reset button, 1TF card, 1DC in(12V) |
| Frequency | 2.4GHz/5.8GHz |
| Transmission rate | 750Mbps |
| WAN/LAN | 10/100Mbps |
| Max Tx Power | 20dBm |
| Protocol | 802.11 ac/a/b/g/n |
| External Storage support | FAT32/EXFAT/EXT4/EXT3/EXT2/NTFS |
| Webcam support | MJPG, YUV |
| DIY features | UART, 4GPIO, 3.3V & 5V power port |
| External antenna support | 2 dual-band antenna |
| PoE support | Yes, optional |
| Power input | 12V/1A |
| Power consumption | <10W |
| Dimension, Weight | 170*150*38mm, 250g |
