Top-Notch Secure Travel Router
Beryl (GL-MT1300) is a high-performance next generation pocket-sized router that offers a powerful hardware and first-class cybersecurity protocol with unique and modern design. Beryl is the new era of travel router, an advanced version of our best-seller, Slate (GL-AR750S).
Powerful CPU with 3 x Gigabit Ports
Excellent Security withVPN & Tor
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
Powerful Hardware With Advanced WiFi Speeds
Beryl comes with a dual-band WiFi with fast speed up to 400Mbps (2.4GHz) + 867Mbps (5GHz). Provides the customers with excellent WiFi experience on the go. Advanced CPU, Type-C power supply, USB 3.0 Port, and 3 Gigabit Ethernet ports offer a fast network and transmission speed anywhere to optimize users’ experience.
Support Max. 40 Connected
Wireless Devices Simultaneously
No More Hackers, Access Home Network Securely
Beryl provides the best encryption and authentication with OpenVPN & WireGuard®, just like the other GL.iNet products. Keeping your Internet connection private with multiple VPN protocol support. With our Web UI 3.0, you can set up a VPN server easily and access your files securely in a remote site as if you are at home.
WireGuardOpenVPN
* OpenVPN speeds will be slower when running the device as a server. Results above are in client mode.
Tor Service Pre-installed
Backed by world-class researchers, Tor (The Onion Router) is pre-installed in Opal. Your online identity and browsing data could be concealed from surveillance and third-party trackers easily with Tor. Your traffic is encrypted three times as it passes over the Tor network so your network will be extra safe!
Learn More
DNS Encryption with Cloudflare
Beryl supports Cloudflare DNS over TLS, it keeps users' online actions secure and private. DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS). The goal is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Dual-band
Wi-Fi
IPv6
VPN Client /
Server
Tor
Anonymity
DNS
Encryption
OpenWrt
Pre-installed
External
Storage
Gigabit
Ethernet
Type-C
Power Input
USB 3.0
Port
Specification
| Interface |
1 x WAN Ethernet port 2 x LAN Ethernet ports 1 x USB 3.0 port 1 x Type-C power port 1 x MicroSD card slot (Max.512GB) 1 x Reset button 1 x Switch button |
| CPU | MTK MT7621A, Dual-Core @880MHz |
| Memory / Storage | DDR3L 256MB / NOR Flash 32MB |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 400Mbps (2.4GHz), 867Mbps (5GHz) |
| Wi-Fi Antennas | 2 x undetachable external Wi-Fi antennas |
| Ethernet Speed | 10/100/1000Mbps |
| Power Input | Type-C, 5V/3A |
| Power Consumption | <8.65W |
| Operating Temperature | 0 ~ 40°C (32 ~ 104°F) |
| Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) |
| Dimension / Weight | 118 x 85 x 30mm / 184g |
| Tools & Downloadables | Firmware | App | Set up video | Tutorials |
