Introducing Opal, The Most Cost-Effective Gigabit Router Ever
During this festive season, we’re delighted to introduce Opal (GL-SFT1200), our high-performing gigabit wireless router that is small in size, yet with strong Wi-Fi speed and security features. GL.iNet hopes to respond to varying customer needs by producing a cost-effective mini router. Opal has amazing unique features and its size is perfect for small apartments and frequent travelers.
At only $39.9 USD each, Opal offers a powerful Internet connection with Max. 300 Mbps (2.4G) + 867 Mbps (5G) Quick Wi-Fi Speeds.The secured and stable connection is ideal for documents transfers, conference calls, and a smooth Internet experience no matter when and where you are. Equipped with Type-C power supply, USB-A 2.0 Port, and 3 Gigabit Ports, you can connect to an efficient network through Ethernet, repeater, tethering, or USB 3G/4G modem.
Pre-installed OpenWrt
Opal (GL-SFT1200) comes with OpenWrt system pre-installed, giving you the freedom to customize your router based on your preferences. You can install different softwares to optimize your device and improve your Wi-Fi experience!
Heightened Internet Security
As with all GL.iNet products, Opal supports over 30+ popular VPN services, you can check our recommended list for popular choices
This smart router comes with impressive security features. The toggle switch allows you to switch between VPN and Tor easily, letting you protect your online identities and keep your activities private from surveillance and hackers. With Cloudflare, DNS over TLS security Protocol, and IPv6 (the latest version of the Internet Protocol), you get an extra layer of security; This lowers the chances of eavesdropping and man-in-the-middle attacks.
Compact and Modern Design
Designed with compactness in mind, Opal is light in size and has foldable antennas, making it convenient to bring around. You can carry them to cafés, hotels, or libraries when you need protection over public-wifis. The bright white color emits calmness and gives a sense of space, making it ideal for small apartments.
Order one for yourself or buy one as a festive gift! ❄️
About GL.iNet
Founded in 2010, GL.iNet is a leading provider of innovative routers and networking solutions. From compact travel routers to cutting-edge remote KVMs, GL.iNet delivers award-winning networking technology designed for performance and security.
GL.iNet gives people and organizations the power to connect with confidence. By putting control in the hands of users, GL.iNet supports the productivity and collaboration that shape a Good Life.
