Industrial 4G IoT Gateway
Amarok is a powerful and stable operation, a cost-effective product designed to meet the needs of industrial users through 4G/3G signal wireless internet access. Because of its open source platform-based features, it can also be used as an integrated platform for extension such as developers, makers, and IoT integration development.
5 x Gigabit Ports
PCIe 4G LTE Modem
128GB Max MicroSD
Supports MU-MIMO
Enterprise IoT Solution
Driving innovation and digital transformation with our Enterprise IoT solutions, Amarok can unleash the value of IoT for your business and apply to multiple domains, such as public utilities, logistics, manufacturing, and smart city.
Flexibility During Deployment
Dual-SIM functionality allows you to switch carriers when you insert two active SIMs on two different carriers into the router. As a result, it can switch to the carrier that is providing the best network experience at that location. It also has a TF card slot and a USB 2.0 port for you to save user data in the external storage.
Industrial Grade Standard
Amarok has 5 Gigabit Ethernet Ports, 1 Gigabit Ethernet Ports can be used as WAN port, and other Gigabit Ethernet Ports are LAN ports. Amarok is based on OpenWrt opensource platform which brings routing function and wireless access point together and can be flexible expanded. Amarok supports 12V or 48V DC power supply or PoE power supply.
Industrial Grade LTE Module for All Regions
Amarok are compatible with CAT4 and CAT6 LTE modules from various brands. Wherever your office is located, you can easily find the best fit with the best price.
Wi-Fi for Things
Bringing Robust Network Connections to IoT World
Facilitating Secure IoT Communications
Amarok creates a secure network for devices that process sensitive information such as ATMs, Point-of-Sales (POS) and more, encrypting their 4G LTE or Wi-Fi traffic via a VPN tunnel for secure access to the Internet or remote services.
RTC
(Real-time Clock)
PoE
Power Supply
Extreme
Environment
Built-in
Watchdog Timer
GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, setup VPN server and client, manage client connection list, and more through the App or web admin panel.
Learn MoreWeb Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Remote SSH
Work or Play Securely from Anywhere, Anytime
Apart from its powerful built-in firewall, Amarok also supports OpenVPN, WireGuard and customized DNS server to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely via a remote site as if you are at home.
WireGuardOpenVPN
4G LTE
Module
Gigabit
Ethernet
Multi-User
MIMO
Dual-band
Wi-Fi
VPN Client /
Server
GPS
Specifications
| Interface | 1 x WAN Ethernet port 4 x LAN Ethernet port 16 x LEDs 1 x USB 2.0 port 2 x Standard SIM card slot (e-SIM is optional) 1 x MicroSD card slot |
| CPU | QCA9563, @775MHz SoC |
| Memory / Storage | DDR2 128MB / FLASH 16MB + 128MB |
| 3G/4G Modem | Support 2 x 4G LTE CAT4 (CAT 6 is optional) |
| 4G Antennas | 4 x External full-band antennas (700Mhz ~ 2.7GHz) |
| Wi-Fi Antenna | 2 x External (5dBi) |
| GPS Antenna | 1 x External |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 2.4GHz(300Mbps), 5GHz(867Mbps) |
| Ethernet Port | 5 x 10/100/1000Mbps Adaptive ethernet ports (1x WAN + 4x LAN) |
| LEDs | Power / PoE output / System / WAN / LAN / 2.4G Wi-Fi / 5G Wi-Fi / 4G Module #1 signal / 4G Module #2 signal |
| Power Input | 48V/1A or 12V/3A DC input or PoE input (802.3at) |
| Power Consumption | <11W (Exclude power consumption of external device connected by USB port) |
| Operating Temperature | -20~55°C (-4~131°F) Extended Operating Temperature: If powered by PSU, -20~60°C (-4~140°F). If powered by POE, -40~70°C (-40~158°F). But the performance may be affected.) |
| Storage Temperature | -40~70°C (-40~158°F) |
| Dimension / Weight | 240 x 145 x 40mm / 1360g |
| Tools & Downloadables | Firmware | App | Tutorials |
