GL.iNet 6416
This item is discontinued.- Powered by Atheros AR9331
- Stable
- Low cost
- GPIO, UART
GL.iNet 6416 is our first mini starter router designed for OpenWrt and DIY hobbyists. It provides stable performance with affordable price.
In hardware, it provides 5 GPIOs in 2.0mm distance, UART, 3.3V Power, 1 USB-A adapter, one Reset button. It is powered by any USB power adapter which can provide 5V 1A.
In software, it comes with OpenWrt BB 1407 firmware. And GL.iNet target has emerged in OpenWrt trunk and you can have the newest OpenWrt release easily. We provide a beautiful and easy-to-use WebUI built on top of the original OpenWrt Luci interface. USB storage auto mounting, files sharing, offline download and video streaming has been built inside of the default firmware. Save your time to configure your OpenWrt.
| CPU | Qualcomm Atheros 9331, @400MHz |
| Memory/Storage | DDR1 64MB/ FLASH 16MB |
| Interfaces | 1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button |
| Frequency | 2.4GHz |
| Transmission rate | 150Mbps |
| Max Tx Power | 18dBm |
| Protocol | IEEE 802.11b/g/n |
| External Storage support | FAT32/EXFAT/EXT4/EXT3/EXT2/NTFS |
| Webcam support | MJPG, YUV |
| DIY features | UART, 5GPIO, 3.3V & 5V power port |
| External antenna support | No |
| PoE support | No |
| Power input | 5V/1A |
| Power consumption | <1W |
| Dimension, Weight | 58*58*22mm, 43g |
