Creta (GL-AR750)
GL-AR750 Travel AC Router
MEET CRETA
Dual-Band Wireless Router with Expandable Storage
Discontinued
Travel AC Router
Creta (GL-AR750) is a dual-band travel AC router. The simultaneous dual-band supports up to 733Mbps (2.4GHz: 300Mbps + 5GHz: 433Mbps) wireless transmission rate. Creta can convert a public network to a private Wi-Fi for secure surfing. External storage supports MicroSD up to 128GB. OpenWrt/LEDE and OpenVPN are pre-installed. Therefore, Creta gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography.
Max. 300Mbps (2.4GHz) + 433Mbps (5GHz) Wi-Fi Speed
128GB Max. MicroSD
Support PoE (Optional)
Learn More View Online Guide
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
Your Personal Wi-Fi Router
  • Fast Wi-Fi Speed: Simultaneous dual-band with wireless speed 300Mbps (2.4GHz) + 433Mbps (5GHz)
  • Open Source Platform: Pre-installed OpenWrt/LEDE, a highly customizable Linux OS
  • External Storage: Extra space for sharing files
Traveling Safely
Traveling Safely From Now On...
With OpenVPN Enabled,
  • Convert untrusted networks such as public Wi-Fi into your own secure virtual private network (VPN).
  • Mask your IP address to protect your online privacy and keep you from being tracked and exploited online.
  • Keep sensitive information safe: Encrypt your personal data and online traffic all the time.
Watching Your Favorite Show Anytime, Anywhere...
  • You can enjoy streaming service away from home country.
  • It also comes in handy when you're traveling in censorship-heavy countries.
  • With up to 15Mbps OpenVPN Speed, you will be able to watch streaming videos.
WIRELESS SHARING
Sharing Files Across Devices
Creta has a built-in MicroSD slot that has a 128GB capacity. With the extra storage, you can create a local drive to store and download files on your laptop and other compatible devices as long as it is connected to the Wi-Fi.
HIGH EXTENSIBILITY
Optional PoE Support
Power over Ethernet (PoE) is a networking feature defined by the IEEE 802.3af and 802.3at standards. With optional PoE module, Creta can allow power supply over Ethernet with the existing data connection when you also have 48V PoE injector ready.
20+ VPN SERVICE PROVIDERS FOR YOUR SELECTION
Mask Your Online Identity with VPN
Apart from its powerful built-in firewall, Creta also supports VPN, WireGuard and DNS server in order to level up your online security. With brand-new Web UI 3.0, you can set up VPN server easily. It can be configured as VPN server and allow users to access files securely as if they were at home.
WireGuard® is a registered trademark by Jason A. Donenfeld.
WireGuard
Max. 50Mbps
OpenVPN
Max. 15Mbps
WebUI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Cloudflare x GL.iNet
Mango
(GL-MT300N-V2)
Mini Smart Router
Shadow
(GL-AR300M)
Mini Wireless Router
Creta
(GL-AR750)
Travel AC Router
Slate
(GL-AR750S)
Gigabit Travel Router
Wi-Fi Repeater
USB Modem
Tethering
MicroSD Card Slot
Dual-Band Wi-Fi
PoE
OPENVPNMax. 11MbpsMax. 15MbpsMax. 15MbpsMax. 17Mbps
WIREGUARD®Max. 45MbpsMax. 50MbpsMax. 50MbpsMax. 68Mbps
* Tests are conducted on a Local Network. Real world speeds may differ depending on your network configuration.
OpenWrt Pre-installed
OpenWrt
Pre-installed
External Storage
External
Storage
Dual-band Wi-Fi
Dual-band
Wi-Fi
VPN Client/Server
VPN Client /
Server
High Speed
High Speed
PoE (Optional)
PoE
(Optional)
Specification
Interface1 x WAN Ethernet port
2 x LAN Ethernet ports
3 x LEDs
1 x USB 2.0 port
1 x Micro USB Power Input
1 x MicroSD card slot (Max.128GB)
1 x Reset button
1 x Toggle button
CPUQCA9531 @650Mhz SoC
Memory / StorageDDR2 128MB / NOR Flash 16MB
AntennasInternal
ProtocolIEEE 802.11a/b/g/n/ac
Wi-Fi Speed300Mbps (2.4GHz) + 433Mbps (5GHz)
TX Power<20dBm
Ethernet Speed10/100Mbps
LEDsPower Supply / 2G / 5G
Power InputMicro USB, 5V/2A
Power Consumption<4W
Operating Temperature0 ~ 40°C (32 ~ 104°F)
Storage Temperature-20 ~ 70°C (-4 ~ 158°F)
Dimension / Weight88 x 68 x 24mm / 66g
Tools & Downloadables Firmware | App | Tutorials
Looking for In-depth Solutions?
Contact Our Sales Manager
