Smart Home Gateway
Convexa-S is a unique smart home gateway with beamforming Wi-Fi and Bluetooth* that can connect all your IoT devices together. More wireless protocols will be added.
Built-in Bluetooth Module *
3 x Gigabit Ports
Supports MU-MIMO
* In developement
Learn More View Online GuideSmart Home Gateway Solution
An OpenWrt Home Gateway for Your Internet of Things
Eliminate Wi-Fi Dead Zones
Convexa-S is equipped with Qualcomm Wi-Fi SON (Self-Organizing Network) mesh technology to deliver robust and consistent connectivity to your entire home. Multiple units are required to extend the Wi-Fi network throughout your home.
Maximize the Wi-Fi Speed
Convexa-S adopts MU-MIMO and Beamforming technology
Connecting Smart Home Sensors
Convexa-S can connect to various sensors with Bluetooth*. Users can remotely monitor and control the sensors via the cloud. Convexa-S supports an open platform that can be easily customized for different scenarios and functions as a part of a trusted security mechanism to secure anything that is connected to it.
Newly Developed BLE Module
It is based on proven Silicon Labs chipset, low power consumption, multi-protocol supportable, and on-board antenna supportable.
Wide application scenarios as below:
✓ IoT multi-protocol devices
✓ Smart Home
✓ Lighting
✓ Health monitoring products
✓ Measuring equipment
✓ Products on Building automation and Security
Control your devices anywhere, anytime with our device cloud - GoodCloud.xyz It will be ready to integrate with IoT devices
Web Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Large Storage for Offline Data
With an 8GByte EMMC (Embedded Multi-Media Card) storage, Convexa-S allows you to store your data offline, save bandwidth and process data locally. With massive space for customized firmware installation, you can also enjoy faster device booting and system processing.
Work or Play Securely from Anywhere, Anytime
Apart from its powerful built-in firewall, Convexa-S also supports OpenVPN, WireGuard® and customized DNS server to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely via a remote site as if you are at home.
WireGuardOpenVPN
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
OpenWrt
Pre-installed
Gigabit
Ethernet
Multi-User
MIMO
Dual-band
Wi-Fi
VPN Client/
Server
Mesh
Network
Large
Storage
Bluetooth
(Optional)
Specifications
| Interface | 1 x WAN Ethernet port 2 x LAN Ethernet ports 3 x LEDs 1 x USB 3.0 port |
| CPU | IPQ4029 Quad-core ARM, @717MHz SoC |
| Memory / Storage | DDR3L 512MB / NOR Flash 16MB + EMMC 8GB |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 400Mbps (2.4GHz), 867Mbps (5GHz) |
| Wi-Fi Antennas | Internal |
| TX power | <20dBm |
| Ethernet Speed | 10/100/1000Mbps |
| LEDs | Wireless / Mesh / Power |
| Bluetooth | Optional |
| Zigbee | Optional |
| Power Input | 12V/1.5A |
| Power Consumption | <7W |
| Operating Temperature | 0 ~ 40°C (32 ~ 104°F) |
| Storage Temperature | -20~70°C (-4~158°F) |
| Dimension / Weight | 117 x 117 x 35mm / 240g |
| Tools & Downloadables | Firmware | App | Tutorials | Media Kit |
