GL-MT300A
- Powered by MTK 7620A 580Mhz SoC
- 300Mbps high speed
- Large RAM, 128MB. Up to 256MB.
- Small, light, easy to use
- OpenWrt pre-installed
- UART and MicroSD interface, with MicroSD daughter board
- External antenna optional support
| CPU | MTK 7620A @580Mhz |
| Memory/Storage | DDRII 128MB/ FLASH 16MB |
| Interfaces | 1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button |
| Frequency | 2.4GHz |
| Transmission rate | 300Mbps |
| Max Tx Power | 20dBm |
| Protocol | IEEE 802.11b/g/n |
| External Storage support | FAT32/EXFAT/EXT4/EXT3/EXT2/NTFS |
| Webcam support | MJPG, YUV |
| DIY features | UART, TF Card interface, 3.3V & 5V power port |
| External antenna support | Yes |
| PoE support | No |
| Power input | 5V/1A |
| Power consumption | <2W |
| Dimension, Weight | 58*58*25mm, 39g |
