Enterprise Wireless Networks Access Point
Cirrus ceiling wireless access point is an elite business-class level gateway with MU-MIMO Wi-Fi solution. PoE power supply and Watchdog timer built-in function are implemented in order to fulfill most enterprise-level user cases. With well-developed Goodcloud management system, managing the device is very easy and convenient. You can enable a remote and secure access wherever you are and whenever you want.
Supports MU-MIMO
2 x Gigabit Port
PoE Power Supply
Built-in Watchdog
The Ultimate Wi-Fi Speed and Performance
Cirrus has two internal antennas which has dual-band (2.4GHz + 5GHz). 2 Gigabit Ethernet ports with RJ45 Interface. The dual-band Wi-Fi provides simultaneous 400Mbps on 2.4GHz and 867Mbps on 5GHz, which in total 1267Mbps Wi-Fi speeds.
Model Comparison
![]() GL-AP1300 | VS | ![]() GL-AP1300LTE |
4G LTE MODULE | ||
EXTERNAL ANTENNAS | ||
IOT BLE MODULE | ||
POE |
Interchangeable Module Tailored to Your Needs
Cirrus is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules from various brands.
Establishing 4G LTE Cellular Network for Mobility
Cirrus (GL-AP1300LTE) has a built-in nano SIM card slot. When inserting the nano SIM card into the slot, the side of the card upon which the chip lies should go upwards, and the vacant point of the card should be aligned with the upper right-hand corner.
4G LTE Internet Backup
Connection automatically moves into 4G LTE wireless network if the Ethernet Internet fails, in order to ensure constant data transmission in the critical facilities.
PoE Power Supply
Power over Ethernet (PoE) is a networking feature defined by the IEEE 802.3af and 48V 802.3at standard. With PoE module, Cirrus can allow power supply over Ethernet with the existing data connection when you also have 48V PoE injector ready.
Mask Your Online Identity with VPN
Keeping your Internet connection private with multiple VPN protocol support, Cirrus provides the best encryption and authentication with OpenVPN. Meanwhile, WireGuard® gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptographic algorithms. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely via a remote site as if you are at home.
WireGuardOpenVPN
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, setup VPN server and client, manage client connection list, and more through the App or web admin panel.
Learn MoreWeb Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Remote SSH
Network Architecture
Flexible deployment choices for SMEs to design secure and reliable commercial wireless networks
Technical InquiryApplication Scenarios
Network infrastructure for Cold Chain Logistics
Learn More
OpenWrt
Ready
Gigabit
Ethernet
Dual-Band
Wi-Fi
VPN Client/
Server
Multi-User
MIMO
PoE Power
Supply
Watchdog
RTC
Module*
4G LTE
Module*
Bluetooth
(Optional)
Specifications
| Interface | 1 x WAN Ethernet port 1 x LAN Ethernet port 1 x Reset button |
| CPU | IPQ4018 Quad-core ARM, @717MHz SoC |
| Memory / Storage | DDR3L 256MB / NOR Flash 4MB + NAND Flash 128MB |
| Wi-Fi Antennas | 2 x Internal |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 400Mbps (2.4GHz), 867Mbps (5GHz) |
| Ethernet Speed | 10/100/1000Mbps |
| LEDs | 2 x Single-color LED, for Indicate Power and System |
| Power Supply | 12V/2A DC / 802.3at POE-IN |
| Power Consumption | <10W |
| Operating Temperature | -10 ~ 40°C (14 ~ 104°F) |
| Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) | Dimension / Weight | 200 x 200 x 40mm / 692g |
| Tools & Downloadables | Product Flyer | Firmware | App | Unboxing | Tutorials | Media kit |
