Industrial 4G DTU Gateway
GL-XD1 is a compact and flexible industrial 4G DTU gateway. It supports TCP, IP, MQTT, UDP, HTTP and MODBUS protocols which satisfy all your business needs. With the DTU pass-through feature and RS485 interface, it can apply to different industries, such as smart transportation, smart logistics, vending machines, AI, environment monitoring, etc.
Support RS485 & RS232 interface
Built-in GPS (Optional)
Learn More
Industrial Grade LTE Module for All Regions
GL-XD1 is compatible with CAT1 module. Wherever your office is located, you can easily find the best fit with the best price.
GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, setup VPN server and client, manage client connection list, and more through the App or web admin panel.
Web Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Remote SSH
Satisfy All Your Needs
The router has a wide range of application, such as security camera, smart water meters, pressure gauges, smoke detectors, smart farm, industrial devices etc.
Smart Parking
EV Charging Stations
Self-service Terminals
Public Transportation
Industrial Data Collection
Smart Energy
Environment Monitoring
Smart Agriculture
OpenWrt
Ready
VPN Client/
Server
4G LTE
Module
RS485
GPS*
Specifications
Interface |
1 x Power Port 1 x RS323 1 x RS485 2 X SIM Card Slot 1 x Reset Button |
LEDs | Power, 4G, RS485 and GPS |
Power Supply | 12V/1A DC |
Power Consumption | <9W |
Operating Temperature | -30 ~ 50°C (-22 ~ 122°F) |
Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) | Dimension / Weight | 80 x 60 x 20mm / 200g |
