{"product_id":"gl-mt750","title":"GL-MT750","description":"\u003cstyle\u003e\n    .products-main-container .nav-link {\n        color: grey;\n    }\n\n    .products-main-container .nav-link.active {\n        color: #43c8cf;\n    }\n\u003c\/style\u003e\n\n\u003cmain class=\"products-main-container\"\u003e\n    \u003cnav aria-label=\"breadcrumb\" class=\"container\"\u003e\n        \u003col class=\"breadcrumb bg-white\"\u003e\n            \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/\"\u003eHome\u003c\/a\u003e\u003c\/li\u003e\n            \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/products\"\u003eProducts\u003c\/a\u003e\u003c\/li\u003e\n            \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/pages\/discontinued\/\"\u003eDiscontinued\u003c\/a\u003e\u003c\/li\u003e\n            \u003cli class=\"breadcrumb-item active\" aria-current=\"page\"\u003eGL-MT750\u003c\/li\u003e\n        \u003c\/ol\u003e\n    \u003c\/nav\u003e\n    \u003csection class=\"container mb-4\"\u003e\u003cimg src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt750\/mt750_1920x775.jpg\" alt=\"gl-inet products GL-MT750\" class=\"img-fluid\"\u003e\u003c\/section\u003e\n    \u003csection class=\"container\"\u003e\n        \u003cul class=\"nav nav-tabs\" id=\"productsTab\" role=\"tablist\"\u003e\n            \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link active\" id=\"introduction-tab\" data-toggle=\"tab\" href=\"#introduction\" role=\"tab\" aria-controls=\"introduction\" aria-selected=\"true\"\u003eIntroduction\u003c\/a\u003e\u003c\/li\u003e\n            \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"specs-tab\" data-toggle=\"tab\" href=\"#specs\" role=\"tab\" aria-controls=\"specs\" aria-selected=\"false\"\u003eSpecs\u003c\/a\u003e\u003c\/li\u003e\n            \u003c!-- \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"download-tab\" data-toggle=\"tab\" href=\"#download\" role=\"tab\" aria-controls=\"download\" aria-selected=\"false\"\u003eDownload\u003c\/a\u003e\u003c\/li\u003e --\u003e\n        \u003c\/ul\u003e\n        \u003cdiv class=\"tab-content\" id=\"productsTabContent\"\u003e\n            \u003cdiv class=\"tab-pane fade show active\" id=\"introduction\" role=\"tabpanel\" aria-labelledby=\"introduction-tab\"\u003e\n                \u003cdiv class=\"row mt-4\"\u003e\n                    \u003cdiv class=\"carousel slide col-12 col-md-6 col-lg-6\" data-ride=\"carousel\"\u003e\n                        \u003cdiv class=\"carousel-inner\"\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt750\/ar300_500x500_2.jpg\" alt=\"First slide\"\u003e\u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item active\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt750\/DSC_9923_1024x1024.jpg\" alt=\"Second slide\"\u003e\u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt750\/ar300_500x500_0.jpg\" alt=\"Third slide\"\u003e\u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt750\/ar300_500x500_1.jpg\" alt=\"Forth slide\"\u003e\u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"col-12 col-md-6 col-lg-6 mt-3 mt-md-0\"\u003e\n                        \u003ch2\u003eGL-MT750\u003c\/h2\u003e\n\u003cstrong\u003eThis item is discontinued.\u003c\/strong\u003e\n                        \u003cul\u003e\n                            \u003cli\u003ePowered by MTK 7620A + MT7610E\u003c\/li\u003e\n                            \u003cli\u003e2.4G + 5G dual radio\u003c\/li\u003e\n                            \u003cli\u003e750Mbps high speed, 802.11ac\u003c\/li\u003e\n                            \u003cli\u003eLarge RAM up to 128M\u003c\/li\u003e\n                            \u003cli\u003eOpenWrt pre-installed\u003c\/li\u003e\n                            \u003cli\u003eIO ports reserved for function extending\u003c\/li\u003e\n                            \u003cli\u003eOptional PoE support\u003c\/li\u003e\n                        \u003c\/ul\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n            \u003cdiv class=\"tab-pane fade\" id=\"specs\" role=\"tabpanel\" aria-labelledby=\"specs-tab\"\u003e\n                \u003ctable class=\"table table-bordered mt-4\"\u003e\n                    \u003ctbody\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eCPU\u003c\/td\u003e\n                            \u003ctd\u003eMTK 7620A @580Mhz\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eMemory\/Storage\u003c\/td\u003e\n                            \u003ctd\u003eDDR2 128MB\/ FLASH 16MB\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eInterfaces\u003c\/td\u003e\n                            \u003ctd\u003e1 WAN, 4 LAN, 1 USB2.0, 1 Reset button, 1TF card, 1DC in(12V)\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eFrequency\u003c\/td\u003e\n                            \u003ctd\u003e2.4GHz\/5.8GHz\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eTransmission rate\u003c\/td\u003e\n                            \u003ctd\u003e750Mbps\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eWAN\/LAN\u003c\/td\u003e\n                            \u003ctd\u003e10\/100Mbps\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eMax Tx Power\u003c\/td\u003e\n                            \u003ctd\u003e20dBm\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eProtocol\u003c\/td\u003e\n                            \u003ctd\u003e802.11 ac\/a\/b\/g\/n\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eExternal Storage support\u003c\/td\u003e\n                            \u003ctd\u003eFAT32\/EXFAT\/EXT4\/EXT3\/EXT2\/NTFS\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eWebcam support\u003c\/td\u003e\n                            \u003ctd\u003eMJPG, YUV\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eDIY features\u003c\/td\u003e\n                            \u003ctd\u003eUART, 4GPIO, 3.3V \u0026amp; 5V power port\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eExternal antenna support\u003c\/td\u003e\n                            \u003ctd\u003e2 dual-band antenna\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003ePoE support\u003c\/td\u003e\n                            \u003ctd\u003eYes, optional\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003ePower input\u003c\/td\u003e\n                            \u003ctd\u003e12V\/1A\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003ePower consumption\u003c\/td\u003e\n                            \u003ctd\u003e\u0026lt;10W\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                        \u003ctr\u003e\n                            \u003ctd\u003eDimension, Weight\u003c\/td\u003e\n                            \u003ctd\u003e170*150*38mm, 250g\u003c\/td\u003e\n                        \u003c\/tr\u003e\n                    \u003c\/tbody\u003e\n                \u003c\/table\u003e\n            \u003c\/div\u003e\n            \u003c!-- \u003cdiv class=\"tab-pane fade\" id=\"download\" role=\"tabpanel\" aria-labelledby=\"download-tab\"\u003e\n                \u003cdiv class=\"mt-4\"\u003e\n                    \u003cp\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt750\/\" target=\"_blank\"\u003eFirmware Download\u003c\/a\u003e\u003c\/p\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e --\u003e\n        \u003c\/div\u003e\n    \u003c\/section\u003e\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"Default Title","offer_id":46291768934583,"sku":null,"price":0.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/product-list_mt750.webp?v=1770177380","url":"https:\/\/www.gl-inet.com\/products\/gl-mt750","provider":"GL.iNet","version":"1.0","type":"link"}
