{"product_id":"gl-mt300n","title":"GL-MT300N","description":"\u003cmain class=\"products-main-container container\"\u003e\n\u003csection class=\"container mb-4\"\u003e\u003cimg class=\"img-fluid\" alt=\"gl-inet products GL-MT300N\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/pic_mango.jpg\"\u003e\u003c\/section\u003e\n\u003csection class=\"container mb-4\"\u003e\n\u003cul role=\"tablist\" id=\"productsTab\" class=\"nav nav-tabs\"\u003e\n\u003cli class=\"nav-item\"\u003e\u003ca aria-selected=\"true\" aria-controls=\"introduction\" role=\"tab\" href=\"#introduction\" data-toggle=\"tab\" id=\"introduction-tab\" class=\"nav-link active\"\u003eIntroduction\u003c\/a\u003e\u003c\/li\u003e\n\u003cli class=\"nav-item\"\u003e\u003ca aria-selected=\"false\" aria-controls=\"specs\" role=\"tab\" href=\"#specs\" data-toggle=\"tab\" id=\"specs-tab\" class=\"nav-link\"\u003eSpecs\u003c\/a\u003e\u003c\/li\u003e\n\u003cli class=\"nav-item\"\u003e\u003ca aria-selected=\"false\" aria-controls=\"download\" role=\"tab\" href=\"#download\" data-toggle=\"tab\" id=\"download-tab\" class=\"nav-link\"\u003eDownload\u003c\/a\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cdiv id=\"productsTabContent\" class=\"tab-content\"\u003e\n\u003cdiv aria-labelledby=\"introduction-tab\" role=\"tabpanel\" id=\"introduction\" class=\"tab-pane fade show active\"\u003e\n\u003cdiv class=\"row mt-4\"\u003e\n\u003cdiv data-ride=\"carousel\" class=\"carousel slide col-12 col-md-6 col-lg-6\"\u003e\n\u003cdiv class=\"carousel-inner\"\u003e\n\u003cdiv class=\"carousel-item active\"\u003e\u003cimg alt=\"First slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mango_500x500_3.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"carousel-item\"\u003e\u003cimg alt=\"Second slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mango_500x500_0.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"carousel-item\"\u003e\u003cimg alt=\"Third slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mango_500x500_2.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"carousel-item\"\u003e\u003cimg alt=\"Forth slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mango_500x500_1.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"carousel-item\"\u003e\u003cimg alt=\"Fifth slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mt300n-small-e1446017878499.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003cdiv class=\"carousel-item\"\u003e\u003cimg alt=\"Sixth slide\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300n\/mt300n-pcb-marking.jpg\" class=\"d-block w-100\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"col-12 col-md-6 col-lg-6 mt-3 mt-md-0\"\u003e\n\u003ch2\u003eGL-MT300N\u003c\/h2\u003e\n\u003cul\u003e\n\u003cli\u003ePowered by MTK 7620N 580Mhz SoC\u003c\/li\u003e\n\u003cli\u003e300Mbps high speed\u003c\/li\u003e\n\u003cli\u003eSmall, light, easy to use\u003c\/li\u003e\n\u003cli\u003eOpenWrt pre-installed\u003c\/li\u003e\n\u003cli\u003eIO ports reserved for function extending\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv aria-labelledby=\"specs-tab\" role=\"tabpanel\" id=\"specs\" class=\"tab-pane fade\"\u003e\n\u003ctable class=\"table table-bordered mt-4\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eCPU\u003c\/td\u003e\n\u003ctd\u003eMTK 7620N @580Mhz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMemory\/Storage\u003c\/td\u003e\n\u003ctd\u003eDDR1 64MB\/ FLASH 16MB\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInterfaces\u003c\/td\u003e\n\u003ctd\u003e1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency\u003c\/td\u003e\n\u003ctd\u003e2.4GHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTransmission rate\u003c\/td\u003e\n\u003ctd\u003e300Mbps\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMax Tx Power\u003c\/td\u003e\n\u003ctd\u003e20dBm\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eProtocol\u003c\/td\u003e\n\u003ctd\u003eIEEE 802.11b\/g\/n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eExternal Storage support\u003c\/td\u003e\n\u003ctd\u003eFAT32\/EXFAT\/EXT4\/EXT3\/EXT2\/NTFS\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWebcam support\u003c\/td\u003e\n\u003ctd\u003eMJPG, YUV\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDIY features\u003c\/td\u003e\n\u003ctd\u003eUART, 4GPIO, 3.3V \u0026amp; 5V power port\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eExternal antenna support\u003c\/td\u003e\n\u003ctd\u003eYes (Optional)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePoE support\u003c\/td\u003e\n\u003ctd\u003eYes (Optional)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower input\u003c\/td\u003e\n\u003ctd\u003e5V\/1A\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003ePower consumption\u003c\/td\u003e\n\u003ctd\u003e\u0026lt;2W\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDimension, Weight\u003c\/td\u003e\n\u003ctd\u003e58*58*25mm, 39g\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003c\/div\u003e\n\u003cdiv aria-labelledby=\"download-tab\" role=\"tabpanel\" id=\"download\" class=\"tab-pane fade\"\u003e\n\u003cdiv class=\"mt-4\"\u003e\n\u003cp\u003e\u003ca href=\"https:\/\/docs.gl-inet.com\/router\/en\/2\/hardware\/mt300n\/\" target=\"_blank\"\u003eGL-MT300N Docs\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003eFirmware and User Guide can be download blow:\u003c\/p\u003e\n\u003cdiv class=\"table-responsive\"\u003e\n\u003ctable class=\"table table-bordered mt-4\"\u003e\n\u003cthead\u003e\n\u003ctr\u003e\n\u003cth\u003eRouter Model\u003c\/th\u003e\n\u003cth\u003eDefault Release\u003c\/th\u003e\n\u003cth\u003ePre-release\u003c\/th\u003e\n\u003cth\u003eOpenWrt Only\u003c\/th\u003e\n\u003cth\u003eTor\u003c\/th\u003e\n\u003cth\u003eUser Guide\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003c\/thead\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eGL-MT300N\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300n\/v1\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300n\/testing\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300n\/clean\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300n\/tor\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/static.gl-inet.com\/www\/uploads\/2017\/07\/minirouter_user-guide_MT300N_20170628.pdf\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003c\/div\u003e\n\u003cp\u003eThe \"Default Release\" is recommended for most users.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"Default Title","offer_id":45506652438711,"sku":null,"price":0.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/mt300n-v2_38eac275-35ac-40d3-b4b1-157aa4b28acd.png?v=1767948264","url":"https:\/\/www.gl-inet.com\/products\/gl-mt300n","provider":"GL.iNet","version":"1.0","type":"link"}
