{"product_id":"gl-mt300a","title":"GL-MT300A","description":"\u003cmain class=\"products-main-container container\"\u003e\n    \u003csection class=\"container mb-4\"\u003e\n        \u003cimg src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/pic_Azure2.jpg\" alt=\"gl-inet products GL-MT300A\" class=\"img-fluid\"\u003e\n    \u003c\/section\u003e\n\n    \u003csection class=\"container\"\u003e\n        \u003cul class=\"nav nav-tabs\" id=\"productsTab\" role=\"tablist\"\u003e\n            \u003cli class=\"nav-item\"\u003e\n                \u003ca class=\"nav-link active\" id=\"introduction-tab\" data-toggle=\"tab\" href=\"#introduction\" role=\"tab\" aria-controls=\"introduction\" aria-selected=\"true\"\u003eIntroduction\u003c\/a\u003e\n            \u003c\/li\u003e\n            \u003cli class=\"nav-item\"\u003e\n                \u003ca class=\"nav-link\" id=\"specs-tab\" data-toggle=\"tab\" href=\"#specs\" role=\"tab\" aria-controls=\"specs\" aria-selected=\"false\"\u003eSpecs\u003c\/a\u003e\n            \u003c\/li\u003e\n            \u003cli class=\"nav-item\"\u003e\n                \u003ca class=\"nav-link\" id=\"download-tab\" data-toggle=\"tab\" href=\"#download\" role=\"tab\" aria-controls=\"download\" aria-selected=\"false\"\u003eDownload\u003c\/a\u003e\n            \u003c\/li\u003e\n        \u003c\/ul\u003e\n        \u003cdiv class=\"tab-content\" id=\"productsTabContent\"\u003e\n            \u003cdiv class=\"tab-pane fade show active\" id=\"introduction\" role=\"tabpanel\" aria-labelledby=\"introduction-tab\"\u003e\n                \u003cdiv class=\"row mt-4\"\u003e\n                    \u003cdiv class=\"carousel slide col-12 col-md-6 col-lg-6\" data-ride=\"carousel\"\u003e\n                        \u003cdiv class=\"carousel-inner\"\u003e\n                            \u003cdiv class=\"carousel-item active\"\u003e\n                                \u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/azure_500x500_2-1.jpg\" alt=\"First slide\"\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\n                                \u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/azure_500x500_0-1.jpg\" alt=\"Second slide\"\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\n                                \u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/azure_500x500_internal.jpg\" alt=\"Third slide\"\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\n                                \u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/MT300A-small.jpg\" alt=\"Forth slide\"\u003e\n                            \u003c\/div\u003e\n                            \u003cdiv class=\"carousel-item\"\u003e\n                                \u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt300a\/azure_500x500_3.jpg\" alt=\"Fifth slide\"\u003e\n                            \u003c\/div\u003e\n                        \u003c\/div\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"col-12 col-md-6 col-lg-6 mt-3 mt-md-0\"\u003e\n                        \u003ch2\u003eGL-MT300A\u003c\/h2\u003e\n                        \u003cul\u003e\n                            \u003cli\u003ePowered by MTK 7620A  580Mhz SoC\u003c\/li\u003e\n                            \u003cli\u003e300Mbps high speed\u003c\/li\u003e\n                            \u003cli\u003eLarge RAM, 128MB. Up to 256MB.\u003c\/li\u003e\n                            \u003cli\u003eSmall, light, easy to use\u003c\/li\u003e\n                            \u003cli\u003eOpenWrt pre-installed\u003c\/li\u003e\n                            \u003cli\u003eUART and MicroSD interface, with MicroSD daughter board\u003c\/li\u003e\n                            \u003cli\u003eExternal antenna optional support\u003c\/li\u003e\n                        \u003c\/ul\u003e\n                    \u003c\/div\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n\n            \u003cdiv class=\"tab-pane fade\" id=\"specs\" role=\"tabpanel\" aria-labelledby=\"specs-tab\"\u003e\n                \u003ctable class=\"table table-bordered mt-4\"\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eCPU\u003c\/td\u003e\n                        \u003ctd\u003eMTK 7620A @580Mhz\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eMemory\/Storage\u003c\/td\u003e\n                        \u003ctd\u003eDDRII 128MB\/ FLASH 16MB\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eInterfaces\u003c\/td\u003e\n                        \u003ctd\u003e1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eFrequency\u003c\/td\u003e\n                        \u003ctd\u003e2.4GHz\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eTransmission rate\u003c\/td\u003e\n                        \u003ctd\u003e300Mbps\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eMax Tx Power\u003c\/td\u003e\n                        \u003ctd\u003e20dBm\u003c\/td\u003e\n                    \n                    \u003c\/tr\u003e\n\u003ctr\u003e\n                        \u003ctd\u003eProtocol\u003c\/td\u003e\n                        \u003ctd\u003eIEEE 802.11b\/g\/n\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eExternal Storage support\u003c\/td\u003e\n                        \u003ctd\u003eFAT32\/EXFAT\/EXT4\/EXT3\/EXT2\/NTFS\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eWebcam support\u003c\/td\u003e\n                        \u003ctd\u003eMJPG, YUV\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eDIY features\u003c\/td\u003e\n                        \u003ctd\u003eUART, TF Card interface, 3.3V \u0026amp; 5V power port\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eExternal antenna support\u003c\/td\u003e\n                        \u003ctd\u003eYes\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003ePoE support\u003c\/td\u003e\n                        \u003ctd\u003eNo\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003ePower input\u003c\/td\u003e\n                        \u003ctd\u003e5V\/1A\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003ePower consumption\u003c\/td\u003e\n                        \u003ctd\u003e\u0026lt;2W\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                    \u003ctr\u003e\n                        \u003ctd\u003eDimension, Weight\u003c\/td\u003e\n                        \u003ctd\u003e58*58*25mm, 39g\u003c\/td\u003e\n                    \u003c\/tr\u003e\n                \u003c\/table\u003e\n            \u003c\/div\u003e\n\n            \u003cdiv class=\"tab-pane fade\" id=\"download\" role=\"tabpanel\" aria-labelledby=\"download-tab\"\u003e\n                \u003cdiv class=\"mt-4\"\u003e\n                    \u003cp\u003e\n                        \u003ca href=\"https:\/\/docs.gl-inet.com\/router\/en\/2\/hardware\/mt300a\/\" target=\"_blank\"\u003eGL-MT300A Docs\u003c\/a\u003e\n                    \u003c\/p\u003e\n                    \u003cp\u003eFirmware and User Guide can be download blow:\u003c\/p\u003e\n                    \u003cdiv class=\"table-responsive\"\u003e\n                        \u003ctable class=\"table table-bordered mt-4\"\u003e\n                            \u003cthead\u003e\n                                \u003ctr\u003e\n                                    \u003cth\u003eRouter Model\u003c\/th\u003e\n                                    \u003cth\u003eDefault Release\u003c\/th\u003e\n                                    \u003cth\u003ePre-release\u003c\/th\u003e\n                                    \u003cth\u003eOpenWrt Only\u003c\/th\u003e\n                                    \u003cth\u003eTor\u003c\/th\u003e\n                                    \u003cth\u003eUser Guide\u003c\/th\u003e\n                                \u003c\/tr\u003e\n                            \u003c\/thead\u003e\n                            \u003ctr\u003e\n                                \u003ctd\u003eGL-MT300A\u003cbr\u003eGL-MT300A-Ext\u003c\/td\u003e\n                                \u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300a\/v1\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n                                \u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300a\/testing\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n                                \u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300a\/clean\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n                                \u003ctd\u003e\u003ca href=\"https:\/\/dl.gl-inet.com\/firmware\/mt300a\/tor\/\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n                                \u003ctd\u003e\u003ca href=\"https:\/\/static.gl-inet.com\/www\/uploads\/2017\/07\/minirouter_user-guide_MT300A_20170628-1.pdf\" target=\"_blank\"\u003eDownload\u003c\/a\u003e\u003c\/td\u003e\n                            \u003c\/tr\u003e\n                        \u003c\/table\u003e\n                    \u003c\/div\u003e\n                    \u003cp\u003eThe \"Default Release\" is recommended for most users.\u003c\/p\u003e\n                \u003c\/div\u003e\n            \u003c\/div\u003e\n        \u003c\/div\u003e\n    \u003c\/section\u003e\n\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"Default Title","offer_id":45506653290679,"sku":null,"price":0.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/minirouter-mt300a.png?v=1774431806","url":"https:\/\/www.gl-inet.com\/products\/gl-mt300a","provider":"GL.iNet","version":"1.0","type":"link"}
