{"product_id":"gl-m9531","title":"GL-M9531","description":"\u003cstyle\u003e\n  .products-main-container .nav-link {\n    color: grey;\n  }\n\n  .products-main-container .nav-link.active {\n    color: #43c8cf;\n  }\n\u003c\/style\u003e\n\u003cmain class=\"products-main-container\"\u003e\n  \u003cnav aria-label=\"breadcrumb\" class=\"container\"\u003e\n    \u003col class=\"breadcrumb bg-white\"\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/\"\u003eHome\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/products\"\u003eProducts\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/pages\/discontinued\/\"\u003eDiscontinued\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item active\" aria-current=\"page\"\u003eGL-M9531\u003c\/li\u003e\n    \u003c\/ol\u003e\n  \u003c\/nav\u003e\n  \u003csection class=\"container\"\u003e\n    \u003cdiv class=\"row\"\u003e\n      \u003cdiv class=\"col-12 col-md-6 col-lg-6\"\u003e\u003cimg src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-m9531\/DSC_2024.jpg\" alt=\"gl-inet products GL-M9531\" class=\"img-fluid\"\u003e\u003c\/div\u003e\n      \u003cdiv class=\"col-12 col-md-6 col-lg-6 mt-3 mt-md-0\"\u003e\n        \u003ch2\u003eHigh power Atheros Wi-Fi module\u003c\/h2\u003e\n        \u003cstrong\u003eThis item is discontinued.\u003c\/strong\u003e\n        \u003cul\u003e\n          \u003cli\u003ePowered by Atheros 9531\u003c\/li\u003e\n          \u003cli\u003eStrong signal max 29dBm output\u003c\/li\u003e\n          \u003cli\u003e300Mbps 802.11b\/g\/n\u003c\/li\u003e\n          \u003cli\u003ePCIe Interfaces\u003c\/li\u003e\n          \u003cli\u003e1.27 mm headers\u003c\/li\u003e\n        \u003c\/ul\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003csection class=\"container\"\u003e\n    \u003cul class=\"nav nav-tabs\" id=\"productsTab\" role=\"tablist\"\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link active\" id=\"introduction-tab\" data-toggle=\"tab\" href=\"#introduction\" role=\"tab\" aria-controls=\"introduction\" aria-selected=\"true\"\u003eIntroduction\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"specs-tab\" data-toggle=\"tab\" href=\"#specs\" role=\"tab\" aria-controls=\"specs\" aria-selected=\"false\"\u003eSpecs\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"download-tab\" data-toggle=\"tab\" href=\"#download\" role=\"tab\" aria-controls=\"download\" aria-selected=\"false\"\u003eDownload\u003c\/a\u003e\u003c\/li\u003e\n    \u003c\/ul\u003e\n    \u003cdiv class=\"tab-content\" id=\"productsTabContent\"\u003e\n      \u003cdiv class=\"tab-pane fade show active\" id=\"introduction\" role=\"tabpanel\" aria-labelledby=\"introduction-tab\"\u003e\n        \u003cdiv class=\"row mt-4\"\u003e\n          \u003cdiv class=\"carousel slide col-12 col-md-10 col-lg-10\" data-ride=\"carousel\"\u003e\n            \u003cp\u003eGL-M9531 high power Wi-Fi module that can be used in Wi-Fi routers and IoT devices, providing 29dmb\n              output.\u003c\/p\u003e\n            \u003cdiv class=\"carousel-inner\"\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-m9531\/pinout-1024x768.jpg\" alt=\"First slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-m9531\/DSC_2017.jpg\" alt=\"Second slide\"\u003e\u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-m9531\/DSC_2018.jpg\" alt=\"Third slide\"\u003e\u003c\/div\u003e\n              \u003cdiv class=\"carousel-item active\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-m9531\/DSC_2023.jpg\" alt=\"Forth slide\"\u003e\u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"tab-pane fade\" id=\"specs\" role=\"tabpanel\" aria-labelledby=\"specs-tab\"\u003e\n        \u003ctable class=\"table table-bordered mt-4\"\u003e\n          \u003ctbody\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eCPU\u003c\/td\u003e\n              \u003ctd\u003eAtheros 9531, @650MHz\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eMemory\/Storage\u003c\/td\u003e\n              \u003ctd\u003eDDR 128MB\/ FLASH 16MB\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eInterfaces\u003c\/td\u003e\n              \u003ctd\u003e1 WAN\/LAN, 1 USB, I2C, UART, GPIO, LED, RESET, PCIe\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eMax Tx Power\u003c\/td\u003e\n              \u003ctd\u003e29dBm\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eProtocol\u003c\/td\u003e\n              \u003ctd\u003eIEEE 802.11b\/g\/n\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eWAN\/LAN\u003c\/td\u003e\n              \u003ctd\u003e10\/100Mbps\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eTransmission rate\u003c\/td\u003e\n              \u003ctd\u003e300Mbps\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eAntenna\u003c\/td\u003e\n              \u003ctd\u003eIPEX interface External Antenna\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003ePower input\u003c\/td\u003e\n              \u003ctd\u003e5V\/2A\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003ePower consumption\u003c\/td\u003e\n              \u003ctd\u003e≤ 8W\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eDimension, Weight\u003c\/td\u003e\n              \u003ctd\u003e45*35*12mm, 20g\u003c\/td\u003e\n            \u003c\/tr\u003e\n          \u003c\/tbody\u003e\n        \u003c\/table\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"tab-pane fade\" id=\"download\" role=\"tabpanel\" aria-labelledby=\"download-tab\"\u003e\n        \u003cdiv class=\"mt-4\"\u003e\n          \u003cp\u003eNo download yet.\u003c\/p\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"Default Title","offer_id":46290777735351,"sku":null,"price":0.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/product-list_m9531.webp?v=1770172521","url":"https:\/\/www.gl-inet.com\/products\/gl-m9531","provider":"GL.iNet","version":"1.0","type":"link"}
