{"product_id":"gl-inet6416","title":"GL.iNet6416","description":"\u003cstyle\u003e\n  .products-main-container .nav-link {\n    color: grey;\n  }\n\n  .products-main-container .nav-link.active {\n    color: #43c8cf;\n  }\n\u003c\/style\u003e\n\u003cmain class=\"products-main-container\"\u003e\n  \u003cnav aria-label=\"breadcrumb\" class=\"container\"\u003e\n    \u003col class=\"breadcrumb bg-white\"\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/\"\u003eHome\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/products\"\u003eProducts\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item\"\u003e\u003ca href=\"\/pages\/discontinued\/\"\u003eDiscontinued\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"breadcrumb-item active\" aria-current=\"page\"\u003eGL.iNet6416\u003c\/li\u003e\n    \u003c\/ol\u003e\n  \u003c\/nav\u003e\n  \u003csection class=\"container mb-4\"\u003e\u003cimg src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_1920x775.jpg\" alt=\"gl-inet products GL.iNet6416\" class=\"img-fluid\"\u003e\u003c\/section\u003e\n  \u003csection class=\"container\"\u003e\n    \u003cul class=\"nav nav-tabs\" id=\"productsTab\" role=\"tablist\"\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link active\" id=\"introduction-tab\" data-toggle=\"tab\" href=\"#introduction\" role=\"tab\" aria-controls=\"introduction\" aria-selected=\"true\"\u003eIntroduction\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"specs-tab\" data-toggle=\"tab\" href=\"#specs\" role=\"tab\" aria-controls=\"specs\" aria-selected=\"false\"\u003eSpecs\u003c\/a\u003e\u003c\/li\u003e\n      \u003cli class=\"nav-item\"\u003e\u003ca class=\"nav-link\" id=\"download-tab\" data-toggle=\"tab\" href=\"#download\" role=\"tab\" aria-controls=\"download\" aria-selected=\"false\"\u003eDownload\u003c\/a\u003e\u003c\/li\u003e\n    \u003c\/ul\u003e\n    \u003cdiv class=\"tab-content\" id=\"productsTabContent\"\u003e\n      \u003cdiv class=\"tab-pane fade show active\" id=\"introduction\" role=\"tabpanel\" aria-labelledby=\"introduction-tab\"\u003e\n        \u003cdiv class=\"row mt-4\"\u003e\n          \u003cdiv class=\"carousel slide col-12 col-md-6 col-lg-6\" data-ride=\"carousel\"\u003e\n            \u003cdiv class=\"carousel-inner\"\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_6.jpg\" alt=\"First slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_0.jpg\" alt=\"Second slide\"\u003e\u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_1.jpg\" alt=\"Third slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_2.jpg\" alt=\"Forth slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_4.jpg\" alt=\"Fifth slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item active\"\u003e\n\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/6416_500x500_5.jpg\" alt=\"Sixth slide\"\u003e\n              \u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/GLiNet_15_1200_tech-blog.jpg\" alt=\"Seventh slide\"\u003e\u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/GLiNet_09_1200_tech-blog.jpg\" alt=\"Eighth slide\"\u003e\u003c\/div\u003e\n              \u003cdiv class=\"carousel-item\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl.inet6416\/GLiNet_12_1200_tech-blog.jpg\" alt=\"Ninth slide\"\u003e\u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"col-12 col-md-6 col-lg-6 mt-3 mt-md-0\"\u003e\n            \u003ch2\u003eGL.iNet 6416\u003c\/h2\u003e\n\u003cstrong\u003eThis item is discontinued.\u003c\/strong\u003e\n            \u003cul\u003e\n              \u003cli\u003ePowered by Atheros AR9331\u003c\/li\u003e\n              \u003cli\u003eStable\u003c\/li\u003e\n              \u003cli\u003eLow cost\u003c\/li\u003e\n              \u003cli\u003eGPIO, UART\u003c\/li\u003e\n            \u003c\/ul\u003e\n            \u003cp\u003eGL.iNet 6416 is our first mini starter router designed for OpenWrt and DIY hobbyists. It provides stable\n              performance with affordable price.\u003c\/p\u003e\n            \u003cp\u003eIn hardware, it provides 5 GPIOs in 2.0mm distance, UART, 3.3V Power, 1 USB-A adapter, one Reset button.\n              It is powered by any USB power adapter which can provide 5V 1A.\u003c\/p\u003e\n            \u003cp\u003eIn software, it comes with OpenWrt BB 1407 firmware. And GL.iNet target has emerged in OpenWrt trunk and\n              you can have the newest OpenWrt release easily. We provide a beautiful and easy-to-use WebUI built on top\n              of the original OpenWrt Luci interface. USB storage auto mounting, files sharing, offline download and\n              video streaming has been built inside of the default firmware. Save your time to configure your OpenWrt.\n            \u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"tab-pane fade\" id=\"specs\" role=\"tabpanel\" aria-labelledby=\"specs-tab\"\u003e\n        \u003ctable class=\"table table-bordered mt-4\"\u003e\n          \u003ctbody\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eCPU\u003c\/td\u003e\n              \u003ctd\u003eQualcomm Atheros 9331, @400MHz\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eMemory\/Storage\u003c\/td\u003e\n              \u003ctd\u003eDDR1 64MB\/ FLASH 16MB\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eInterfaces\u003c\/td\u003e\n              \u003ctd\u003e1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eFrequency\u003c\/td\u003e\n              \u003ctd\u003e2.4GHz\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eTransmission rate\u003c\/td\u003e\n              \u003ctd\u003e150Mbps\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eMax Tx Power\u003c\/td\u003e\n              \u003ctd\u003e18dBm\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eProtocol\u003c\/td\u003e\n              \u003ctd\u003eIEEE 802.11b\/g\/n\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eExternal Storage support\u003c\/td\u003e\n              \u003ctd\u003eFAT32\/EXFAT\/EXT4\/EXT3\/EXT2\/NTFS\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eWebcam support\u003c\/td\u003e\n              \u003ctd\u003eMJPG, YUV\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eDIY features\u003c\/td\u003e\n              \u003ctd\u003eUART, 5GPIO, 3.3V \u0026amp; 5V power port\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eExternal antenna support\u003c\/td\u003e\n              \u003ctd\u003eNo\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003ePoE support\u003c\/td\u003e\n              \u003ctd\u003eNo\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003ePower input\u003c\/td\u003e\n              \u003ctd\u003e5V\/1A\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003ePower consumption\u003c\/td\u003e\n              \u003ctd\u003e\u0026lt;1W\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eDimension, Weight\u003c\/td\u003e\n              \u003ctd\u003e58*58*22mm, 43g\u003c\/td\u003e\n            \u003c\/tr\u003e\n          \u003c\/tbody\u003e\n        \u003c\/table\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"tab-pane fade\" id=\"download\" role=\"tabpanel\" aria-labelledby=\"download-tab\"\u003e\n        \u003cdiv class=\"mt-4\"\u003e\n          \u003cp\u003e\u003ca href=\"https:\/\/docs.gl-inet.com\/router\/en\/2\/hardware\/6416\/\" target=\"_blank\"\u003eGL-iNet6416 Docs\u003c\/a\u003e\u003c\/p\u003e\n          \u003c!-- \u003cp\u003e\u003ca href=\"#\" data-href=\"https:\/\/dl.gl-inet.com\/firmware\/6416\/\"\u003eFirmware download\u003c\/a\u003e\u003c\/p\u003e --\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"Default Title","offer_id":46290780848311,"sku":null,"price":0.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/product-list_glinet-6416.webp?v=1770172536","url":"https:\/\/www.gl-inet.com\/products\/gl-inet6416","provider":"GL.iNet","version":"1.0","type":"link"}
