{"product_id":"gl-be10000","title":"Slate 7 Pro (GL-BE10000) Tri-band Wi-Fi 7 Travel Router","description":"\u003cstyle\u003e\n  \/* select-language-button 基础样式 *\/\n  .select-language-button {\n    position: fixed;\n    right: 0;\n    z-index: 9995;\n    top: 50%;\n  }\n\n  .select-language-button .select-language-container {\n    position: relative;\n    transform: rotate(-90deg);\n    transform-origin: 83% 0;\n    will-change: transform;\n  }\n\n  \/* 容器在小屏幕下的 transform-origin 调整 *\/\n  @media (max-width: 1023px) {\n    .select-language-button .select-language-container {\n      transform-origin: 84% 0;\n    }\n  }\n\n  \/* 语言列表基础样式（初始隐藏） *\/\n  .select-language-button .select-language-list {\n    position: absolute;\n    left: 0;\n    padding: 0;\n    margin: 0;\n    background: #fff;\n    box-shadow: 0 0 4px 0 rgba(0, 0, 0, 0.2);\n    border-radius: 5px;\n    transform: rotate(90deg) translateX(50px);\n    top: -202px;\n    will-change: transform;\n    opacity: 0;\n    transition: opacity 0.3s ease-in-out, transform 0.2s ease-in-out;\n    z-index: 2;\n    width: 0;\n    overflow: hidden;\n  }\n\n  @media (max-width: 1023px) {\n    .select-language-button .select-language-list {\n      top: -139px;\n    }\n  }\n\n  \/* 列表中的链接样式 *\/\n  .select-language-button .select-language-list a {\n    display: block;\n    color: #000;\n    white-space: nowrap;\n    padding: 8px 40px 8px 18px;\n  }\n\n  @media (max-width: 1023px) {\n    .select-language-button .select-language-list a {\n      font-size: 12px;\n      padding: 5px;\n    }\n  }\n\n  .select-language-button .select-language-list a:hover {\n    color: #2fb5b8;\n  }\n\n  \/* 悬停按钮时显示列表 *\/\n  .select-language-button:hover .select-language-list {\n    transform: rotate(90deg) translateX(0px);\n    opacity: 1;\n    width: auto;\n  }\n\n  \/* 默认选中的语言显示区域 *\/\n  .select-language-button .default {\n    cursor: pointer;\n    position: relative;\n    z-index: 3;\n  }\n\n  .select-language-button .default span {\n    display: inline-block;\n    border-radius: 10px 10px 0 0;\n    background-color: #2fb5b8;\n    color: #001525;\n    padding: 4px 15px;\n    font-weight: 600;\n    white-space: nowrap;\n    font-size: 15px;\n  }\n\n  @media (max-width: 1023px) {\n    .select-language-button .default span {\n      font-size: 12px;\n    }\n  }\n\n  \/* --- 第一部分：Tiny Slider 基础容器 --- *\/\n  .tiny-slider-container-general-1122 {\n    position: relative;\n    padding: 0 0;\n    overflow: hidden;\n  }\n\n  .tiny-slider-container-general-1122 .tiny-slider-general-1122 {\n    display: flex;\n    flex-wrap: wrap;\n  }\n\n  .tiny-slider-container-general-1122 .tiny-slider-general-1122 .tiny-slider-item-general-1122 {\n    vertical-align: middle;\n    display: inline-flex;\n  }\n\n  \/* --- 第二部分：共享的主容器样式 (.e5800 和 .be10000) --- *\/\n\n  .e5800-main-container .scenarios-slider-container,\n  .be10000-main-container .scenarios-slider-container {\n    width: 100%;\n    flex-wrap: wrap;\n  }\n\n  @media (max-width: 1440px) {\n\n    .e5800-main-container .scenarios-slider-container,\n    .be10000-main-container .scenarios-slider-container {\n      width: 100%;\n    }\n  }\n\n  .e5800-main-container .scenarios-slider-container .container .tns-ovh,\n  .be10000-main-container .scenarios-slider-container .container .tns-ovh {\n    overflow: visible;\n  }\n\n  .e5800-main-container .scenarios-slider-container .scenarios-slider,\n  .be10000-main-container .scenarios-slider-container .scenarios-slider {\n    overflow-x: hidden;\n    padding: 0 calc(50% - 720px) 0;\n  }\n\n  .e5800-main-container .scenarios-slider-container .scenarios-slider label,\n  .be10000-main-container .scenarios-slider-container .scenarios-slider label {\n    display: inline-block;\n    font-size: 1.25rem;\n    font-weight: bold;\n    color: #FFFFFF;\n    padding: 0.25rem 0.75rem 0.5rem;\n    margin-bottom: -5px;\n  }\n\n  @media (max-width: 1199px) {\n\n    .e5800-main-container .scenarios-slider-container .scenarios-slider label,\n    .be10000-main-container .scenarios-slider-container .scenarios-slider label {\n      font-size: 1rem;\n    }\n  }\n\n  .e5800-main-container .scenarios-slider-container .scenarios-slider figure,\n  .be10000-main-container .scenarios-slider-container .scenarios-slider figure {\n    display: flex;\n    width: 100%;\n    margin: 0;\n    padding: 0 0.75rem;\n  }\n\n  @media (max-width: 768px) {\n\n    .e5800-main-container .scenarios-slider-container .scenarios-slider figure,\n    .be10000-main-container .scenarios-slider-container .scenarios-slider figure {\n      padding: 0 0.5rem;\n    }\n  }\n\n  .e5800-main-container .scenarios-slider-container .scenarios-slider figure .figure-content,\n  .be10000-main-container .scenarios-slider-container .scenarios-slider figure .figure-content {\n    aspect-ratio: 4 \/ 3;\n    background-size: cover;\n    background-position: center;\n    display: flex;\n    flex-wrap: wrap;\n    align-content: flex-end;\n  }\n\n  @media (max-width: 576px) {\n\n    .e5800-main-container .scenarios-slider-container .scenarios-slider figure .figure-content,\n    .be10000-main-container .scenarios-slider-container .scenarios-slider figure .figure-content {\n      aspect-ratio: 4 \/ 4;\n    }\n  }\n\n  .e5800-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3,\n  .be10000-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3 {\n    color: #FFFFFF;\n    width: 70%;\n    padding-bottom: 3rem;\n  }\n\n  @media (max-width: 991px) {\n\n    .e5800-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3,\n    .be10000-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3 {\n      width: 80%;\n      padding-bottom: 2rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n\n    .e5800-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3,\n    .be10000-main-container .scenarios-slider-container .scenarios-slider figure .figure-content h3 {\n      width: 95%;\n      padding-bottom: 1rem;\n      font-size: 1.2rem;\n    }\n  }\n\n  \/* 控制按钮悬停样式 *\/\n  .e5800-main-container .tiny-slider-general-1122-controls.circle-controls a:hover,\n  .be10000-main-container .tiny-slider-general-1122-controls.circle-controls a:hover {\n    background-color: #f7f7f7;\n    border-color: #f7f7f7;\n    color: #212529;\n  }\n\n  \/* 基础容器布局 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review {\n    display: flex;\n    flex-wrap: wrap;\n  }\n\n  \/* 轮播单项样式 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review {\n    padding: 0 1rem;\n    vertical-align: middle;\n    display: inline-flex;\n  }\n\n  \/* 轮播单项 - 响应式 *\/\n  @media (max-width: 1440px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review {\n      transform: translateX(0);\n    }\n  }\n\n  @media (max-width: 991px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review {\n      vertical-align: top;\n    }\n  }\n\n  \/* 评论卡片外层 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card {\n    display: flex;\n    height: 100%;\n  }\n\n  \/* 卡片内部行布局 (Bootstrap 或自定义 row) *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row {\n    background-color: #ffffff;\n    margin: 0;\n    align-items: center;\n  }\n\n  @media (max-width: 991px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row {\n      align-items: flex-start;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row {\n      margin-right: 0;\n    }\n  }\n\n  \/* 图片容器 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row .card-image {\n    height: 100%;\n  }\n\n  @media (max-width: 991px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row .card-image {\n      height: auto;\n    }\n  }\n\n  \/* 图片具体样式 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row .card-image img {\n    width: 100%;\n    height: 100%;\n    object-fit: cover;\n    border-radius: 15px 0 0 15px;\n  }\n\n  @media (max-width: 991px) {\n    .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row .card-image img {\n      border-radius: 15px 15px 0 0;\n      width: 100%;\n      height: auto;\n    }\n  }\n\n  \/* 文本内容样式 *\/\n  .tiny-slider-container-beta-tester-review .tiny-slider-beta-tester-review .tiny-slider-item-beta-tester-review .tiny-slider-review-card .row p {\n    font-size: 1.1rem;\n  }\n\n  .be10000-main-container {\n    --be10000: #3C74F5;\n  }\n\n  .be10000-main-container .text-be10000 {\n    color: var(--be10000);\n  }\n\n  .be10000-main-container h2.be10000-h2 {\n    font-size: 3rem;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container h2.be10000-h2 {\n      font-size: 2rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container h2.be10000-h2 {\n      font-size: 1.5rem;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container h2.be10000-h2 {\n      font-size: 1.2rem;\n    }\n  }\n\n  .be10000-main-container .btn-round-be10000 {\n    background-color: var(--be10000);\n    color: #FFF;\n    border-radius: 50px;\n    padding: 1rem 2rem;\n    text-transform: uppercase;\n    font-weight: bold;\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .btn-round-be10000 {\n      min-height: 50px;\n      border-radius: 50px;\n      padding: 12px 2rem;\n      text-transform: uppercase;\n      font-weight: bold;\n    }\n  }\n\n  .be10000-main-container .btn-round-be10000:hover {\n    background-color: #FFF;\n    color: #5b8cd3;\n    border-color: #5b8cd3;\n  }\n\n  .be10000-main-container #mc_embed_shell {\n    display: flex;\n    justify-content: center;\n  }\n\n  .be10000-main-container #mc_embed_shell input {\n    border: medium none;\n    color: gray;\n    font-size: 16px;\n    padding: 8px 25px;\n    width: auto;\n    height: 50px;\n    border-radius: 25px 0px 0px 25px;\n  }\n\n  @media (max-width: 575.98px) {\n    .be10000-main-container #mc_embed_shell input {\n      width: 100%;\n      height: 40px;\n      font-size: 13px;\n    }\n  }\n\n  .be10000-main-container #mc_embed_shell input.email {\n    background: #fff;\n  }\n\n  @media (max-width: 575.98px) {\n    .be10000-main-container #mc_embed_shell input.email {\n      font-size: 13px;\n    }\n  }\n\n  .be10000-main-container #mc_embed_shell input[type=submit] {\n    background-color: var(--be10000);\n  }\n\n  .be10000-main-container #mc_embed_shell input[type=submit]:hover {\n    background-color: #568BFF;\n  }\n\n  .be10000-main-container #mc_embed_shell input[type=submit] {\n    text-align: center;\n    transition: 0.5s;\n    background-size: 200% auto;\n    font-weight: bold;\n    color: white;\n    border-radius: 0 25px 25px 0;\n    display: block;\n    margin: 0;\n  }\n\n  .be10000-main-container #mc_embed_shell #mc-embedded-subscribe-form {\n    width: auto;\n    justify-content: start;\n  }\n\n  @media (max-width: 991.98px) {\n    .be10000-main-container #mc_embed_shell #mc-embedded-subscribe-form {\n      margin: auto;\n      justify-content: center;\n    }\n  }\n\n  .be10000-main-container #mc_embed_shell input[type=submit]:hover {\n    background-position: right center;\n    \/* change the direction of the change here *\/\n    color: #fff;\n    text-decoration: none;\n  }\n\n  .be10000-main-container .top-banner {\n    position: relative;\n    background-color: black;\n    height: 55rem;\n    min-height: 25rem;\n    width: 100%;\n    overflow: hidden;\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .top-banner {\n      height: 35rem;\n      aspect-ratio: 1\/1;\n    }\n  }\n\n  .be10000-main-container .top-banner .overlay {\n    position: absolute;\n    top: 0;\n    left: 0;\n    height: 100%;\n    width: 100%;\n    background: linear-gradient(180deg, rgba(0, 0, 0, 0) 30%, rgba(0, 0, 0, 0.3333333333) 95%);\n    opacity: 1;\n    z-index: 1;\n  }\n\n  .be10000-main-container .top-banner video {\n    position: absolute;\n    top: 50%;\n    left: 50%;\n    min-width: 100%;\n    min-height: 100%;\n    width: auto;\n    height: auto;\n    z-index: 0;\n    -ms-transform: translateX(-50%) translateY(-50%);\n    -moz-transform: translateX(-50%) translateY(-50%);\n    -webkit-transform: translateX(-50%) translateY(-50%);\n    transform: translateX(-50%) translateY(-50%);\n  }\n\n  .be10000-main-container .top-banner .container {\n    position: relative;\n    z-index: 2;\n  }\n\n  .be10000-main-container .grid {\n    display: grid;\n    grid-auto-rows: 6rem;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-main-container .grid {\n      grid-auto-rows: 6rem;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid {\n      grid-auto-rows: 5.5rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid {\n      grid-auto-rows: 4rem;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid {\n      grid-auto-rows: 3.5rem;\n    }\n  }\n\n  .be10000-main-container .grid .grid-item {\n    position: relative;\n    margin: 0.3rem;\n    overflow: hidden;\n    box-shadow: 0px 0px 5px rgba(0, 0, 0, 0.2);\n  }\n\n  .be10000-main-container .grid .grid-cell {\n    position: absolute;\n    transform: translate(-50%, -50%);\n    top: 50%;\n    left: 50%;\n    height: 100%;\n    width: 100%;\n    background: linear-gradient(0deg, #0a2b4d 0%, #277AA5 70%);\n    background-size: cover;\n    background-repeat: no-repeat;\n    background-position: center bottom;\n    padding: 1.25rem 1.5rem 1.5rem;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-main-container .grid .grid-cell {\n      padding: 1rem 1rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .grid-cell {\n      padding: 1rem 0.75rem;\n    }\n  }\n\n  .be10000-main-container .grid .grid-cell h2 {\n    font-size: 1.75rem;\n  }\n\n  @media (max-width: 1280px) {\n    .be10000-main-container .grid .grid-cell h2 {\n      font-size: 1.5rem;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .grid-cell h2 {\n      font-size: 1.25rem;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .grid-cell h2 {\n      font-size: 1.1rem;\n    }\n  }\n\n  @media (max-width: 1280px) {\n    .be10000-main-container .grid .grid-cell h4 {\n      font-size: 1.25rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .grid-cell h4 {\n      font-size: 1rem;\n    }\n  }\n\n  .be10000-main-container .grid .grid-cell p {\n    margin-bottom: 0;\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .grid-cell p {\n      font-size: 0.75rem;\n    }\n  }\n\n  .be10000-main-container .grid .cell-video {\n    position: absolute;\n    width: 100%;\n    height: 100%;\n    top: 0;\n    left: 0;\n    z-index: 1;\n  }\n\n  .be10000-main-container .grid .cell-video video {\n    width: 100%;\n    height: 100%;\n    object-fit: cover;\n  }\n\n  .be10000-main-container .grid .item-1 .grid-cell {\n    z-index: 2;\n    background: transparent;\n    align-content: center;\n    text-align: center;\n  }\n\n  .be10000-main-container .grid .item-1 .grid-cell h3 {\n    text-align: center;\n    font-size: 5rem;\n    text-shadow: 0px 0px 8px #ffffff;\n  }\n\n  @media (max-width: 1400px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 4.8rem;\n    }\n  }\n\n  @media (max-width: 1280px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 4.2rem;\n    }\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 4rem;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 3rem;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 2.75rem;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid .item-1 .grid-cell h3 {\n      font-size: 2.5rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-1 .grid-cell {\n      background-size: 100%;\n      background-position-y: 65%;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .item-1 .grid-cell {\n      background-position-y: 60%;\n    }\n  }\n\n  .be10000-main-container .grid .item-2 .grid-cell {\n    z-index: 2;\n    background: transparent;\n  }\n\n  .be10000-main-container .grid .item-2 .grid-cell p span {\n    font-size: 1.5em;\n  }\n\n  .be10000-main-container .grid .item-3 .grid-cell {\n    background-position-y: 60%;\n  }\n\n  .be10000-main-container .grid .item-4 .grid-cell {\n    background-size: 165%;\n    background-position: 70% 37%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-4 .grid-cell {\n      background-size: 175%;\n      background-position: 70% 30%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid .item-4 .grid-cell {\n      background-position: 76% 18%;\n    }\n  }\n\n  .be10000-main-container .grid .item-5 .grid-cell {\n    background-size: 100%;\n    background-position: 100% 48%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-5 .grid-cell {\n      background-size: 125%;\n      background-position: 90% 40%;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-5 .grid-cell {\n      background-size: 130%;\n      background-position: 90% 50%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid .item-5 .grid-cell {\n      background-size: 160%;\n      background-position: 90% 40%;\n    }\n  }\n\n  .be10000-main-container .grid .item-6 .grid-cell {\n    background-size: 100%;\n    background-position: 100% 55%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-6 .grid-cell {\n      background-size: 125%;\n      background-position: 90% 40%;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-6 .grid-cell {\n      background-size: 130%;\n      background-position: 90% 50%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid .item-6 .grid-cell {\n      background-size: 160%;\n      background-position: 90% 40%;\n    }\n  }\n\n  .be10000-main-container .grid .item-7 .grid-cell {\n    background-size: 123%;\n    background-position: 42% 41%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-7 .grid-cell {\n      background-position: 38% 23%;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-7 .grid-cell {\n      background-position: 38% 30%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-main-container .grid .item-7 .grid-cell {\n      background-size: 140%;\n      background-position: 60% 10%;\n    }\n  }\n\n  .be10000-main-container .grid .item-8 .grid-cell {\n    background-size: 116%;\n    background-position: 100% 32%;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-main-container .grid .item-8 .grid-cell {\n      background-size: 127%;\n      background-position: 71% 34%;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-8 .grid-cell {\n      background-size: 134%;\n      background-position: 71% 32%;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .item-8 .grid-cell {\n      background-size: 143%;\n      background-position: 74% 14%;\n    }\n  }\n\n  .be10000-main-container .grid .item-9 .grid-cell {\n    background-size: 100%;\n    background-position: 100% 48%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-9 .grid-cell {\n      background-size: 130%;\n      background-position: 95% 40%;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-9 .grid-cell {\n      background-size: 130%;\n      background-position: 90% 54%;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .grid .item-9 .grid-cell {\n      background-size: 130%;\n      background-position: 90% 54%;\n    }\n  }\n\n  .be10000-main-container .grid {\n    \/* grid control *\/\n  }\n\n  .be10000-main-container .grid .item-1 {\n    grid-area: 1\/1\/span 4\/span 3;\n  }\n\n  .be10000-main-container .grid .item-2 {\n    grid-area: 3\/4\/span 4\/span 3;\n  }\n\n  .be10000-main-container .grid .item-3 {\n    grid-area: 1\/7\/span 4\/span 3;\n  }\n\n  .be10000-main-container .grid .item-4 {\n    grid-area: 1\/4\/span 2\/span 3;\n  }\n\n  .be10000-main-container .grid .item-5 {\n    grid-area: 1\/10\/span 2\/span 3;\n  }\n\n  .be10000-main-container .grid .item-6 {\n    grid-area: 3\/10\/span 2\/span 3;\n  }\n\n  .be10000-main-container .grid .item-7 {\n    grid-area: 5\/1\/span 2\/span 3;\n  }\n\n  .be10000-main-container .grid .item-8 {\n    grid-area: 5\/7\/span 2\/span 3;\n  }\n\n  .be10000-main-container .grid .item-9 {\n    grid-area: 5\/10\/span 2\/span 3;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-main-container .grid .item-1 {\n      grid-area: 1\/1\/span 4\/span 4;\n    }\n\n    .be10000-main-container .grid .item-2 {\n      grid-area: 3\/5\/span 4\/span 4;\n    }\n\n    .be10000-main-container .grid .item-3 {\n      grid-area: 1\/9\/span 4\/span 4;\n    }\n\n    .be10000-main-container .grid .item-4 {\n      grid-area: 1\/5\/span 2\/span 4;\n    }\n\n    .be10000-main-container .grid .item-5 {\n      grid-area: 5\/1\/span 2\/span 4;\n    }\n\n    .be10000-main-container .grid .item-6 {\n      grid-area: 5\/9\/span 2\/span 4;\n    }\n\n    .be10000-main-container .grid .item-7 {\n      grid-area: 7\/1\/span 2\/span 4;\n    }\n\n    .be10000-main-container .grid .item-8 {\n      grid-area: 7\/5\/span 2\/span 4;\n    }\n\n    .be10000-main-container .grid .item-9 {\n      grid-area: 7\/9\/span 2\/span 4;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .grid .item-1 {\n      grid-area: 1\/1\/span 3\/span 3;\n    }\n\n    .be10000-main-container .grid .item-2 {\n      grid-area: 3\/4\/span 3\/span 3;\n    }\n\n    .be10000-main-container .grid .item-3 {\n      grid-area: 1\/7\/span 3\/span 3;\n    }\n\n    .be10000-main-container .grid .item-4 {\n      grid-area: 1\/4\/span 2\/span 3;\n    }\n\n    .be10000-main-container .grid .item-5 {\n      grid-area: 4\/1\/span 2\/span 3;\n    }\n\n    .be10000-main-container .grid .item-6 {\n      grid-area: 4\/7\/span 2\/span 3;\n    }\n\n    .be10000-main-container .grid .item-7 {\n      grid-area: 6\/1\/span 2\/span 3;\n    }\n\n    .be10000-main-container .grid .item-8 {\n      grid-area: 6\/4\/span 2\/span 3;\n    }\n\n    .be10000-main-container .grid .item-9 {\n      grid-area: 6\/7\/span 2\/span 3;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .grid .item-1 {\n      grid-area: 1\/1\/span 5\/span 4;\n    }\n\n    .be10000-main-container .grid .item-2 {\n      grid-area: 1\/5\/span 5\/span 4;\n    }\n\n    .be10000-main-container .grid .item-3 {\n      grid-area: 6\/1\/span 5\/span 4;\n    }\n\n    .be10000-main-container .grid .item-4 {\n      grid-area: 6\/5\/span 3\/span 4;\n    }\n\n    .be10000-main-container .grid .item-5 {\n      grid-area: 9\/5\/span 3\/span 4;\n    }\n\n    .be10000-main-container .grid .item-6 {\n      grid-area: 11\/1\/span 3\/span 4;\n    }\n\n    .be10000-main-container .grid .item-7 {\n      grid-area: 12\/5\/span 3\/span 4;\n    }\n\n    .be10000-main-container .grid .item-8 {\n      grid-area: 14\/1\/span 3\/span 4;\n    }\n\n    .be10000-main-container .grid .item-9 {\n      grid-area: 15\/5\/span 2\/span 4;\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    color: #000;\n    width: 100%;\n    overflow: hidden;\n    background-color: #fff;\n    position: relative;\n    \/* 轮播主体 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-wrapper {\n    position: relative;\n    width: 100%;\n    display: flex;\n    align-items: center;\n    justify-content: center;\n    overflow: visible;\n    padding: 20px 0;\n    cursor: grab;\n  }\n\n  @media (max-width: 992px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-wrapper {\n      padding: 0;\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-wrapper:active {\n    cursor: grabbing;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-container {\n    display: flex;\n    align-items: center;\n    justify-content: center;\n    width: 100%;\n    height: auto;\n    min-height: 400px;\n    position: relative;\n  }\n\n  @media (max-width: 992px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-container {\n      min-height: auto;\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item {\n    position: absolute;\n    width: 60%;\n    aspect-ratio: 16\/9;\n    border-radius: 15px;\n    overflow: hidden;\n    transition: transform 0.8s cubic-bezier(0.25, 1, 0.5, 1), opacity 0.8s ease;\n    opacity: 0;\n    transform: translateX(0);\n    z-index: 1;\n    user-select: none;\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 内部容器，用于裁剪圆角 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .media-inner {\n    width: 100%;\n    height: 100%;\n    border-radius: 15px;\n    overflow: hidden;\n    position: relative;\n    z-index: 1;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.active {\n    opacity: 1;\n    z-index: 10;\n    transform: translateX(0);\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.prev {\n    opacity: 0.4;\n    transform: translateX(-105%);\n    z-index: 5;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.next {\n    opacity: 0.4;\n    transform: translateX(105%);\n    z-index: 5;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.hidden-left {\n    opacity: 0;\n    transform: translateX(-200%);\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.hidden-right {\n    opacity: 0;\n    transform: translateX(200%);\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item video,\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item img {\n    width: 100%;\n    height: 100%;\n    object-fit: cover;\n    display: block;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item img {\n    transform: scale(1.01);\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 导航按钮 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .nav-btn {\n    position: absolute;\n    top: 50%;\n    transform: translateY(-50%);\n    background: rgba(255, 255, 255, 0.7);\n    border: none;\n    width: 4vw;\n    height: 4vw;\n    min-width: 40px;\n    min-height: 40px;\n    max-width: 60px;\n    max-height: 60px;\n    border-radius: 50%;\n    color: #333;\n    cursor: pointer;\n    z-index: 30;\n    display: flex;\n    align-items: center;\n    justify-content: center;\n    transition: all 0.3s ease;\n    box-shadow: 0 4px 12px rgba(0, 0, 0, 0.1);\n  }\n\n  .be10000-main-container .be10000-video-carousel .nav-btn:hover {\n    background: #fff;\n    transform: translateY(-50%) scale(1.1);\n  }\n\n  .be10000-main-container .be10000-video-carousel .nav-btn:focus {\n    outline: none;\n  }\n\n  .be10000-main-container .be10000-video-carousel .nav-btn svg {\n    width: 50%;\n    height: 50%;\n  }\n\n  .be10000-main-container .be10000-video-carousel .nav-btn.hidden {\n    opacity: 0;\n    pointer-events: none;\n  }\n\n  .be10000-main-container .be10000-video-carousel .prev-btn {\n    left: calc(20% + 20px);\n  }\n\n  .be10000-main-container .be10000-video-carousel .next-btn {\n    right: calc(20% + 20px);\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 播放\/暂停按钮 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-play-pause-btn {\n    position: absolute;\n    bottom: 20px;\n    right: 20px;\n    background: rgba(0, 0, 0, 0.5);\n    border: none;\n    width: 44px;\n    height: 44px;\n    border-radius: 50%;\n    color: white;\n    cursor: pointer;\n    z-index: 20;\n    display: flex;\n    align-items: center;\n    justify-content: center;\n    opacity: 0;\n    transition: opacity 0.3s;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.active .be10000-play-pause-btn {\n    opacity: 1;\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 图片项隐藏播放按钮 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-carousel-item.is-image .be10000-play-pause-btn {\n    display: none !important;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-play-pause-btn:focus {\n    outline: none;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-play-pause-btn svg {\n    position: absolute;\n    top: 0;\n    left: 0;\n    transform: rotate(-90deg);\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-progress-ring-circle {\n    transition: stroke-dashoffset 0.1s linear;\n    stroke: #fff;\n    stroke-width: 2;\n    fill: transparent;\n    stroke-dasharray: 125.6;\n    stroke-dashoffset: 125.6;\n  }\n\n  .be10000-main-container .be10000-video-carousel .bg-ring-circle {\n    stroke: rgba(255, 255, 255, 0.3);\n    stroke-width: 2;\n    fill: transparent;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-icon {\n    position: relative;\n    z-index: 2;\n    font-size: 16px;\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 底部控制区 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .controls-footer {\n    margin-top: 20px;\n    display: flex;\n    flex-direction: column;\n    align-items: center;\n    width: 100%;\n  }\n\n  .be10000-main-container .be10000-video-carousel .progress-container {\n    display: flex;\n    gap: 15px;\n    width: 60%;\n    height: 4px;\n    margin-bottom: 30px;\n  }\n\n  .be10000-main-container .be10000-video-carousel .progress-bar {\n    flex: 1;\n    background: #333;\n    border-radius: 2px;\n    cursor: pointer;\n    transition: background 0.3s;\n  }\n\n  .be10000-main-container .be10000-video-carousel .progress-bar.active {\n    background: #e0e0e0;\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 文案展示区域 *\/\n  }\n\n  .be10000-main-container .be10000-video-carousel .text-display-container {\n    width: 60%;\n    min-height: 100px;\n    text-align: left;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-text-content {\n    display: none;\n    animation: fadeIn 0.5s ease forwards;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-text-content.active {\n    display: block;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-text-content h5 {\n    margin-bottom: 10px;\n  }\n\n  .be10000-main-container .be10000-video-carousel .be10000-text-content p {\n    margin: 0;\n  }\n\n  @keyframes fadeIn {\n    from {\n      opacity: 0;\n      transform: translateY(10px);\n    }\n\n    to {\n      opacity: 1;\n      transform: translateY(0);\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel {\n    \/* 移动端适配 *\/\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-item {\n      width: 85%;\n      aspect-ratio: 1\/0.91;\n    }\n\n    .be10000-main-container .be10000-video-carousel .prev-btn {\n      left: calc(7.5% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .next-btn {\n      right: calc(7.5% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .progress-container,\n    .be10000-main-container .be10000-video-carousel .text-display-container {\n      width: 85%;\n    }\n\n    .be10000-main-container .be10000-video-carousel .be10000-text-content p {\n      font-size: 1rem;\n    }\n  }\n\n  @media (max-width: 991px) and (min-width: 768px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-item {\n      width: 70%;\n      aspect-ratio: 16\/9;\n    }\n\n    .be10000-main-container .be10000-video-carousel .prev-btn {\n      left: calc(15% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .next-btn {\n      right: calc(15% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .progress-container,\n    .be10000-main-container .be10000-video-carousel .text-display-container {\n      width: 70%;\n    }\n\n    .be10000-main-container .be10000-video-carousel .be10000-text-content p {\n      font-size: 1rem;\n    }\n  }\n\n  @media (max-width: 1400px) and (min-width: 991px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-item {\n      width: 70%;\n      aspect-ratio: 16\/9;\n    }\n\n    .be10000-main-container .be10000-video-carousel .prev-btn {\n      left: calc(15% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .next-btn {\n      right: calc(15% + 10px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .progress-container,\n    .be10000-main-container .be10000-video-carousel .text-display-container {\n      width: 70%;\n    }\n\n    .be10000-main-container .be10000-video-carousel .be10000-text-content p {\n      font-size: 1rem;\n    }\n  }\n\n  @media (min-width: 1400px) {\n    .be10000-main-container .be10000-video-carousel .be10000-carousel-item {\n      width: 45%;\n      aspect-ratio: 16\/9;\n    }\n\n    .be10000-main-container .be10000-video-carousel .prev-btn {\n      left: calc(27.5% + 20px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .next-btn {\n      right: calc(27.5% + 20px);\n    }\n\n    .be10000-main-container .be10000-video-carousel .progress-container,\n    .be10000-main-container .be10000-video-carousel .text-display-container {\n      width: 45%;\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel .overlay {\n    position: absolute;\n    top: 0;\n    left: 0;\n    height: 100%;\n    width: 100%;\n    background: linear-gradient(180deg, #000 0%, rgba(0, 0, 0, 0) 20%, rgba(0, 0, 0, 0) 80%, #000 100%);\n    opacity: 1;\n    z-index: 1;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-video-carousel .overlay {\n      background: linear-gradient(180deg, #000000 5%, rgba(0, 0, 0, 0) 25%, rgba(0, 0, 0, 0) 75%, #000000 95%);\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel .video-bg {\n    position: absolute;\n    top: 50%;\n    left: 50%;\n    min-width: 100%;\n    min-height: 100%;\n    width: auto;\n    height: auto;\n    z-index: 0;\n    -ms-transform: translateX(-50%) translateY(-50%);\n    -moz-transform: translateX(-50%) translateY(-50%);\n    -webkit-transform: translateX(-50%) translateY(-50%);\n    transform: translateX(-50%) translateY(-50%);\n    object-fit: cover;\n  }\n\n  .be10000-main-container .be10000-video-carousel .video-bg video {\n    width: auto;\n    height: 100%;\n    min-width: 100%;\n    object-fit: cover;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-video-carousel .video-bg video {\n      width: auto;\n      height: 100%;\n      object-fit: cover;\n    }\n  }\n\n  .be10000-main-container .be10000-video-carousel video :focus-visible {\n    outline: none;\n  }\n\n  .be10000-main-container .be10000-video-carousel .text-shadow {\n    text-shadow: 0px 0px 12px rgba(0, 0, 0, 0.6666666667);\n  }\n\n  .be10000-main-container .be10000-video-carousel .media-inner {\n    background-size: cover;\n  }\n\n  .be10000-main-container .be10000-video-carousel .media-inner .item-content {\n    position: absolute;\n    width: 100%;\n    bottom: 0;\n    padding: 6% 1.5rem 6%;\n    background: linear-gradient(180deg, rgba(0, 0, 0, 0) 0%, black 80%);\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-video-carousel .media-inner .item-content {\n      padding: 6% 1rem 10%;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-video-carousel .media-inner .item-content h3 {\n      font-size: 1.2rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .be10000-video-carousel .media-inner .item-content h3 {\n      font-size: 1.2rem;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios {\n    position: relative;\n    width: 100%;\n  }\n\n  .be10000-main-container .feature-scenarios figure {\n    height: 32rem;\n    display: flex;\n    margin: 0;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure {\n      flex-direction: column;\n      height: inherit;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-content {\n    display: flex;\n    flex-grow: 1;\n    flex-shrink: 1;\n    flex-basis: 0px;\n    flex-direction: column;\n    justify-content: center;\n    padding: 2.5rem 1.75rem;\n    text-align: center;\n    position: relative;\n    z-index: 1;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-content {\n      flex-grow: inherit;\n      flex-shrink: inherit;\n      position: absolute;\n      bottom: 0;\n      width: 100%;\n      padding: 1.5rem 1.5rem;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-content.order-lg-1 {\n    background: linear-gradient(90deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-content.order-lg-1 {\n      background: linear-gradient(0deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-content.order-lg-2 {\n    background: linear-gradient(-90deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-content.order-lg-2 {\n      background: linear-gradient(0deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-content h3 {\n      font-size: 1.2rem;\n    }\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-content h3 {\n      font-size: 1.2rem;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-img {\n    display: flex;\n    flex-grow: 1;\n    flex-shrink: 1;\n    flex-basis: 0px;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-img {\n      display: block;\n      flex-grow: inherit;\n      flex-shrink: inherit;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-img {\n      aspect-ratio: 3\/2;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-img picture {\n    width: 100%;\n    height: 100%;\n    object-fit: cover;\n    position: absolute;\n    left: 0;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .feature-scenarios figure .scenarios-img picture {\n      position: relative;\n    }\n  }\n\n  .be10000-main-container .feature-scenarios figure .scenarios-img picture img {\n    object-fit: cover;\n  }\n\n  .be10000-main-container .be10000-touchscreen .d-flex {\n    flex-direction: row;\n    gap: 1.5rem;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-touchscreen .d-flex {\n      flex-direction: column;\n    }\n  }\n\n  .be10000-main-container .be10000-touchscreen .d-flex\u003ediv {\n    display: flex;\n    flex-grow: 1;\n    flex-shrink: 1;\n  }\n\n  .be10000-main-container .be10000-touchscreen .d-flex\u003ediv .scenarios-content {\n    position: absolute;\n    width: 100%;\n    bottom: 0;\n    background: linear-gradient(0deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n  }\n\n  .be10000-main-container .be10000-dpi .card {\n    padding: 3rem 1.5rem;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-dpi .card {\n      padding: 2rem 1rem;\n    }\n  }\n\n  .be10000-main-container .be10000-dpi .scenarios-slider figure .figure-content h3 {\n    width: 85%;\n    padding-bottom: 1.75rem;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-dpi .scenarios-slider figure .figure-content h3 {\n      width: 90%;\n    }\n  }\n\n  .be10000-main-container .be10000-ports {\n    overflow: hidden;\n    background-color: #000;\n    background: linear-gradient(180deg, black 60%, var(--be10000) 100%);\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios {\n    max-width: 1200px;\n    margin: auto;\n    position: relative;\n    z-index: 0;\n    \/* Image *\/\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-image img {\n    width: 100%;\n    display: block;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-image {\n    position: relative;\n    width: 100%;\n    aspect-ratio: 26\/9;\n    overflow: hidden;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-image .scene-img {\n    position: absolute;\n    top: 0;\n    left: 0;\n    width: 100%;\n    height: 100%;\n    object-fit: cover;\n    opacity: 0;\n    z-index: 1;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-image .scene-img.active {\n    opacity: 1;\n    z-index: 2;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs {\n    display: flex;\n    justify-content: center;\n    gap: 12px;\n    position: sticky;\n    top: 0;\n    z-index: 10;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .tab.active {\n    color: #fff;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs {\n    width: 100%;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .scenarios-tabs-wrapper {\n    overflow-x: auto;\n    scrollbar-width: none;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .scenarios-tabs-wrapper::-webkit-scrollbar {\n    display: none;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .scenarios-tabs-wrapper {\n    -webkit-overflow-scrolling: touch;\n    padding: 10px 0;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .scenarios-tabs-bg {\n    position: relative;\n    display: flex;\n    flex-wrap: nowrap;\n    width: max-content;\n    background-color: #161718;\n    border-radius: 50px;\n    padding: 5px;\n    margin: 0 auto;\n    z-index: 1;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .scenarios-tabs-bg .tab-sliding-indicator {\n    position: absolute;\n    top: 5px;\n    left: 0;\n    height: calc(100% - 10px);\n    background-color: var(--be10000);\n    border-radius: 40px;\n    z-index: 0;\n    transition: all 0.4s cubic-bezier(0.4, 0, 0.2, 1);\n    width: var(--indicator-width, 0);\n    transform: translateX(var(--indicator-left, 0));\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .tab {\n    position: relative;\n    z-index: 2;\n    background: transparent !important;\n    border: none;\n    color: #888;\n    padding: 10px 25px;\n    font-weight: 600;\n    transition: color 0.3s;\n    white-space: nowrap;\n    border-radius: 40px;\n    outline: none !important;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs .tab.active {\n    color: #fff;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios {\n    \/* Content *\/\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-content {\n    margin-top: 28px;\n    text-align: center;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .tab-content {\n    display: none;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .tab-content.active {\n    display: block;\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios {\n    \/* Background container *\/\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs-bg {\n    display: inline-flex;\n    gap: 8px;\n    background: #2d2d2d;\n    \/* 👈 background color *\/\n    border-radius: 999px;\n    \/* pill *\/\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios {\n    \/* Tabs *\/\n  }\n\n  .be10000-main-container .be10000-ports .be10000-scenarios .scenarios-tabs-bg .tab {\n    padding: 8px 20px;\n    border-radius: 999px;\n    border: none;\n    background: transparent;\n    color: #a1a1a1;\n    cursor: pointer;\n    font-weight: 500;\n  }\n\n  .be10000-main-container .be10000-ports-2 {\n    background: linear-gradient(0deg, black 90%, rgba(25, 48, 101, 0.8) 100%);\n  }\n\n  .be10000-main-container .be10000-ports-2 .d-flex {\n    flex-direction: row;\n    gap: 1.5rem;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-main-container .be10000-ports-2 .d-flex {\n      flex-direction: column;\n    }\n  }\n\n  .be10000-main-container .be10000-ports-2 .d-flex\u003ediv:first-child {\n    display: flex;\n    flex-grow: 1;\n    flex-shrink: 1;\n  }\n\n  .be10000-main-container .be10000-ports-2 .d-flex\u003ediv:first-child .scenarios-content {\n    position: absolute;\n    width: 100%;\n    bottom: 0;\n    background: linear-gradient(0deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n  }\n\n  .be10000-main-container .be10000-ports-2 .d-flex\u003ediv:nth-child(2) {\n    display: flex;\n    flex-grow: 1;\n    flex-shrink: 1;\n  }\n\n  .be10000-main-container .be10000-ports-2 .d-flex\u003ediv:nth-child(2) .scenarios-content {\n    position: absolute;\n    width: 100%;\n    bottom: 0;\n    background: linear-gradient(0deg, rgba(0, 0, 0, 0.8666666667) 0%, rgba(0, 0, 0, 0) 100%);\n  }\n\n  .be10000-main-container .model-comparison .comparison-detail\u003ediv i.fa-crown {\n    color: var(--be10000);\n  }\n\n  .be10000-main-container .model-comparison .comparison-detail\u003ediv i.fa-check {\n    color: var(--be10000);\n  }\n\n  .be10000-main-container .model-comparison .comparison-detail div:nth-child(2) {\n    background-color: var(--be10000);\n  }\n\n  @media (max-width: 768px) {\n    .be10000-main-container .model-comparison .comparison-detail div:nth-child(2) {\n      background-color: inherit;\n    }\n  }\n\n  .be10000-de .grid .item-4 .grid-cell {\n    background-size: 117%;\n    background-position: 25% 25%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-de .grid .item-4 .grid-cell {\n      background-size: 175%;\n      background-position: 70% 30%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-de .grid .item-4 .grid-cell {\n      background-position: 76% 18%;\n    }\n  }\n\n  .be10000-de .grid .item-8 .grid-cell {\n    background-size: 106%;\n    background-position: 140% 22%;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-de .grid .item-8 .grid-cell {\n      background-size: 127%;\n      background-position: 71% 34%;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-de .grid .item-8 .grid-cell {\n      background-size: 134%;\n      background-position: 71% 32%;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-de .grid .item-8 .grid-cell {\n      background-size: 143%;\n      background-position: 74% 14%;\n    }\n  }\n\n  .be10000-fr .grid .item-2 .grid-cell {\n    background: linear-gradient(0deg, rgba(0, 0, 0, 0) 45%, black 90%);\n  }\n\n  .be10000-fr .grid .item-4 .grid-cell {\n    background-size: 112%;\n    background-position: 67% 21%;\n  }\n\n  @media (max-width: 991px) {\n    .be10000-fr .grid .item-4 .grid-cell {\n      background-size: 175%;\n      background-position: 70% 30%;\n    }\n  }\n\n  @media (max-width: 440px) {\n    .be10000-fr .grid .item-4 .grid-cell {\n      background-position: 76% 18%;\n    }\n  }\n\n  .be10000-fr .grid .item-8 .grid-cell {\n    background-size: 106%;\n    background-position: 140% 22%;\n  }\n\n  @media (max-width: 1199px) {\n    .be10000-fr .grid .item-8 .grid-cell {\n      background-size: 127%;\n      background-position: 71% 34%;\n    }\n  }\n\n  @media (max-width: 991px) {\n    .be10000-fr .grid .item-8 .grid-cell {\n      background-size: 134%;\n      background-position: 71% 32%;\n    }\n  }\n\n  @media (max-width: 576px) {\n    .be10000-fr .grid .item-8 .grid-cell {\n      background-size: 143%;\n      background-position: 74% 14%;\n    }\n  }\n\n  .product-nav {\n    top: 0 !important;\n  }\n\u003c\/style\u003e\n\u003cdiv class=\"select-language-button\" data-model=\"gl-be10000\" data-default=\"EN\"\u003e\u003c\/div\u003e\n\u003cscript type=\"module\"\u003e\n  \/**\n * selectLanguageBase: default language icon and name List\n *\/\n  export const selectLanguageBase = {\n    EN: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_us.png',\n      name: 'English (EN)'\n    },\n    DE: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_de.png',\n      name: 'German (DE)'\n    },\n    NL: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_nl.png',\n      name: 'Dutch (NL)'\n    },\n    FR: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_fr.png',\n      name: 'French (FR)'\n    },\n    SV: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_sv.png',\n      name: 'Swedish (SV)'\n    },\n    PL: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_pl.png',\n      name: 'Polish (PL)'\n    },\n    ES: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_es.png',\n      name: 'Spanish (ES)'\n    },\n    JP: {\n      icon: 'https:\/\/static.gl-inet.com\/www\/images\/campaign\/deals\/flag_jp.png',\n      name: 'Japanese (JP)'\n    }\n  }\n  \/**\n   * eg: \u003cdiv class=\"select-language-button\" data-model=\"gl-be3600\" data-default=\"EN\"\u003e\u003c\/div\u003e \n   *     \u003cdiv class=\"select-language-button\" data-model=\"gl-be3600\" data-only-switch=\"DE\"\u003e\u003c\/div\n   *     \u003cdiv class=\"select-language-button\" data-model=\"gl-be3600\" data-link=\"https:\/\/fonts.google.com\/\" data-target=\"_blank\" data-btn-text=\"点击打开新标签页\"\u003e\u003c\/div\u003e\n   * \n   * ---------------以下为必须写的内容--------------\n   * \u003cdiv class=\"select-language-button\" data-model=\"selectLanguageLink里面其中一个model\"\u003e\u003c\/div\u003e \n   * \n   * ---------------以下配置3选1【必须配置一个】--------------\n   * data-default     设置默认拉取除参数外的link item，作为选项列表【可从以下内容选择：EN、DE、NL、FR、SV、PL、ES】\n   * data-only-switch 设置links的一个url 作为按钮的link【可从以下内容选择：EN、DE、NL、FR、SV、PL、ES】\n   * data-link        设置外链\n   * \n   * ----------------以下为额外的配置项------------------------\n   * data-btn-text    可配置文案（如果自己配置文案，样式错乱的话，需要自定义一个class，去改样式，请不要改当前公共的样式）\n   * data-target=\"_blank\" 配置是否需要打开新标签【不写则为_self，可从以下内容选择：_self、_blank】\n   *\/\n  export const selectLanguageLink = [\n    {\n      model: 'gl-be3600',\n      \/\/  defaultLanguageShow: true, \/\/ 这个属性是默认语言是否在选项列表内展示（默认false）\n      links: [\n        { language: 'EN', url: '#' },\n        { language: 'DE', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-de\/' },\n        { language: 'NL', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-nl\/' },\n        { language: 'FR', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-fr\/' },\n        { language: 'SV', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-sv\/' },\n        { language: 'PL', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-pl\/' },\n        { language: 'ES', url: 'https:\/\/link.gl-inet.com\/productpage-be3600-es\/' }\n      ]\n    },\n    {\n      model: 'gl-rm1',\n      links: [\n        { language: 'EN', url: '#' },\n        { language: 'DE', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-de' },\n        { language: 'NL', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-nl\/' },\n        { language: 'FR', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-fr\/' },\n        { language: 'SV', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-sv\/' },\n        { language: 'PL', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-pl\/' },\n        { language: 'ES', url: 'https:\/\/link.gl-inet.com\/productpage-banner-rm1-es\/' }\n      ]\n    },\n    {\n      model: 'gl-be9300',\n      links: [\n        { language: 'EN', url: '#' },\n        { language: 'DE', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-de\/' },\n        { language: 'NL', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-nl\/' },\n        { language: 'FR', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-fr\/' },\n        { language: 'SV', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-sv\/' },\n        { language: 'PL', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-pl\/' },\n        { language: 'ES', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-es\/' },\n        { language: 'JP', url: 'https:\/\/link.gl-inet.com\/productpage-be9300-jp\/' }\n      ]\n    },\n    {\n      model: 'gl-be10000',\n      links: [\n        { language: 'EN', url: '#' },\n        { language: 'DE', url: '\/pages\/gl-be10000-de\/' },\n        { language: 'ES', url: '\/pages\/gl-be10000-es\/' },\n        { language: 'FR', url: '\/pages\/gl-be10000-fr\/' },\n        { language: 'NL', url: '\/pages\/gl-be10000-nl\/' },\n        { language: 'PL', url: '\/pages\/gl-be10000-pl\/' },\n        { language: 'SV', url: '\/pages\/gl-be10000-sv\/' },\n      ]\n    }\n  ]\n  \/**\n   * a language options list based on the provided model and defaultLan (default language) parameters.\n   * @param {string} model\n   * @param {string} defaultLan\n   * @returns HTML\n   *\/\n  function setElementHtml(model, btn) {\n    const defaultLan = btn.getAttribute('data-default')\n    const defaultOnlySwitch = btn.getAttribute('data-only-switch')\n    const dataLink = btn.getAttribute('data-link')\n    const dataTarget = btn.getAttribute('data-target') || '_self'\n    let btnText = btn.getAttribute('data-btn-text')\n    const item = selectLanguageLink.find((item) =\u003e item.model === model)\n    const linkList = item?.links || []\n    let elementTotal = ''\n    if (defaultLan) {\n      let elementList = ''\n      for (const linkItem of linkList) {\n        const icon = selectLanguageBase[linkItem.language].icon || ''\n        const name = selectLanguageBase[linkItem.language].name || ''\n        if (linkItem.language !== defaultLan || item.defaultLanguageShow) {\n          const elementItem = `\u003ca class=\"item\" href=\"${linkItem.url}\" target=\"${dataTarget}\"\u003e\u003cimg class=\"img-fluid mr-1 pb-1\" width=\"15px\" src=\"${icon}\"\u003e${name}\u003c\/a\u003e` \/\/ 添加了内容\n          elementList += elementItem \/\/ 使用字符串拼接\n        }\n      }\n\n      elementTotal = `\n        \u003cdiv class=\"select-language-container\"\u003e\n            \u003cdiv class=\"default\"\u003e\u003cspan\u003e${btnText || '\u0026nbsp;\u0026nbsp;Select\u0026nbsp;\u0026nbsp;Language \u0026nbsp;\u0026nbsp;'}\u003c\/span\u003e\u003c\/div\u003e\n            \u003cul class=\"select-language-list\"\u003e${elementList}\u003c\/ul\u003e\n        \u003c\/div\u003e`\n    } else if (defaultOnlySwitch) {\n      const onlyLink = linkList.find((item) =\u003e item.language === defaultOnlySwitch).url\n      elementTotal = `\n        \u003cdiv class=\"select-language-container\"\u003e\n            \u003ca class=\"default\" href=\"${onlyLink}\" target=\"${dataTarget}\"\u003e\u003cspan\u003e${btnText || 'Switch to English'}\u003c\/span\u003e\u003c\/a\u003e\n        \u003c\/div\u003e`\n    } else if (dataLink) {\n      elementTotal = `\n        \u003cdiv class=\"select-language-container\"\u003e\n            \u003ca class=\"default\" href=\"${dataLink}\" target=\"${dataTarget}\"\u003e\u003cspan\u003e${btnText || 'Switch to English'}\u003c\/span\u003e\u003c\/a\u003e\n        \u003c\/div\u003e`\n    }\n    return elementTotal\n  }\n  \/\/ change url of shop now button base on region\n  async function showSelectLanguageBtn() {\n    const btns = document.getElementsByClassName('select-language-button')\n    for (const btn of btns) {\n      const model = btn.getAttribute('data-model')\n      if (model == null) {\n        continue\n      }\n      const html = setElementHtml(model, btn)\n      const tempDiv = document.createElement('div')\n      tempDiv.innerHTML = html\n      btn.innerHTML = ''\n      while (tempDiv.firstChild) {\n        btn.appendChild(tempDiv.firstChild)\n      }\n    }\n  }\n  showSelectLanguageBtn()\n\n\u003c\/script\u003e\n\u003cmain class=\"be10000-main-container\"\u003e\n\n  \u003csection class=\"top-banner\" id=\"subscribe\"\u003e\n    \u003cdiv class=\"overlay\"\u003e\u003c\/div\u003e\n    \u003cvideo playsinline=\"playsinline\" autoplay=\"autoplay\" muted=\"muted\" loop\u003e\n      \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_bg_teaser.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n\n    \u003cdiv class=\"container h-100\"\u003e\n\n      \u003cdiv class=\"d-flex justify-content-center align-items-center text-center text-light h-100\"\u003e\n        \u003cdiv class=\"px-2\"\u003e\n          \u003ch1 class=\"font-weight-bold text-uppercase\"\u003eMeet Slate 7 Pro\u003c\/h1\u003e\n          \u003ch3 class=\"mb-0\"\u003eTri-band Wi-Fi 7 Travel Router\u003c\/h3\u003e\n          \u003cdiv class=\"font-italic mt-3\"\u003e\n            \u003cp\u003e*Slate 7 Pro is currently unavailable in the U.S. due to recent FCC-related developments. For details,\n              please refer to \u003ca href=\"\/blog\/glinet-statement-on-recent-fcc-regulatory-developments\/\" target=\"_blank\"\u003eour official statement\u003c\/a\u003e.\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003c!-- Introduction --\u003e\n  \u003csection class=\"p-4 py-lg-5 bg-light\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv class=\"row justify-content-center align-items-center\"\u003e\n        \u003cdiv class=\"col-12 col-md-12 col-lg-7 col-xl-7 mb-4\"\u003e\n          \u003ch2 class=\"font-weight-bold text-left\"\u003eWorld's First True Tri-band Travel Router\u003c\/h2\u003e\n          \u003cp\u003eSlate 7 Pro (GL-BE10000) is the world’s first travel router to redefine the limits of networking by\n            unleashing the full power of tri-band Wi-Fi 7 aggregation. Equipped with an intuitive 2.8\" touchscreen,\n            it allows you to manage key network functions with a single tap. Beyond speed, it provides pro-grade\n            security through integrated DPI and high-speed VPN to safeguard your privacy in any environment. With Slate\n            7 Pro,\n            you don’t just connect to the world—you challenge its boundaries. Choose your office, secure your data, and\n            embrace the freedom to work from anywhere without compromise.\u003c\/p\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eTri-band Wi-Fi 7 with MLO\u003c\/b\u003e: Faster and more stable connections\n                using tri-band aggregation and Multi-Link Operation.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eIntuitive 2.8\" Touchscreen\u003c\/b\u003e: Real-time monitoring and one-tap\n                basic network management.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eHigh-Speed VPN with Obfuscation\u003c\/b\u003e: Up to 1100 Mbps (WireGuard®)\n                with obfuscation to bypass restrictions.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eAdvanced Network Security\u003c\/b\u003e: Integrated DPI to easily identify\n                and block malicious traffic.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eOpenWrt Customization\u003c\/b\u003e: OpenWrt support for professional-grade\n                flexibility and plugin support.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"d-flex mb-2\"\u003e\n            \u003cdiv class=\"pr-2 text-be10000\"\u003e\u003ci class=\"fa-solid fa-check\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/div\u003e\n            \u003cdiv\u003e\n              \u003cp class=\"mb-0\"\u003e\u003cb class=\"text-be10000\"\u003eSeamless Wired Connectivity\u003c\/b\u003e: Dual 2.5G ports and a versatile\n                Type-C 3.0 data port.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"pt-2\"\u003e\n            \u003ca class=\"btn btn-round btn-round-be10000 mt-3 mr-3\" href=\"#specs\"\u003eView Specs\u003c\/a\u003e\n            \u003ca class=\"btn btn-round btn-outline-secondary mt-3\" href=\"\/support\/gl-be10000\/\" target=\"_blank\"\u003eOnline\n              Guide\u003c\/a\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n        \u003cdiv class=\"col-12 col-md-10 col-lg-5 py-4\"\u003e\n          \u003cdiv class=\"product_carousel\"\u003e\n            \u003cul class=\"product-show-list\"\u003e\n              \u003cli class=\"item active\" data-type=\"Photos\"\u003e\n                \u003cdiv id=\"carouselExampleIndicators\" class=\"carousel slide\" data-ride=\"carousel\"\u003e\n                  \u003col class=\"carousel-indicators\"\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"0\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"1\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"2\" class=\"active\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"3\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"4\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"5\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                    \u003cli data-target=\"#carouselExampleIndicators\" data-slide-to=\"6\" class=\"\"\u003e\n                    \u003c\/li\u003e\n                  \u003c\/ol\u003e\n                  \u003cdiv class=\"carousel-inner\"\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_1.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_1.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_1.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_2.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_2.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_2.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item active\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_3.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_3.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_3.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_4.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_4.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_4.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_5.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_5.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_5.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_6.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_6.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_6.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003cdiv class=\"carousel-item\"\u003e\n                      \u003cpicture\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_7.webp\" type=\"image\/webp\"\u003e\n                        \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_7.jpg\" type=\"image\/jpg\"\u003e\u003cimg class=\"d-block w-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_7.jpg\" alt=\"Slate 7 Pro (GL-BE10000) Product Photos\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n                    \u003c\/div\u003e\n                    \u003ca class=\"carousel-control-prev\" href=\"#carouselExampleIndicators\" role=\"button\" data-slide=\"prev\"\u003e\u003cspan class=\"carousel-control-prev-icon text-dark\" aria-hidden=\"true\"\u003e\u003c\/span\u003e\n                      \u003cspan class=\"sr-only\"\u003ePrevious\u003c\/span\u003e\n                    \u003c\/a\u003e\u003ca class=\"carousel-control-next\" href=\"#carouselExampleIndicators\" role=\"button\" data-slide=\"next\"\u003e\u003cspan class=\"carousel-control-next-icon text-dark\" aria-hidden=\"true\"\u003e\u003c\/span\u003e\n                      \u003cspan class=\"sr-only\"\u003eNext\u003c\/span\u003e\u003c\/a\u003e\n                  \u003c\/div\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n            \u003c\/ul\u003e\n          \u003c\/div\u003e\n          \u003cstyle\u003e\n            .product-show-list {\n              padding: 0;\n              margin: 0\n            }\n\n            .product-show-list\u003eli {\n              list-style-type: none;\n              margin: 0;\n              padding: 0;\n              display: none\n            }\n\n            .product-show-list\u003eli.active {\n              display: block\n            }\n\n            .product-show-list model-viewer {\n              display: block;\n              width: 100%;\n              height: 553px\n            }\n\n            @media(max-width:768px) {\n              .product-show-list model-viewer {\n                height: calc(90vw - 2.5rem)\n              }\n            }\n\n            .product-type-btn-list {\n              text-align: center;\n              padding-top: 15px\n            }\n\n            .product-type-btn-list a {\n              cursor: pointer;\n              padding: 5px 10px;\n              border-radius: 30px;\n              margin: 10px\n            }\n\n            .product-type-btn-list a i {\n              margin-right: 5px\n            }\n\n            .product-type-btn-list a:hover {\n              background-color: rgba(0, 0, 0, .1)\n            }\n\n            .product-type-btn-list a.active {\n              background-color: rgba(0, 0, 0, .8);\n              color: #fff\n            }\n          \u003c\/style\u003e\n          \u003cscript\u003edocument.querySelectorAll(\".product-type-btn-list a\").forEach(function (e) { e.addEventListener(\"click\", function () { document.querySelectorAll(\".product-type-btn-list a\").forEach(function (e) { e.classList.remove(\"active\") }), this.classList.add(\"active\"); var e = this.getAttribute(\"data-btn\"); document.querySelectorAll(\".product-show-list li\").forEach(function (t) { t.getAttribute(\"data-type\") === e.charAt(0).toUpperCase() + e.slice(1) ? t.classList.add(\"active\") : t.classList.remove(\"active\") }) }) })\u003c\/script\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003c!-- Product Nav Tab --\u003e\n  \u003csection class=\"product-nav\"\u003e\n    \u003cdiv class=\"product-nav-container container-md\"\u003e\n      \u003cdiv class=\"product-nav-content\"\u003e\n        \u003ca class=\"product-nav-item nav-link highlight\" href=\"#highlight\"\u003eHighlight\u003c\/a\u003e\n        \u003ca class=\"product-nav-item nav-link features\" href=\"#features\"\u003eFeatures\u003c\/a\u003e\n        \u003c!-- \u003ca class=\"product-nav-item nav-link scenarios\" href=\"#scenarios\"\u003eScenarios\u003c\/a\u003e --\u003e\n        \u003ca class=\"product-nav-item nav-link reviews\" href=\"#reviews\"\u003eReviews\u003c\/a\u003e\n        \u003ca class=\"product-nav-item nav-link specs\" href=\"#specs\"\u003eSpecs\u003c\/a\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n    \u003cscript\u003e\n      let currentModel = ''\n      window.addEventListener(\"scroll\", function () {\n        document.querySelectorAll(\".product-nav-section\").forEach((section) =\u003e {\n          let sectionTop = section.offsetTop;\n          if (pageYOffset \u003e= sectionTop - 100) {\n            currentModel = section.getAttribute(\"id\");\n          }\n        });\n        document.querySelectorAll(\".product-nav-item\").forEach((li) =\u003e {\n          if (li.classList.contains(currentModel)) {\n            li.classList.add(\"active\");\n          } else {\n            li.classList.remove(\"active\");\n          }\n        });\n      });\n    \u003c\/script\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- grid --\u003e\n  \u003csection class=\"px-0 py-4 py-lg-5 product-nav-section\" style=\"background-color: #000;\" id=\"highlight\"\u003e\n    \u003cdiv class=\"container py-0 py-lg-5\"\u003e\n      \u003cdiv class=\"grid w-100 text-white\"\u003e\n        \u003cdiv class=\"grid-item gl-rounded item-1\"\u003e\n\n          \u003cdiv class=\"cell-video\"\u003e\n            \u003cvideo loop=\"true\" autoplay=\"true\" muted=\"\" playsinline=\"\"\u003e\n              \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item1.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"grid-cell\"\u003e\n            \u003ch3 class=\"font-weight-bold mb-0\"\u003eWi-Fi 7\u003c\/h3\u003e\n            \u003ch2 class=\"mb-0\"\u003eAdvanced Tri-Band Connectivity\u003c\/h2\u003e\n            \u003c!--\n            \u003cdiv class=\"d-flex\"\u003e\n              \u003cdiv\u003e\n                \u003ch5 class=\"mb-0\"\u003e\u003cspan class=\"\"\u003e5765\u003c\/span\u003eMbps\u003c\/h5\u003e\n                \u003cp class=\"mb-0\"\u003e6GHz\u003c\/p\u003e\n              \u003c\/div\u003e\n              \u003cdiv\u003e\n                \u003ch5 class=\"mb-0\"\u003e\u003cspan class=\"\"\u003e2882\u003c\/span\u003eMbps\u003c\/h5\u003e\n                \u003cp class=\"mb-0\"\u003e5GHz\u003c\/p\u003e\n              \u003c\/div\u003e\n              \u003cdiv\u003e\n                \u003ch5 class=\"mb-0\"\u003e\u003cspan class=\"\"\u003e688\u003c\/span\u003eMbps\u003c\/h5\u003e\n                \u003cp class=\"mb-0\"\u003e2.4GHz\u003c\/p\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n            --\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-2\"\u003e\n          \u003cdiv class=\"cell-video\"\u003e\n            \u003cvideo loop=\"true\" autoplay=\"true\" muted=\"\" playsinline=\"\"\u003e\n              \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item2.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n          \u003c\/div\u003e\n          \u003c!--\n          \u003cdiv class=\"grid-cell\" style=\"background-image: linear-gradient(0deg, #00000000 50%, #000000cc 100%), url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item2.jpg');\"\u003e\n          --\u003e\n          \u003cdiv class=\"grid-cell\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eBlazing-Fast VPN\u003c\/h2\u003e\n            \u003cp class=\"mb-0\"\u003eMax. \u003cspan class=\"text-be10000\"\u003e1100\u003c\/span\u003e Mbps\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-3\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: linear-gradient(0deg, #5477e500 70%, #5477e511 100%), url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item3.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eSmart Touch Interface\u003c\/h2\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-4\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: linear-gradient(0deg, #5477e500 40%, #5477e545 100%), url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item4.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eVPN Obfuscation\u003c\/h2\u003e\n            \u003cp class=\"mb-0\"\u003eBypass Traffic Inspection\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-5\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item5.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eOpenWrt-based SDK\u003c\/h2\u003e\n            \u003cp class=\"mb-0\"\u003eFlexible \u003cbr class=\"d-block d-lg-none\"\u003eCustomization\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-6\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item6.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eAdvanced \u003cbr\u003eDPI Shield\u003c\/h2\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-7\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: linear-gradient(0deg, #5477e500 40%, #5477e545 100%), url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item7.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eTri-band Aggregation\u003c\/h2\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-8\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: linear-gradient(0deg, #5477e500 40%, #5477e566 95%), url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item8.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eDual 2.5G Ports\u003c\/h2\u003e\n            \u003cp class=\"mb-0\"\u003eBoosted Wired Connections\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"grid-item gl-rounded item-9\"\u003e\n          \u003cdiv class=\"grid-cell\" style=\"background-image: url('https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_grid-item9.jpg');\"\u003e\n            \u003ch2 class=\"font-weight-bold mb-1\"\u003eMulti-WAN \u003cbr\u003eFailover\u003c\/h2\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- wifi 7 --\u003e\n  \u003csection class=\"be10000-video-carousel be10000-wifi7 product-nav-section\" style=\"background-color: #000;\" id=\"features\"\u003e\n    \u003cdiv class=\"position-relative overflow-hidden py-3 py-lg-5\"\u003e\n      \u003cdiv class=\"overlay\"\u003e\u003c\/div\u003e\n      \u003cdiv class=\"video-bg\"\u003e\n        \u003cvideo playsinline=\"playsinline\" autoplay=\"autoplay\" muted=\"muted\" loop=\"loop\" class=\"px-0\"\u003e\n          \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_bg-wifi7_2.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"container position-relative text-shadow py-5\" style=\"z-index: 10;\"\u003e\n        \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto py-0 py-lg-5 my-0 my-lg-5\"\u003e\n          \u003ch2 class=\"font-weight-bold be10000-h2 \"\u003eTri-Band Wi-Fi 7 Extreme Performance\u003c\/h2\u003e\n          \u003cp class=\"mb-0\"\u003e\n            Slate 7 Pro offers a \u003cb class=\"\"\u003ededicated 6GHz\u003c\/b\u003e lane to bypass congestion, while MLO (Multi-Link\n            Operation) ensures the connection remains stable by switching bands in real-time.\n            By \u003cb class=\"\"\u003eaggregating three bands\u003c\/b\u003e into one massive data pipe, it delivers smooth, stable\n            performance for any heavy network demand.\n          \u003c\/p\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n\n    \u003cdiv class=\"container-fluid pb-5\"\u003e\n      \u003cdiv class=\"be10000-carousel-wrapper\"\u003e\n        \u003cbutton class=\"nav-btn prev-btn\"\u003e\n          \u003csvg viewbox=\"0 0 24 24\" fill=\"none\" stroke=\"currentColor\" stroke-width=\"2\" stroke-linecap=\"round\" stroke-linejoin=\"round\"\u003e\n            \u003cpolyline points=\"15 18 9 12 15 6\"\u003e\u003c\/polyline\u003e\n          \u003c\/svg\u003e\n        \u003c\/button\u003e\n\n        \u003cdiv class=\"be10000-carousel-container\"\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"1\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cvideo playsinline=\"\" muted=\"\"\u003e\n                \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_video-01.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eHigh-Density Connectivity in Congested Hubs\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"2\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cvideo playsinline=\"\" muted=\"\"\u003e\n                \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_video-02.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eMLO-Enhanced Speed for Intensive Workloads\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"3\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cvideo playsinline=\"\" muted=\"\"\u003e\n                \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_video-03.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eLow-Latency Performance for Cloud Gaming\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"4\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cvideo playsinline=\"\" muted=\"\"\u003e\n                \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_video-04.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eOffice-Grade Connectivity in Any Location\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n        \u003c\/div\u003e\n\n        \u003cbutton class=\"nav-btn next-btn\"\u003e\n          \u003csvg viewbox=\"0 0 24 24\" fill=\"none\" stroke=\"currentColor\" stroke-width=\"2\" stroke-linecap=\"round\" stroke-linejoin=\"round\"\u003e\n            \u003cpolyline points=\"9 18 15 12 9 6\"\u003e\u003c\/polyline\u003e\n          \u003c\/svg\u003e\n        \u003c\/button\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"controls-footer\"\u003e\n        \u003cdiv class=\"progress-container\"\u003e\u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n\n\n  \u003c\/section\u003e\n\n  \u003c!-- touchscreen --\u003e\n  \u003csection class=\"be10000-touchscreen py-4 py-lg-5\" style=\"background-color: #161718;\" id=\"touchscreen\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto\"\u003e\n        \u003ch2 class=\"font-weight-bold be10000-h2\"\u003eOne-Tap Network Control\u003c\/h2\u003e\n        \u003cp\u003e\n          Slate 7 Pro makes networking effortless with its responsive 2.8\" touchscreen. Manage essential features\n          directly on-device to save time and effort.\n          Instantly toggle VPNs, share Wi-Fi, and monitor status with a single touch, giving you immediate control the\n          moment you power on.\n        \u003c\/p\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"row justify-content-center mt-3\"\u003e\n        \u003cdiv class=\"col-l2\"\u003e\n          \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n            \u003csource media=\"(max-width: 991px)\" srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-touchscreen_bg_mobile.jpg\" type=\"image\/jpg\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-touchscreen_bg.jpg\" type=\"image\/jpg\"\u003e\n            \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-touchscreen_bg.jpg\" alt=\"One-Tap Network Control\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"d-flex justify-content-center w-100 mt-n5\"\u003e\n        \u003cdiv class=\"feature-scenarios\"\u003e\n          \u003cfigure class=\"overflow-hidden gl-rounded m-0\"\u003e\n            \u003cdiv class=\"scenarios-content gl-rounded\"\u003e\n              \u003ch3 class=\"font-weight-bold text-light mb-0 mb-md-3 mb-lg-0\"\u003eGet Started Instantly, No App Required\u003c\/h3\u003e\n            \u003c\/div\u003e\n            \u003cdiv class=\"scenarios-img\"\u003e\n              \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n                \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-from-power-on.jpg\" type=\"image\/jpg\"\u003e\n                \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-from-power-on.jpg\" alt=\"From Power-On to Connection—No App Required\"\u003e\u003c\/picture\u003e\n            \u003c\/div\u003e\n          \u003c\/figure\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"feature-scenarios\"\u003e\n          \u003cfigure class=\"overflow-hidden gl-rounded m-0\"\u003e\n            \u003cdiv class=\"scenarios-content gl-rounded\"\u003e\n              \u003ch3 class=\"font-weight-bold text-light mb-0 mb-md-3 mb-lg-0\"\u003eToggle VPNs and Switch Providers in Seconds\n              \u003c\/h3\u003e\n            \u003c\/div\u003e\n            \u003cdiv class=\"scenarios-img\"\u003e\n              \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n                \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-toggle-vpns.jpg\" type=\"image\/jpg\"\u003e\n                \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-toggle-vpns.jpg\" alt=\"Toggle VPNs and Switch Providers in Seconds\"\u003e\u003c\/picture\u003e\n            \u003c\/div\u003e\n          \u003c\/figure\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- vpn --\u003e\n  \u003csection class=\"be10000-video-carousel be10000-vpn py-4 py-5\" style=\"background-color: #000;\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto\"\u003e\n        \u003ch2 class=\"font-weight-bold be10000-h2\"\u003eHigh-Speed VPN with Stealth Obfuscation\u003c\/h2\u003e\n        \u003cp\u003e\n          Slate 7 Pro delivers massive throughput—\u003cb class=\"text-be10000\"\u003eup to 1100 Mbps via WireGuard®\u003c\/b\u003e and \u003cb class=\"text-be10000\"\u003e1000 Mbps with OpenVPN-DCO\u003c\/b\u003e, ensuring your encrypted tunnel feels as fast as an open\n          connection.\n          With support for 30+ leading VPN providers and built-in obfuscation, you can cloak your traffic and bypass\n          restrictions effortlessly wherever you are.\n        \u003c\/p\u003e\n        \u003cp class=\"mb-0\"\u003e\n          \u003csmall\u003e*Tests conducted on a local network. Real world speeds may differ depending on your network\n            configuration.\u003c\/small\u003e\u003cbr\u003e\n          \u003csmall\u003e*OpenVPN-DCO and WireGuard speeds will be slower when running the device as a server. Results above are\n            in client mode.\u003c\/small\u003e\n        \u003c\/p\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"col-12 mt-5 px-0 mb-3\"\u003e\n        \u003cvideo playsinline=\"playsinline\" autoplay=\"autoplay\" muted=\"muted\" loop=\"loop\" class=\"w-100 gl-rounded overflow-hidden video-border\"\u003e\n          \u003csource src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_vpn_obfiscation.mp4\" type=\"video\/mp4\"\u003e\u003c\/video\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n\n    \u003cdiv class=\"container-fluid pb-5\"\u003e\n      \u003cdiv class=\"be10000-carousel-wrapper\"\u003e\n        \u003cbutton class=\"nav-btn prev-btn\"\u003e\n          \u003csvg viewbox=\"0 0 24 24\" fill=\"none\" stroke=\"currentColor\" stroke-width=\"2\" stroke-linecap=\"round\" stroke-linejoin=\"round\"\u003e\n            \u003cpolyline points=\"15 18 9 12 15 6\"\u003e\u003c\/polyline\u003e\n          \u003c\/svg\u003e\n        \u003c\/button\u003e\n\n        \u003cdiv class=\"be10000-carousel-container\"\u003e\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"1\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-bypass-network.jpg\" alt=\"Bypass Network Blocks in Hotels \u0026amp; Public Wi-Fi\"\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eBypass Network Blocks in Hotels \u0026amp; Public Wi-Fi\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"2\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-star-connected.jpg\" alt=\"Stay Connected in Highly Restricted Areas\"\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eStay Connected in Highly Restricted Areas\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"3\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-hide-your-encryption.jpg\" alt=\"Hide Your Encryption for Maximum Privacy\"\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003eHide Your Encryption for Maximum Privacy\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"be10000-carousel-item\" data-index=\"4\"\u003e\n            \u003cdiv class=\"media-inner\"\u003e\n              \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-prevent-isp.jpg\" alt=\"Prevent ISP Throttling for Full Speed\"\u003e\n\n              \u003cdiv class=\"item-content text-center text-light\"\u003e\n                \u003ch3 class=\"font-weight-bold mb-0\"\u003ePrevent ISP Throttling for Full Speed\u003c\/h3\u003e\n              \u003c\/div\u003e\n\n              \u003cbutton class=\"be10000-play-pause-btn\"\u003e\n                \u003csvg width=\"44\" height=\"44\"\u003e\n                  \u003ccircle class=\"bg-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                  \u003ccircle class=\"be10000-progress-ring-circle\" cx=\"22\" cy=\"22\" r=\"20\"\u003e\u003c\/circle\u003e\n                \u003c\/svg\u003e\n                \u003cspan class=\"be10000-icon\"\u003eII\u003c\/span\u003e\n              \u003c\/button\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n        \u003c\/div\u003e\n\n        \u003cbutton class=\"nav-btn next-btn\"\u003e\n          \u003csvg viewbox=\"0 0 24 24\" fill=\"none\" stroke=\"currentColor\" stroke-width=\"2\" stroke-linecap=\"round\" stroke-linejoin=\"round\"\u003e\n            \u003cpolyline points=\"9 18 15 12 9 6\"\u003e\u003c\/polyline\u003e\n          \u003c\/svg\u003e\n        \u003c\/button\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"controls-footer\"\u003e\n        \u003cdiv class=\"progress-container\"\u003e\u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n\n  \u003c\/section\u003e\n\n  \u003cscript\u003e\n    (() =\u003e {\n      function initBe10000Carousel(targetSection) {\n        const wrapper = targetSection.querySelector(\".be10000-carousel-wrapper\");\n        const container = targetSection.querySelector(\".be10000-carousel-container\");\n        const items = targetSection.querySelectorAll(\".be10000-carousel-item\");\n        const textContents = targetSection.querySelectorAll(\".be10000-text-content\");\n        const prevBtn = targetSection.querySelector(\".prev-btn\");\n        const nextBtn = targetSection.querySelector(\".next-btn\");\n        const progressContainer = targetSection.querySelector(\".progress-container\");\n\n        if (!wrapper || !container || !items.length || !prevBtn || !nextBtn || !progressContainer) return;\n\n        let currentIndex = 0;\n        let isPlaying = true;\n        let imageCurrentTime = 0;\n        const IMAGE_DURATION = 4000;\n        const PAUSE_DELAY = 1000;\n        const radius = 20;\n        const circumference = 2 * Math.PI * radius;\n        let lastTimestamp = 0;\n        let isPausing = false;\n        let pauseStartTime = 0;\n\n        progressContainer.innerHTML = \"\";\n        items.forEach((_, index) =\u003e {\n          const bar = document.createElement(\"div\");\n          bar.className = \"progress-bar\";\n          bar.addEventListener(\"click\", () =\u003e goToSlide(index));\n          progressContainer.appendChild(bar);\n        });\n        const progressBars = progressContainer.querySelectorAll(\".progress-bar\");\n\n        function updatePlayPauseIcons(text) {\n          const icons = targetSection.querySelectorAll(\".be10000-icon\");\n          icons.forEach((icon) =\u003e (icon.textContent = text));\n        }\n\n        function updateCarousel() {\n          imageCurrentTime = 0;\n          lastTimestamp = performance.now();\n          isPausing = false;\n          pauseStartTime = 0;\n          isPlaying = true;\n          updatePlayPauseIcons(\"II\");\n\n          items.forEach((item, index) =\u003e {\n            item.classList.remove(\"active\", \"prev\", \"next\", \"hidden-left\", \"hidden-right\");\n            const video = item.querySelector(\"video\");\n\n            if (index === currentIndex) {\n              item.classList.add(\"active\");\n              if (video) {\n                video.currentTime = 0;\n                video.play();\n              }\n              requestAnimationFrame(updateProgressLoop);\n            } else {\n              if (video) {\n                video.pause();\n                video.currentTime = 0;\n              }\n              if (index === currentIndex - 1) item.classList.add(\"prev\");\n              else if (index === currentIndex + 1) item.classList.add(\"next\");\n              else if (index \u003c currentIndex) item.classList.add(\"hidden-left\");\n              else item.classList.add(\"hidden-right\");\n            }\n          });\n\n          textContents.forEach((content, index) =\u003e {\n            content.classList.toggle(\"active\", index === currentIndex);\n          });\n          progressBars.forEach((bar, index) =\u003e {\n            bar.classList.toggle(\"active\", index === currentIndex);\n          });\n          prevBtn.classList.toggle(\"hidden\", currentIndex === 0);\n          nextBtn.classList.toggle(\"hidden\", currentIndex === items.length - 1);\n\n          const activeItem = items[currentIndex];\n          if (activeItem) container.style.height = activeItem.offsetHeight + \"px\";\n        }\n\n        function goToSlide(index) {\n          if (currentIndex === index) return;\n          currentIndex = index;\n          updateCarousel();\n        }\n\n        function nextSlide() {\n          if (currentIndex \u003c items.length - 1) {\n            currentIndex++;\n            updateCarousel();\n          } else {\n            isPlaying = false;\n            updatePlayPauseIcons(\"▶\");\n            const video = items[currentIndex].querySelector(\"video\");\n            if (video) video.pause();\n          }\n        }\n\n        function prevSlide() {\n          if (currentIndex \u003e 0) {\n            currentIndex--;\n            updateCarousel();\n          }\n        }\n\n        function updateProgressLoop(timestamp) {\n          if (!lastTimestamp) lastTimestamp = timestamp;\n          const deltaTime = timestamp - lastTimestamp;\n          lastTimestamp = timestamp;\n\n          const activeItem = items[currentIndex];\n          if (!activeItem) return;\n\n          const video = activeItem.querySelector(\"video\");\n          const circle = activeItem.querySelector(\".be10000-progress-ring-circle\");\n          let percent = 0;\n\n          if (video) {\n            if (video.duration) percent = video.currentTime \/ video.duration;\n          } else if (isPlaying) {\n            if (isPausing) {\n              const pauseElapsed = timestamp - pauseStartTime;\n              if (pauseElapsed \u003e= PAUSE_DELAY) {\n                isPausing = false;\n                updatePlayPauseIcons(\"▶\");\n                nextSlide();\n                return;\n              }\n              percent = 1;\n            } else {\n              imageCurrentTime += deltaTime;\n              if (imageCurrentTime \u003e= IMAGE_DURATION) {\n                imageCurrentTime = IMAGE_DURATION;\n                isPausing = true;\n                pauseStartTime = timestamp;\n                updatePlayPauseIcons(\"▶\");\n              }\n              percent = imageCurrentTime \/ IMAGE_DURATION;\n            }\n          } else {\n            percent = imageCurrentTime \/ IMAGE_DURATION;\n          }\n\n          if (circle) {\n            const offset = circumference - percent * circumference;\n            circle.style.strokeDashoffset = offset;\n          }\n\n          if (isPlaying) requestAnimationFrame(updateProgressLoop);\n        }\n\n        function togglePlay() {\n          isPlaying = !isPlaying;\n          const activeItem = items[currentIndex];\n          const video = activeItem.querySelector(\"video\");\n          if (isPlaying) {\n            if (video) video.play();\n            updatePlayPauseIcons(\"II\");\n            lastTimestamp = performance.now();\n            requestAnimationFrame(updateProgressLoop);\n          } else {\n            if (video) video.pause();\n            updatePlayPauseIcons(\"▶\");\n          }\n        }\n\n        let startX = 0;\n        let isDragging = false;\n        wrapper.addEventListener(\"mousedown\", dragStart);\n        wrapper.addEventListener(\"touchstart\", dragStart);\n        wrapper.addEventListener(\"mousemove\", dragMove);\n        wrapper.addEventListener(\"touchmove\", dragMove);\n        wrapper.addEventListener(\"mouseup\", dragEnd);\n        wrapper.addEventListener(\"touchend\", dragEnd);\n        wrapper.addEventListener(\"mouseleave\", dragEnd);\n\n        function dragStart(e) {\n          isDragging = true;\n          startX = getPositionX(e);\n        }\n\n        function dragMove() {\n          if (!isDragging) return;\n        }\n\n        function dragEnd(e) {\n          if (!isDragging) return;\n          isDragging = false;\n          const endX = getPositionX(e);\n          const diff = endX - startX;\n          if (diff \u003e 50) prevSlide();\n          else if (diff \u003c -50) nextSlide();\n        }\n\n        function getPositionX(e) {\n          return e.type.includes(\"mouse\") ? e.pageX : e.touches[0].clientX;\n        }\n\n        items.forEach((item, index) =\u003e {\n          const video = item.querySelector(\"video\");\n          if (video) {\n            video.onended = () =\u003e {\n              if (index === currentIndex) {\n                isPausing = true;\n                pauseStartTime = performance.now();\n                updatePlayPauseIcons(\"▶\");\n                requestAnimationFrame(waitAndNextSlide);\n              }\n            };\n          }\n        });\n\n        function waitAndNextSlide(timestamp) {\n          if (!isPausing) return;\n          const pauseElapsed = timestamp - pauseStartTime;\n          if (pauseElapsed \u003e= PAUSE_DELAY) {\n            isPausing = false;\n            updatePlayPauseIcons(\"▶\");\n            nextSlide();\n          } else {\n            requestAnimationFrame(waitAndNextSlide);\n          }\n        }\n\n        nextBtn.addEventListener(\"click\", (e) =\u003e {\n          e.stopPropagation();\n          nextSlide();\n        });\n        prevBtn.addEventListener(\"click\", (e) =\u003e {\n          e.stopPropagation();\n          prevSlide();\n        });\n        items.forEach((item) =\u003e {\n          const btn = item.querySelector(\".be10000-play-pause-btn\");\n          if (btn) {\n            btn.addEventListener(\"click\", (e) =\u003e {\n              e.stopPropagation();\n              togglePlay();\n            });\n          }\n          item.addEventListener(\"click\", () =\u003e {\n            if (item.classList.contains(\"prev\")) prevSlide();\n            if (item.classList.contains(\"next\")) nextSlide();\n          });\n        });\n\n        const observer = new IntersectionObserver((entries) =\u003e {\n          entries.forEach((entry) =\u003e {\n            if (entry.isIntersecting) {\n              if (!targetSection.dataset.carouselInitialized) {\n                updateCarousel();\n                targetSection.dataset.carouselInitialized = \"true\";\n              } else if (!isPlaying) {\n                togglePlay();\n              }\n            } else if (targetSection.dataset.carouselInitialized === \"true\" \u0026\u0026 isPlaying) {\n              togglePlay();\n            }\n          });\n        }, { root: null, rootMargin: \"0px\", threshold: 0.5 });\n\n        observer.observe(targetSection);\n        window.addEventListener(\"resize\", updateCarousel);\n      }\n\n      const sections = document.querySelectorAll(\".be10000-video-carousel, .be10000-vpn\");\n      sections.forEach((section) =\u003e initBe10000Carousel(section));\n    })();\n  \u003c\/script\u003e\n\n  \u003c!-- dpi --\u003e\n  \u003csection class=\"be10000-dpi py-4 py-lg-5\" style=\"background-color: #161718;\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv\u003e\n        \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_dpi.jpg\" alt=\"Pro DPI Security, Compactly Delivered\"\u003e\n      \u003c\/div\u003e\n      \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto py-5\"\u003e\n        \u003cp class=\"mb-0\"\u003e\n          Slate 7 Pro delivers professional-level precision in a sleek, compact design. By integrating Deep Packet\n          Inspection (DPI),\n          it moves beyond basic tracking to analyze data in real-time—giving you the power to monitor and protect your\n          network, anywhere.\n        \u003c\/p\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"row justify-content-center align-content-center text-light text-center px-3\"\u003e\n        \u003cdiv class=\"col-6 col-lg-3 px-0 mb-3\"\u003e\n          \u003cdiv class=\"card border-0 gl-rounded h-100 mx-2\" style=\"background-color: #121213;\"\u003e\n            \u003ch1 class=\"mb-2 mb-lg-3\"\u003e\n              \u003ci class=\"fa-solid fa-arrows-to-eye\"\u003e\u003c\/i\u003e\n            \u003c\/h1\u003e\n            \u003cp class=\"mb-0\"\u003eIntuitive Traffic Insights with Visual Precision\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-6 col-lg-3 px-0 mb-3\"\u003e\n          \u003cdiv class=\"card border-0 gl-rounded h-100 mx-2\" style=\"background-color: #121213;\"\u003e\n            \u003ch1 class=\"mb-2 mb-lg-3\"\u003e\n              \u003ci class=\"fa-solid fa-filter\"\u003e\u003c\/i\u003e\n            \u003c\/h1\u003e\n            \u003cp class=\"mb-0\"\u003eSmart Web \u0026amp; Content Filtering\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-6 col-lg-3 px-0 mb-3\"\u003e\n          \u003cdiv class=\"card border-0 gl-rounded h-100 mx-2\" style=\"background-color: #121213;\"\u003e\n            \u003ch1 class=\"mb-2 mb-lg-3\"\u003e\n              \u003ci class=\"fa-solid fa-chart-diagram\"\u003e\u003c\/i\u003e\n            \u003c\/h1\u003e\n            \u003cp class=\"mb-0\"\u003eOptimized Bandwidth Management\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-6 col-lg-3 px-0 mb-3\"\u003e\n          \u003cdiv class=\"card border-0 gl-rounded h-100 mx-2\" style=\"background-color: #121213;\"\u003e\n            \u003ch1 class=\"mb-2 mb-lg-3\"\u003e\n              \u003ci class=\"fa-solid fa-hexagon-nodes\"\u003e\u003c\/i\u003e\n            \u003c\/h1\u003e\n            \u003cp class=\"mb-0\"\u003eStable Connections for Critical Tasks\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n\n    \u003cdiv class=\"scenarios-slider-container tiny-slider-container-general-1122 pt-3\"\u003e\n      \u003cdiv class=\"container\"\u003e\n        \u003cdiv class=\"tns-outer\" id=\"tns2-ow\"\u003e\n          \u003cdiv class=\"tns-liveregion tns-visually-hidden\" aria-live=\"polite\" aria-atomic=\"true\"\u003eslide \u003cspan class=\"current\"\u003e3 to 4\u003c\/span\u003e of 4\u003c\/div\u003e\n          \u003cdiv id=\"tns2-mw\" class=\"tns-ovh\"\u003e\n            \u003cdiv class=\"tns-inner\" id=\"tns2-iw\"\u003e\n              \u003cdiv class=\"scenarios-slider tiny-slider-general-1122  tns-slider tns-carousel tns-subpixel tns-calc tns-horizontal\" id=\"tns2\" style=\"transform: translate3d(-50%, 0px, 0px);\"\u003e\n                \u003cdiv class=\"tiny-slider-item-general-1122 tns-item\" id=\"tns2-item0\" aria-hidden=\"true\" tabindex=\"-1\"\u003e\n                  \u003cfigure\u003e\n                    \u003cdiv class=\"figure-content w-100 h-100 text-center gl-rounded overflow-hidden\" style=\"background-image:linear-gradient(180deg,#00000000 50%,#000000ff 95%),url(https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_dpi-scenarios-1.jpg)\"\u003e\n                      \u003ch3 class=\"font-weight-bold mx-auto\"\u003eProfessional Network Sovereignty for Remote Teams\u003c\/h3\u003e\n                    \u003c\/div\u003e\n                  \u003c\/figure\u003e\n                \u003c\/div\u003e\n                \u003cdiv class=\"tiny-slider-item-general-1122 tns-item\" id=\"tns2-item1\" aria-hidden=\"true\" tabindex=\"-1\"\u003e\n                  \u003cfigure\u003e\n                    \u003cdiv class=\"figure-content w-100 h-100 text-center gl-rounded overflow-hidden\" style=\"background-image:linear-gradient(180deg,#00000000 50%,#000000ff 95%),url(https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_dpi-scenarios-2.jpg)\"\u003e\n                      \u003ch3 class=\"font-weight-bold mx-auto\"\u003eEnterprise-Grade Security for Family \u0026amp; Small Business\n                      \u003c\/h3\u003e\n                    \u003c\/div\u003e\n                  \u003c\/figure\u003e\n                \u003c\/div\u003e\n                \u003cdiv class=\"tiny-slider-item-general-1122 tns-item tns-slide-active\" id=\"tns2-item2\"\u003e\n                  \u003cfigure\u003e\n                    \u003cdiv class=\"figure-content w-100 h-100 text-center gl-rounded overflow-hidden\" style=\"background-image:linear-gradient(180deg,#00000000 50%,#000000ff 95%),url(https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_dpi-scenarios-3.jpg)\"\u003e\n                      \u003ch3 class=\"font-weight-bold mx-auto\"\u003eSeamless Connectivity for Virtual Collaboration\u003c\/h3\u003e\n                    \u003c\/div\u003e\n                  \u003c\/figure\u003e\n                \u003c\/div\u003e\n                \u003cdiv class=\"tiny-slider-item-general-1122 tns-item tns-slide-active\" id=\"tns2-item3\"\u003e\n                  \u003cfigure\u003e\n                    \u003cdiv class=\"figure-content w-100 h-100 text-center gl-rounded overflow-hidden\" style=\"background-image:linear-gradient(180deg,#00000000 50%,#000000ff 95%),url(https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_dpi-scenarios-4.jpg)\"\u003e\n                      \u003ch3 class=\"font-weight-bold mx-auto\"\u003eStable Performance for Critical High-Load Tasks\u003c\/h3\u003e\n                    \u003c\/div\u003e\n                  \u003c\/figure\u003e\n                \u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n        \u003cdiv class=\"mt-3 mt-lg-5\"\u003e\n          \u003cdiv class=\"tiny-slider-general-1122-controls tiny-slider-controls circle-controls m-auto text-right d-lg-block\" aria-label=\"Carousel Navigation\" tabindex=\"0\"\u003e\n            \u003ca class=\"prev mr-2\" data-controls=\"prev\" aria-controls=\"tns2\" tabindex=\"-1\" aria-disabled=\"false\"\u003e\u003ci class=\"fas fa-chevron-left\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\n            \u003c\/a\u003e\u003ca class=\"next\" data-controls=\"next\" aria-controls=\"tns2\" tabindex=\"-1\" aria-disabled=\"true\"\u003e\u003ci class=\"fas fa-chevron-right\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/a\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- ports --\u003e\n  \u003csection class=\"be10000-ports position-relative pt-4 pt-lg-5\"\u003e\n\n    \u003cdiv class=\"container be10000-scenarios pt-5\"\u003e\n      \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto position-relative\" style=\"z-index: 8; background: linear-gradient(180deg, #000000ff 60%, #00000000 100%);\"\u003e\n        \u003ch2 class=\"font-weight-bold be10000-h2\"\u003eAlways-On, High-Speed Networking\u003c\/h2\u003e\n        \u003cp\u003e\n          Slate 7 Pro features \u003cb class=\"text-be10000\"\u003edual 2.5G ports\u003c\/b\u003e—including one configurable WAN\/LAN—and a \u003cb class=\"text-be10000\"\u003eUSB-C port\u003c\/b\u003e for tethering, enabling fast,\n          flexible connectivity with seamless \u003cb class=\"text-be10000\"\u003eMulti-WAN failover\u003c\/b\u003e.\n        \u003c\/p\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"row justify-content-center mt-4\"\u003e\n        \u003cdiv class=\"col-lg-9\"\u003e\n          \u003c!-- Scene Tabs --\u003e\n          \u003cdiv class=\"scenarios-tabs mb-4 mb-lg-0\"\u003e\n            \u003c!-- 增加一层用于处理横向滚动的包装 --\u003e\n            \u003cdiv class=\"scenarios-tabs-wrapper\"\u003e\n              \u003cdiv class=\"scenarios-tabs-bg\"\u003e\n                \u003cbutton class=\"tab active\" data-tab=\"pd\" data-img=\"...\"\u003ePower Port\u003c\/button\u003e\n                \u003cbutton class=\"tab\" data-tab=\"wan\" data-img=\"...\"\u003eWAN Port\u003c\/button\u003e\n                \u003cbutton class=\"tab\" data-tab=\"wanlan\" data-img=\"...\"\u003eLAN Port\u003c\/button\u003e\n                \u003cbutton class=\"tab\" data-tab=\"typec\" data-img=\"...\"\u003eType-C Data Port\u003c\/button\u003e\n\n                \u003c!-- 滑动底色指示器 --\u003e\n                \u003cdiv class=\"tab-sliding-indicator\"\u003e\u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003c!-- Scene Images --\u003e\n          \u003cdiv class=\"scenarios-image\"\u003e\n            \u003c!-- 初始状态：Data Center 显示，其他隐藏 --\u003e\n            \u003cimg class=\"scene-img active\" data-target=\"pd\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_pd.png\"\u003e\n            \u003cimg class=\"scene-img\" data-target=\"wan\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_wan.png\"\u003e\n            \u003cimg class=\"scene-img\" data-target=\"wanlan\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_wanlan.png\"\u003e\n            \u003cimg class=\"scene-img\" data-target=\"typec\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_typec.png\"\u003e\n          \u003c\/div\u003e\n\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003c!-- Content --\u003e\n      \u003c!--\n      \u003cdiv class=\"scenarios-content text-light\"\u003e\n        \u003cdiv class=\"row justify-content-center\"\u003e\n          \u003cdiv class=\"col-lg-10\"\u003e\n            \u003cdiv class=\"tab-content active\" id=\"data-center\"\u003e\n              \u003ch4 class=\"font-weight-bold\"\u003eDitch the Monitor, Keyboard, and Mouse\u003c\/h4\u003e\n              \u003cp\u003eManaging hardware shouldn't require carrying a physical monitor, keyboard, and mouse. With Nearby Control, Comet 5G creates its own wireless management bridge by broadcasting a local SSID. \u003c\/p\u003e\n              \u003cp\u003eThis allows you to configure and control your devices—even in network-isolated environments—using just your laptop or tablet, with no internet or physical peripherals required.\u003c\/p\u003e\n            \u003c\/div\u003e\n        \n            \u003cdiv class=\"tab-content\" id=\"homelab\"\u003e\n              \u003ch4 class=\"font-weight-bold\"\u003eYour Ultimate Network Failsafe\u003c\/h4\u003e\n              \u003cp\u003eWhen your primary ISP goes down, your entire home lab becomes a black box. Relying on a single connection is a risk for any power user. \u003c\/p\u003e\n              \u003cp\u003eComet 5G acts as your final out-of-band management tool, providing a dedicated 5G\/4G cellular path back into your system. Even if your main network fails, you’re never locked out of your home infrastructure.\u003c\/p\u003e\n            \u003c\/div\u003e\n        \n            \u003cdiv class=\"tab-content\" id=\"field-operations\"\u003e\n              \u003ch4 class=\"font-weight-bold\"\u003eMaintenance Without the Miles\u003c\/h4\u003e\n              \u003cp\u003eSending a technician to a rural site just to flip a power switch is a waste of time and resources. Comet 5G provides ultra-reliable connectivity with 5G RedCap and remote power management. \u003c\/p\u003e\n              \u003cp\u003eRestart crashed equipment or update configurations in remote areas from the comfort of your office, reducing downtime and eliminating unnecessary travel costs.\u003c\/p\u003e\n            \u003c\/div\u003e\n        \n            \u003cdiv class=\"tab-content\" id=\"live-concerts\"\u003e\n              \u003ch4 class=\"font-weight-bold\"\u003eReal-Time Tuning from Anywhere\u003c\/h4\u003e\n              \u003cp\u003eManaging complex AV systems for global tours usually requires lead engineers to be on-site at every stop. With Comet 5G, your top experts can monitor and tune equipment in real-time from anywhere in the world. \u003c\/p\u003e\n              \u003cp\u003eWhile local staff handle the physical setup, your technical team can optimize performance remotely, ensuring a perfect show without the need for international travel.\u003c\/p\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n      --\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003cscript\u003e\n    document.addEventListener('DOMContentLoaded', () =\u003e {\n      const bgContainer = document.querySelector('.scenarios-tabs-bg');\n      const scrollWrapper = document.querySelector('.scenarios-tabs-wrapper');\n      const tabs = document.querySelectorAll('.be10000-scenarios .tab');\n      const imgs = document.querySelectorAll('.be10000-scenarios .scene-img'); \/\/ 假设用了叠加法\n      const contents = document.querySelectorAll('.be10000-scenarios .tab-content');\n\n      \/\/ 更新滑块位置并自动居中\n      const updateTabUI = (activeTab) =\u003e {\n        if (!activeTab) return;\n\n        \/\/ 1. 计算滑块位置\n        const tabWidth = activeTab.offsetWidth;\n        const tabLeft = activeTab.offsetLeft;\n        bgContainer.style.setProperty('--indicator-width', `${tabWidth}px`);\n        bgContainer.style.setProperty('--indicator-left', `${tabLeft}px`);\n\n        \/\/ 2. 手机端自动居中逻辑 (关键修复)\n        if (scrollWrapper) {\n          \/\/ 计算目标滚动位置：Tab 的左偏移 - (容器的一半) + (Tab宽度的一半)\n          const containerWidth = scrollWrapper.offsetWidth;\n          const targetScroll = tabLeft - (containerWidth \/ 2) + (tabWidth \/ 2);\n\n          scrollWrapper.scrollTo({\n            left: targetScroll,\n            behavior: 'smooth' \/\/ 平滑滚动\n          });\n        }\n      };\n\n      tabs.forEach(tab =\u003e {\n        tab.addEventListener('click', () =\u003e {\n          const target = tab.getAttribute('data-tab');\n\n          \/\/ 状态切换\n          tabs.forEach(t =\u003e t.classList.remove('active'));\n          tab.classList.add('active');\n\n          updateTabUI(tab);\n\n          \/\/ 图片和文字内容联动\n          if (imgs.length \u003e 0) {\n            imgs.forEach(img =\u003e {\n              img.classList.toggle('active', img.getAttribute('data-target') === target);\n            });\n          }\n          contents.forEach(content =\u003e {\n            content.classList.toggle('active', content.id === target);\n          });\n        });\n      });\n\n      \/\/ 初始化位置\n      const initialActive = document.querySelector('.be10000-scenarios .tab.active');\n      if (initialActive) {\n        setTimeout(() =\u003e updateTabUI(initialActive), 200);\n      }\n\n      \/\/ 窗口大小改变时重置\n      window.addEventListener('resize', () =\u003e {\n        const currentActive = document.querySelector('.be10000-scenarios .tab.active');\n        updateTabUI(currentActive);\n      });\n    }); \n  \u003c\/script\u003e\n\n  \u003cscript\u003e\n    document.addEventListener('DOMContentLoaded', function () {\n      const pillLinks = document.querySelectorAll('a[data-toggle=\"pill\"][data-target]');\n      console.log(pillLinks);\n\n      pillLinks.forEach(function (link) {\n        link.addEventListener('click', function (e) {\n          const targetIds = this.dataset.target.split(', ');\n          console.log(targetIds);\n          document.querySelectorAll('.tab-pane').forEach(panel =\u003e {\n            panel.classList.remove('active', 'show');\n          });\n\n          targetIds.forEach(function (id) {\n            const panel = document.querySelector(id);\n            if (panel) {\n              panel.classList.add('active', 'show');\n            }\n          });\n        });\n      });\n    });\n  \u003c\/script\u003e\n\n  \u003csection class=\"be10000-ports-2 py-4 py-lg-5\" style=\"background-color: #000;\"\u003e\n    \u003cdiv class=\"container text-light mt-5\"\u003e\n      \u003cdiv class=\"feature-scenarios\"\u003e\n        \u003cfigure class=\"overflow-hidden gl-rounded mb-4\"\u003e\n          \u003cdiv class=\"scenarios-content order-2 order-lg-1\"\u003e\n            \u003ch3 class=\"font-weight-bold mb-0 mb-md-3\"\u003eMission-Critical Reliability for Business Travel\u003c\/h3\u003e\n          \u003c\/div\u003e\n          \u003cdiv class=\"scenarios-img order-1 order-lg-2\"\u003e\n            \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n              \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-mission-critical.jpg\" type=\"image\/jpg\"\u003e\n              \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-mission-critical.jpg\" alt=\"Mission-Critical Reliability for Business Travel\"\u003e\u003c\/picture\u003e\n          \u003c\/div\u003e\n        \u003c\/figure\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"d-flex justify-content-center w-100\"\u003e\n        \u003cdiv class=\"feature-scenarios\"\u003e\n          \u003cfigure class=\"overflow-hidden gl-rounded mb-0 w-100\"\u003e\n            \u003cdiv class=\"scenarios-content \"\u003e\n              \u003ch3 class=\"font-weight-bold text-light mb-0 mb-md-3 mb-lg-0\"\u003eHigh-Bandwidth Production in the Field\u003c\/h3\u003e\n            \u003c\/div\u003e\n            \u003cdiv class=\"scenarios-img\"\u003e\n              \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n                \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-high-bandwidth.jpg\" type=\"image\/jpg\"\u003e\n                \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-high-bandwidth.jpg\" alt=\"High-Bandwidth Production in the Field\"\u003e\u003c\/picture\u003e\n            \u003c\/div\u003e\n          \u003c\/figure\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"feature-scenarios\"\u003e\n          \u003cfigure class=\"overflow-hidden gl-rounded mb-0 w-100\"\u003e\n            \u003cdiv class=\"scenarios-content\"\u003e\n              \u003ch3 class=\"font-weight-bold text-light mb-0 mb-md-3 mb-lg-0\"\u003eProfessional-Grade Home Lab \u0026amp; Remote Work\n              \u003c\/h3\u003e\n            \u003c\/div\u003e\n            \u003cdiv class=\"scenarios-img\"\u003e\n              \u003cpicture class=\"overflow-hidden gl-rounded\"\u003e\n                \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-professiponal-grade.jpg\" type=\"image\/jpg\"\u003e\n                \u003cimg class=\"w-100 h-100\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000-professiponal-grade.jpg\" alt=\"Professional-Grade Home Lab \u0026amp; Remote Work\"\u003e\u003c\/picture\u003e\n            \u003c\/div\u003e\n          \u003c\/figure\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- openwrt --\u003e\n  \u003csection class=\"be10000-openwrt \" style=\"background-color: #000;\"\u003e\n    \u003cdiv class=\"container pt-5\"\u003e\n      \u003cdiv class=\"col-12 col-lg-10 text-light text-center mx-auto pt-5\"\u003e\n        \u003ch2 class=\"font-weight-bold be10000-h2\"\u003eUnlock Flexible, Customizable Networking\u003c\/h2\u003e\n        \u003cp\u003e\n          Built on \u003cb class=\"text-be10000\"\u003eOpenWrt 21.02 (Kernel Version 5.4.281)\u003c\/b\u003e with 1GB DDR4 RAM and 512MB NAND\n          Flash, Slate 7 Pro provides the freedom to evolve the router’s\n          capabilities through extensive plugin support and deep customization.\n        \u003c\/p\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"mt-n3\"\u003e\n        \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/be10000_openwrt-bg.jpg\" alt=\"Unlock Flexible, Customizable Networking\"\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003csection class=\"p-4 py-lg-5 product-nav-section bg-light\" id=\"reviews\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003ch2 class=\"font-weight-bold text-center pb-3\"\u003eProfessional Tech Press Insights\u003c\/h2\u003e\n      \u003cdiv class=\"row align-items-center my-3 bg-white m-0 gl-rounded\"\u003e\n        \u003cdiv class=\"col-12 col-lg-6 px-0 overflow-hidden\"\u003e\u003ca href=\"https:\/\/www.forbes.com\/sites\/marksparrow\/2026\/05\/31\/glinet-releases-the-worlds-first-true-tri-band-wi-fi-7-travel-router\/\" target=\"_blank\"\u003e\u003cimg class=\"img-fluid gl-rounded-left\" src=\"https:\/\/imageio.forbes.com\/specials-images\/imageserve\/6a197d3042d96ed24034c63e\/Slate-7-Pro-used-in-airport-setting\/960x0.jpg?format=jpg\u0026amp;width=1440\" alt=\"forbes\"\u003e\u003c\/a\u003e\u003c\/div\u003e\n        \u003cdiv class=\"col-12 col-lg-6 px-lg-5 p-5\"\u003e\n\u003ci class=\"fa-solid fa-quote-left fa-2x my-2\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\n          \u003ch5 class=\"font-weight-light\" style=\"line-height:1.8rem\"\u003eWhether it’s operating under strict network controls\n            or the user wants greater privacy with uninterrupted access, the Slate 7 Pro is the way to do that,\n            especially when on the move or working away from home or office.\u003c\/h5\u003e\n\u003ca href=\"https:\/\/www.forbes.com\/sites\/marksparrow\/2026\/05\/31\/glinet-releases-the-worlds-first-true-tri-band-wi-fi-7-travel-router\/\" target=\"_blank\"\u003e\u003cimg class=\"img-fluid pt-4\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-axt1800\/logo_forbes.png\" alt=\"forbes\"\u003e\u003c\/a\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003c!-- Product Reviews from Youtubers --\u003e\n  \u003csection class=\"container-fluid p-4 py-lg-5 product-nav-section\" id=\"reviews\"\u003e\n    \u003ch2 class=\"font-weight-bold text-dark text-center pb-3\"\u003eProduct Reviews from Youtubers\u003c\/h2\u003e\n    \u003cdiv id=\"youtube-playlist-container\"\u003e\n      \u003cdiv class=\"row justify-content-center\"\u003e\n        \u003cdiv class=\"col-11 col-lg-7 col-xl-8 px-0\" id=\"ytvideoPlayer\"\u003e\n          \u003cdiv class=\"card border-0 h-100\" style=\"background-color:#000\"\u003e\u003ciframe id=\"playlistVideo\" src=\"https:\/\/www.youtube.com\/embed\/e4cgOEQgXVs\" frameborder=\"0\" allowfullscreen=\"\" style=\"aspect-ratio:16\/9;width:100%\"\u003e\u003c\/iframe\u003e\u003c\/div\u003e\n        \u003c\/div\u003e\n        \u003cdiv class=\"col-11 col-lg-5 col-xl-4 px-0\" id=\"ytplaylist\"\u003e\n          \u003cdiv class=\"card border-0 h-100\" style=\"background-color:#000\"\u003e\n            \u003ch5 onclick=\"showYtPlayList()\" class=\"text-light text-center py-3\"\u003eSlate 7 Pro (GL-BE10000) Reviews\n              \u003cspan id=\"ytListBtn\"\u003e\u003ci id=\"ytListBtnIcon\" class=\"fa fa-chevron-down\" aria-hidden=\"true\"\u003e\u003c\/i\u003e\u003c\/span\u003e\n            \u003c\/h5\u003e\n            \u003cul id=\"ytPlayListUl\"\u003e\n              \u003cli\u003e\n\u003cimg src=\"https:\/\/img.youtube.com\/vi\/houYyD7yUVA\/maxresdefault.jpg\" alt=\"Testing The New Slate 7 Pro! @GLTechnologies\" onclick='changeVideo(\"houYyD7yUVA\")'\u003e\n                \u003cdiv class=\"title-container\"\u003e\n                  \u003cp class=\"video-title\"\u003eTesting The New Slate 7 Pro! @GLTechnologies\u003c\/p\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n              \u003cli\u003e\n\u003cimg src=\"https:\/\/img.youtube.com\/vi\/9gOM1M7YHbg\/maxresdefault.jpg\" alt=\"Doom on the Slate 7 Pro Travel Router - GL-BE10000 GL-iNet\" onclick='changeVideo(\"9gOM1M7YHbg\")'\u003e\n                \u003cdiv class=\"title-container\"\u003e\n                  \u003cp class=\"video-title\"\u003eDoom on the Slate 7 Pro Travel Router - GL-BE10000 GL-iNet\u003c\/p\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n              \u003cli\u003e\n\u003cimg src=\"https:\/\/img.youtube.com\/vi\/e4cgOEQgXVs\/maxresdefault.jpg\" alt=\"Gl.iNet Slate 7 Pro Should You Buy - 5 PROs and 5 CONs!\" onclick='changeVideo(\"e4cgOEQgXVs\")'\u003e\n                \u003cdiv class=\"title-container\"\u003e\n                  \u003cp class=\"video-title\"\u003eGl.iNet Slate 7 Pro Should You Buy - 5 PROs and 5 CONs!\u003c\/p\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n              \u003cli\u003e\n\u003cimg src=\"https:\/\/img.youtube.com\/vi\/iPIPBS68qGg\/maxresdefault.jpg\" alt=\"\" onclick='changeVideo(\"iPIPBS68qGg\")'\u003e\n                \u003cdiv class=\"title-container\"\u003e\n                  \u003cp class=\"video-title\"\u003eGl.iNet Slate 7 Pro Travel Router - SHOULD YOU BUY?\u003c\/p\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n              \u003cli\u003e\n\u003cimg src=\"https:\/\/img.youtube.com\/vi\/7ejvqPIwGUc\/maxresdefault.jpg\" alt=\"6 New GL.iNet Devices You NEED to See from CES 2026\" onclick='changeVideo(\"7ejvqPIwGUc\")'\u003e\n                \u003cdiv class=\"title-container\"\u003e\n                  \u003cp class=\"video-title\"\u003e6 New GL.iNet Devices You NEED to See from CES 2026\u003c\/p\u003e\n                \u003c\/div\u003e\n              \u003c\/li\u003e\n              \u003cdiv class=\"mt-2\"\u003e\u003ca class=\"btn btn-outline-light btn-block\" target=\"_blank\" href=\"https:\/\/youtube.com\/playlist?list=PLWQT710fjyEYTTl1Uf0Gnrn4TPVzeuJLr\u0026amp;si=2hERMRlIwIOqDlYO\"\u003eView\n                  More\u003c\/a\u003e\u003c\/div\u003e\n            \u003c\/ul\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- What Beta Tester are Saying --\u003e\n  \u003csection class=\"section-customer-review px-0 py-4 bg-light\"\u003e\n    \u003cdiv class=\"container-fluid px-0 py-4 py-lg-5\"\u003e\n      \u003ch2 class=\"text-center font-weight-bold mb-4\"\u003eWhat Beta Testers are Saying\u003c\/h2\u003e\n\n      \u003cdiv class=\"tiny-slider-container-beta-tester-review pb-3\"\u003e\n        \u003cdiv class=\"tiny-slider-beta-tester-review\"\u003e\n\n          \u003cdiv class=\"tiny-slider-item-beta-tester-review\"\u003e\n            \u003cdiv class=\"tiny-slider-review-card\"\u003e\n              \u003cdiv class=\"row gl-rounded\"\u003e\n                \u003cdiv class=\"card-image col-md-12 col-lg-6 p-0\"\u003e\n                  \u003cimg class=\"\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/beta-tester\/be10000-lupuse.jpg\" alt=\"LupusE\"\u003e\n                \u003c\/div\u003e\n\n                \u003cdiv class=\"col-md-12 col-lg-6 p-4\"\u003e\n                  \u003ch4 class=\"text-info\"\u003e\u003ci class=\"fa-solid fa-quote-left\"\u003e\u003c\/i\u003e\u003c\/h4\u003e\n                  \u003cp class=\"font-weight-bold\"\u003e\n                    The display is a pro. Compared to the small display of the Slate 7, the QR Code can be scanned with\n                    every phone, even from a photo of the screen. It is small and travel friendly, I like the new power\n                    supply.\n                  \u003c\/p\u003e\n                  \u003cp\u003e\n                  \u003c\/p\u003e\n                  \u003ch5 class=\"text-muted pt-3\"\u003e@LupusE\u003c\/h5\u003e\n                \u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"tiny-slider-item-beta-tester-review\"\u003e\n            \u003cdiv class=\"tiny-slider-review-card\"\u003e\n              \u003cdiv class=\"row gl-rounded\"\u003e\n                \u003cdiv class=\"card-image col-md-12 col-lg-6 p-0\"\u003e\n                  \u003cimg class=\"\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/beta-tester\/be10000-darkhawk.jpg\" alt=\"DarkHawk\"\u003e\n                \u003c\/div\u003e\n\n                \u003cdiv class=\"col-md-12 col-lg-6 p-4\"\u003e\n                  \u003ch4 class=\"text-info\"\u003e\u003ci class=\"fa-solid fa-quote-left\"\u003e\u003c\/i\u003e\u003c\/h4\u003e\n                  \u003cp class=\"font-weight-bold\"\u003e\n                    I think the hardware is great...the device is very sturdy and has a nicely sized screen.\n                  \u003c\/p\u003e\n                  \u003cp\u003e\n                  \u003c\/p\u003e\n                  \u003ch5 class=\"text-muted pt-3\"\u003e@DarkHawk\u003c\/h5\u003e\n                \u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"tiny-slider-item-beta-tester-review\"\u003e\n            \u003cdiv class=\"tiny-slider-review-card\"\u003e\n              \u003cdiv class=\"row gl-rounded\"\u003e\n                \u003cdiv class=\"card-image col-md-12 col-lg-6 p-0\"\u003e\n                  \u003cimg class=\"\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/beta-tester\/be10000-tharty.jpg\" alt=\"tharty\"\u003e\n                \u003c\/div\u003e\n\n                \u003cdiv class=\"col-md-12 col-lg-6 p-4\"\u003e\n                  \u003ch4 class=\"text-info\"\u003e\u003ci class=\"fa-solid fa-quote-left\"\u003e\u003c\/i\u003e\u003c\/h4\u003e\n                  \u003cp class=\"font-weight-bold\"\u003e\n                    The Slate 7 Pro isn't just the perfect travel router, it's an absolute powerhouse capable of driving\n                    my home network with ease!\n                  \u003c\/p\u003e\n                  \u003cp\u003e\n                  \u003c\/p\u003e\n                  \u003ch5 class=\"text-muted pt-3\"\u003e@tharty\u003c\/h5\u003e\n                \u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n          \u003cdiv class=\"tiny-slider-item-beta-tester-review\"\u003e\n            \u003cdiv class=\"tiny-slider-review-card\"\u003e\n              \u003cdiv class=\"row gl-rounded\"\u003e\n                \u003cdiv class=\"card-image col-md-12 col-lg-6 p-0\"\u003e\n                  \u003cimg class=\"\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-be10000\/beta-tester\/be10000-mniko_tech.jpg\" alt=\"mniko_tech\"\u003e\n                \u003c\/div\u003e\n\n                \u003cdiv class=\"col-md-12 col-lg-6 p-4\"\u003e\n                  \u003ch4 class=\"text-info\"\u003e\u003ci class=\"fa-solid fa-quote-left\"\u003e\u003c\/i\u003e\u003c\/h4\u003e\n                  \u003cp class=\"font-weight-bold\"\u003e\n                    Hardware quality is excellent and thermal behaviour is well controlled even under heavy load.\n                  \u003c\/p\u003e\n                  \u003cp\u003e\n                  \u003c\/p\u003e\n                  \u003ch5 class=\"text-muted pt-3\"\u003e@mniko_tech\u003c\/h5\u003e\n                \u003c\/div\u003e\n              \u003c\/div\u003e\n            \u003c\/div\u003e\n          \u003c\/div\u003e\n\n\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n\n      \u003cdiv class=\"tiny-slider-controls circle-controls m-auto text-center pt-2 pt-lg-4\" id=\"tiny-slider-controls-beta-tester-review\" aria-label=\"Carousel Navigation\" tabindex=\"0\"\u003e\n        \u003ca class=\"prev mr-2\" data-controls=\"prev\" aria-controls=\"customize\" tabindex=\"-1\"\u003e\n          \u003ci class=\"fas fa-chevron-left\"\u003e\u003c\/i\u003e\n        \u003c\/a\u003e\n        \u003ca class=\"next\" data-controls=\"next\" aria-controls=\"customize\" tabindex=\"-1\"\u003e\n          \u003ci class=\"fas fa-chevron-right\"\u003e\u003c\/i\u003e\n        \u003c\/a\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003c!-- Model Comparison --\u003e\n  \u003csection class=\"px-2 px-lg-4 py-4 py-lg-5 model-comparison\" id=\"\"\u003e\n    \u003cdiv class=\"container-lg\"\u003e\n      \u003cdiv class=\"text-center\"\u003e\n        \u003ch2 class=\"font-weight-bold\"\u003eModel Comparison\u003c\/h2\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"row justify-content-center text-center pt-3 pb-2 pb-md-3\"\u003e\n        \u003cdiv class=\"col-5 col-md-4\"\u003e\n          \u003cimg class=\"product-img\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-table\/table_be3600.png\" alt=\"Slate 7 (GL-BE3600)\"\u003e\n          \u003cp class=\"font-weight-bold mb-1\"\u003e\n            Slate 7 \/ GL-BE3600\n          \u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-1 col-md-3 align-items-center d-flex px-0 px-md-3\"\u003e\n          \u003ch4 class=\"m-auto\"\u003eVS\u003c\/h4\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4\"\u003e\n          \u003cimg class=\"product-img\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-table\/table_be10000.png\" alt=\"Slate 7 Pro (GL-BE10000)\"\u003e\n          \u003cp class=\"font-weight-bold\"\u003e\n            Slate 7 Pro \/ GL-BE10000\n          \u003c\/p\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003eQualcomm, Quad-core @1.1 GHz\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_cpu.svg\" alt=\"CPU\"\u003e\n            CPU\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_cpu.svg\" alt=\"CPU\"\u003e\n            CPU\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003eMediaTek, Quad-core @2.0 GHz\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003e2.22 inch\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_display-screen.svg\" alt=\"Touchscreen Size\"\u003e\n            Touchscreen Size\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_display-screen.svg\" alt=\"Touchscreen Size\"\u003e\n            Touchscreen Size\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003e2.8 inch\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003e\n            688Mbps(2.4 GHz), 2882Mbps(5 GHz)\n          \u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_ethernet-speed.svg\" alt=\"Ethernet Speed\"\u003e\n            Wi-Fi Speed\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_ethernet-speed.svg\" alt=\"Ethernet Speed\"\u003e\n            Wi-Fi Speed\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003e\n              688Mbps (2.4 GHz), 2882Mbps (5 GHz), 5764Mbps (6 GHz)\n            \u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003eMax.385 Mbps\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_openvpn.svg\" alt=\"OpenVPN-DCO (Via Ethernet)\"\u003e\n            OpenVPN-DCO Speed\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_openvpn.svg\" alt=\"OpenVPN-DCO (Via Ethernet)\"\u003e\n            OpenVPN-DCO Speed\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003eMax.1000 Mbps\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003eMax.490 Mbps\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_wireguard.svg\" alt=\"WireGuard® Speed\"\u003e\n            WireGuard\u003csup\u003e®\u003c\/sup\u003e Speed\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_wireguard.svg\" alt=\"WireGuard® Speed\"\u003e\n            WireGuard\u003csup\u003e®\u003c\/sup\u003e Speed\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003eMax.1100 Mbps\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003e\u003ci class=\"fa-solid fa-hyphen\"\u003e\u003c\/i\u003e\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_vpn.svg\" alt=\"VPN Obfuscation\"\u003e\n            VPN Obfuscation\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_vpn.svg\" alt=\"VPN Obfuscation\"\u003e\n            VPN Obfuscation\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003e\u003ci class=\"fa-solid fa-check\"\u003e\u003c\/i\u003e\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003e\u003ci class=\"fa-solid fa-hyphen\"\u003e\u003c\/i\u003e\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_dpi.svg\" alt=\"DPI Integration\"\u003e\n            DPI Integration\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_dpi.svg\" alt=\"DPI Integration\"\u003e\n            DPI Integration\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003e\u003ci class=\"fa-solid fa-check\"\u003e\u003c\/i\u003e\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0\"\u003e\n          \u003cp\u003eUSB 3.0, 5V\/1.5A\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_usb-port.svg\" alt=\"USB Port\"\u003e\n            USB Port\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"http:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_usb-port.svg\" alt=\"USB Port\"\u003e\n            USB Port\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003eUSB 3.0, 5V\/2A\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n      \u003cdiv class=\"comparison-detail row justify-content-center align-content-center text-center pb-md-0\"\u003e\n        \u003cdiv class=\"col-5 col-md-4 order-1 order-md-0 border-0\"\u003e\n          \u003cp\u003e130 x 91 x 34mm \/ 295g\u003c\/p\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-12 col-md-3 order-0 order-md-1\"\u003e\n          \u003ch5 class=\"d-inline-block w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_dimensions.svg\" alt=\"Dimension \/ Weight\"\u003e\n            Dimension \/ Weight\n          \u003c\/h5\u003e\n          \u003ch5 class=\"d-inline-block d-md-none w-50 font-weight-bold mx-n1\"\u003e\n            \u003cimg class=\"d-block d-md-none mx-auto mb-3\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/compare\/icon_dimensions.svg\" alt=\"Dimension \/ Weight\"\u003e\n            Dimension \/ Weight\n          \u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"col-5 col-md-4 order-2 order-md-2 offset-1 offset-md-0 border-0\"\u003e\n          \u003cdiv class=\"position-relative d-inline-block p-0\"\u003e\n            \u003cp\u003e130 x 91 x 36mm \/ 328g\u003c\/p\u003e\n          \u003c\/div\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003csection class=\"product-specs-section py-4 py-lg-5 bg-light product-nav-section\" id=\"specs\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv class=\"row justify-content-center\"\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_wifi7.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_wifi7.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_wifi7.png\" alt=\"Tri-band Wi-Fi 7\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eTri-band Wi-Fi 7\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_touch-screen.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_touch-screen.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_touch-screen.png\" alt=\"Touchscreen\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eTouchscreen\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_dpi.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_dpi.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_dpi.png\" alt=\"DPI\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eDPI\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_multi-link-operation_tri-band.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_multi-link-operation_tri-band.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_multi-link-operation_tri-band.png\" alt=\"Multi-Link Operation\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eMulti-Link\u003cbr\u003eOperation\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_vpn.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_vpn.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_vpn.png\" alt=\"VPN Client Server\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eVPN Client \/\u003cbr\u003eServer\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_openwrt.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_openwrt.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_openwrt.png\" alt=\"OpenWrt Support\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eOpenWrt \u003cbr\u003eSupport\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_2.5gbps-ports_x2.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_2.5gbps-ports_x2.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_2.5gbps-ports_x2.png\" alt=\"Dual 2.5G Ethernet Ports\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003eDual 2.5G\u003cbr\u003eEthernet Ports\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n        \u003cdiv class=\"text-dark col-6 col-md-4 col-lg-3 px-0 pb-3 text-center\"\u003e\n          \u003cpicture\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_pd-power-supply.webp\" type=\"image\/webp\"\u003e\n            \u003csource srcset=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_pd-power-supply.png\" type=\"image\/png\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/general\/product-icon\/icon_pd-power-supply.png\" alt=\"PD Power Supply\"\u003e\u003c\/source\u003e\u003c\/picture\u003e\n          \u003ch5 class=\"font-weight-bold\"\u003ePD Power Supply\u003c\/h5\u003e\n        \u003c\/div\u003e\n\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n\n  \u003csection class=\"py-4 py-lg-5\"\u003e\n    \u003cdiv class=\"container\"\u003e\n      \u003cdiv class=\"row justify-content-center\"\u003e\n        \u003cdiv class=\"col-12\"\u003e\n          \u003ch2 class=\"font-weight-bold text-left pb-3\"\u003eSpecifications\u003c\/h2\u003e\n          \u003c!--\n          \u003cdiv class=\"text-center\"\u003e\n            \u003cimg class=\"img-fluid\" src=\"https:\/\/static.gl-inet.com\/www\/images\/products\/gl-mt5000\/mt5000_interface.png\"\u003e\n          \u003c\/div\u003e\n          --\u003e\n\n          \u003ctable class=\"table\"\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eInterface\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e\n                1 x 2.5G WAN Ethernet port\u003cbr\u003e\n                1 x 2.5G LAN Ethernet port\u003cbr\u003e\n                1 x 2.8” Color LCD Touchscreen\u003cbr\u003e\n                1 x USB 3.0 Type-C port\u003cbr\u003e\n                1 x Type-C Power port\u003cbr\u003e\n                1 x Reset button\u003cbr\u003e\n                1 x Toggle button\n              \u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eCPU\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003eMediaTek, Quad-core @2.0GHz\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eMemory \/ Storage\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003eDDR4 1GB \/ NAND Flash 512MB\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eProtocol\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003eIEEE 802.11a\/b\/g\/n\/ac\/ax\/be\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eWi-Fi Speed\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e688Mbps (2.4GHz), 2882Mbps (5GHz), 5764Mbps (6GHz)\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eAntennas\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e2 x foldable external Wi-Fi antennas\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eEthernet Speed\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e10\/100\/1000\/2500Mbps\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003ePower Input\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003eUSB PD 5V\/3A, 9V\/3A, 12V\/2.5A\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003ePower Consumption\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e \u0026lt; 20W (without USB)\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eOperating Temperature\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e0 ~ 40°C (32 ~ 104°F)\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eStorage Temperature\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e-20 ~ 70°C (-4 ~ 158°F)\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd class=\"td-left\"\u003eDimension \/ Weight\u003c\/td\u003e\n              \u003ctd class=\"td-right\"\u003e130 x 91 x 36mm \/ 328g\u003c\/td\u003e\n            \u003c\/tr\u003e\n            \u003ctr\u003e\n              \u003ctd\u003eTools \u0026amp; Downloadables\u003c\/td\u003e\n              \u003ctd\u003e\n\u003ca role=\"button\" class=\"btn-underline\" href=\"\/products\/datasheet\/\"\u003e\u003ci class=\"fas fa-download\" aria-hidden=\"true\"\u003e\u003c\/i\u003e Datasheet\u003c\/a\u003e\n\u003cspan class=\"mx-2\"\u003e|\u003c\/span\u003e\n\u003ca role=\"button\" class=\"btn-underline\" href=\"https:\/\/dl.gl-inet.com\/router\/be10000\" target=\"_blank\"\u003e\u003ci class=\"fas fa-download\" aria-hidden=\"true\"\u003e\u003c\/i\u003e Firmware\u003c\/a\u003e\n\u003cspan class=\"mx-2\"\u003e|\u003c\/span\u003e\n\u003ca role=\"button\" class=\"btn-underline\" href=\"\/app\/\" target=\"_blank\"\u003e\u003ci class=\"fas fa-download\" aria-hidden=\"true\"\u003e\u003c\/i\u003e App\u003c\/a\u003e\n\u003cspan class=\"mx-2\"\u003e|\u003c\/span\u003e\n\u003ca role=\"button\" class=\"btn-underline\" href=\"\/support\/gl-be10000\/\" target=\"_blank\"\u003e\u003ci class=\"fas fa-file-alt\" aria-hidden=\"true\"\u003e\u003c\/i\u003e Tutorials\u003c\/a\u003e\n\u003cspan class=\"mx-2\"\u003e|\u003c\/span\u003e\n\u003ca role=\"button\" class=\"btn-underline\" href=\"https:\/\/www.dropbox.com\/scl\/fo\/z3cj6ju0yd3yrt8rv4eez\/ABE54iq8hdjwKKr_OVyrSko?rlkey=b7qkzuij4kcanmeufoswxwb50\u0026amp;st=2awguss2\u0026amp;dl=0\" target=\"_blank\"\u003e\u003ci class=\"fas fa-download\" aria-hidden=\"true\"\u003e\u003c\/i\u003e Media Kit\u003c\/a\u003e\n\u003c\/td\u003e\n            \u003c\/tr\u003e\n          \u003c\/table\u003e\n        \u003c\/div\u003e\n      \u003c\/div\u003e\n    \u003c\/div\u003e\n  \u003c\/section\u003e\n  \u003cscript\u003e\n    document.addEventListener('DOMContentLoaded', function () {\n      \/\/ 获取所有滑块容器元素\n      var allTinySliderContainersGeneral1122ByClass = document.getElementsByClassName('tiny-slider-container-general-1122')\n\n      \/\/ 遍历每个容器，单独初始化滑块\n      if (allTinySliderContainersGeneral1122ByClass.length \u003e 0) {\n        Array.from(allTinySliderContainersGeneral1122ByClass).forEach(function (container, index) {\n          \/\/ 获取当前容器内的 tiny-slider-general-1122 元素\n          var sliderElement = container.querySelector('.tiny-slider-general-1122')\n          var controlsElement = container.querySelector('.tiny-slider-general-1122-controls')\n\n          if (sliderElement) {\n            tns({\n              container: sliderElement, \/\/ 使用当前DOM元素作为容器\n              loop: false,\n              swipeAngle: false,\n              items: 1,\n              center: false,\n              slideBy: 1,\n              nav: false,\n              autoplay: false,\n              speed: 400,\n              autoplayButtonOutput: false,\n              autoHeight: false,\n              mouseDrag: true,\n              controlsContainer: controlsElement || false, \/\/ 使用找到的 controls 容器\n              responsive: {\n                640: {\n                  items: 1\n                },\n                768: {\n                  items: 1\n                },\n                991: {\n                  items: 2\n                },\n                1199: {\n                  items: 2\n                }\n              }\n            })\n          }\n        })\n      }\n\n    });\n  \u003c\/script\u003e\n\u003c\/main\u003e","brand":"GL.iNet","offers":[{"title":"CN warehouse - NA Version","offer_id":48435879510199,"sku":"GL-BE10000-US","price":239.99,"currency_code":"USD","in_stock":true},{"title":"CN warehouse - EU Version","offer_id":48435879542967,"sku":"GL-BE10000-EU","price":239.99,"currency_code":"USD","in_stock":true},{"title":"CN warehouse - AU Version","offer_id":48435879575735,"sku":"GL-BE10000-AU","price":239.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0711\/7733\/9063\/files\/travelrouter-be10000.png?v=1774430262","url":"https:\/\/www.gl-inet.com\/products\/gl-be10000","provider":"GL.iNet","version":"1.0","type":"link"}
