Introducing Comet PoE (GL-RM1PE) Remote KVM over PoE
GL.iNet Comet PoE (GL-RM1PE) Remote KVM over PoE
Hong Kong [Sep 17, 2025] GL.iNet introduces the Comet PoE (GL-RM1PE) KVM over PoE. Now featuring Power over Ethernet (PoE) connectivity and increased eMMC capacity to 32GB, giving extended capabilities to IT professionals.
With PoE capability, the Comet PoE offers simplified, single-cable installation for power and connectivity, enabling deployment in hard-to-reach locations without the need for separate power sources. The upgraded eMMC storage of 32GB compared to the Comet (GL-RM1)’s 8GB supports local logging, image/video capture, firmware backups, and custom applications, significantly enhancing the flexibility and performance of remote access setups.
Comet PoE Ports
Key Features
  • Power over Ethernet (PoE): By integrating PoE support, the Comet PoE now eliminates the need for additional power adapters, simplifying deployment and reducing cable clutter in complex environments. IT professionals can easily power the device through the same ethernet cable used for data transmission, creating a cleaner, more efficient setup.
  • 32GB eMMC: Increased onboard storage making it ideal for larger OS deloyments and data applications.
  • 4K Video Low-Latancy Control: Experience crisp 4K@30FPS video remote operation with H.264 encoding delivering latency as low as 30ms.
  • Tailscale Support: With native Tailscale integration, bind to your Tailscale virtual network for easy remote access.
  • Remote Cloud Control: Web-based cloud remote control on glkvm.com. Avaliable on Windows, macOS or Linux, gain remote access to your Comet PoE without any additional application installs.
  • Two-Way Audio: Listen and communicate remotely whether to troubleshoot or for live collaboration.
  • One-time Purchase: No subscription fees, ever
  • Self-Hosted Server - Self-host and deploy your own cloud service. Check out our GitHub repository at https://github.com/gl-inet/glkvm-cloud.
Whether for data centers, industrial systems, remote offices, or disaster recovery setups, the Comet PoE (GL-RM1PE) offers a secure, low-power solution that simplifies infrastructure management while enhancing performance and security.
Where to Buy Comet PoE
Comet PoE is available for purchase through GL.iNet’s official stores and authorized distributors worldwide. Customers can order directly from the GL.iNet website to ensure they receive genuine products with full support and warranty. Additionally, Comet PoE is available on leading e-commerce platforms and select resellers, making it easy for professionals and businesses to access this powerful remote KVM solution.
For the latest availability, pricing, and purchasing options, visit GL.iNet’s official product page and experience the next level of secure, real-time remote device management today!
KVM over PoE
Shop Now
About GL.iNet
GL.iNet builds network hardware and software solutions that bring affordable and secure network connectivity to families and businesses all over the world. We work with a wide range of industries, solving everyday internet problems in offices, and providing complex networking solutions such as smart buildings and IoT Networks. At GL.iNet, We believe all successful businesses build upon a strong and secure foundation, which is why our highest priority is perfecting network security and reliability for our partners.
