GL.iNet Launches Slate 7 Pro, World's First True Tri-band Wi-Fi 7 Travel Router
GL.iNet Slate 7 Pro (GL-BE10000) Tri-band Wi-Fi 7 Travel Router
Hong Kong, May 15, 2026 — GL.iNet, a leading provider of OpenWrt-based networking and remote access solutions, announces the launch of the Slate 7 Pro (GL-BE10000), the upgraded version of the Slate 7 (GL-BE3600). This travel router is first of its kind to achieve tri-band Wi-Fi aggregration with wireless speeds up to 10 Gbps, rivaling performance that of full-size home routers. Powered by advanced Deep Packet Inspection (DPI), it improves network visibility while strengthening privacy and transmission security. Combining premium performance with intelligent control in a travel-ready design, Slate 7 Pro is built for professionals and power users who demand uncompromising networking on the move.
True Tri-band Wi-Fi 7 Performance
Slate 7 Pro supports simultaneous tri-band operation across 2.4 GHz, 5 GHz, and 6 GHz, delivering high-speed, low-latency connectivity across diverse network environments. Featuring Multi-Link Operation (MLO), enhanced OFDMA, 4KQAM, and preamble puncturing, it maintains high throughput and stable performance even in congested networks, ensuring smooth, reliable connections for work, streaming, and real-time applications.
Intuitive 2.8-inch Touchscreen Control
Slate 7 Pro features a built-in 2.8-inch touchscreen that makes network management simple and intuitive. No need to pull out a phone or laptop to setup Wi-Fi, just tap the screen to monitor connection status in real time, switch VPN profiles instantly, share Wi-Fi via QR code, and complete basic network configuration with ease.
Enhanced VPN Performance
Powered by a high-performance quad-core 2.0 GHz CPU, the Slate 7 Pro delivers faster VPN throughput and enhanced multitasking capabilities. With full support for WireGuard® and OpenVPN (DCO support), it achieves up to 1100 Mbps and 1000 Mbps, respectively. Whether accessing a home lab remotely, transferring large files, or securing the entire local network, it ensures smooth, responsive performance with minimal latency.
Advanced Deep Packet Inspection Protection
Slate 7 Pro leverages DPI technology to proactively identify and block malicious traffic like gambling websites and malware, building a robust security shield for the entire local network. Beyond automated protection, it also enables granular manual controls, allowing you to manage specific applications, domains, or IP addresses for more precise and personalized network governance.
Integrated VPN Obfuscation
Slate 7 Pro features integrated VPN obfuscation that masks VPN traffic patterns to help bypass DPI detection. By concealing VPN signatures, it reduces the risk of throttling, blocking, or network restrictions, maintaining a stable and reliable encrypted connection. Whether operating under strict network controls or seeking greater privacy with uninterrupted access, Slate 7 Pro ensures a discreet and smooth online experience.
Availability
Slate 7 Pro is currently available for pre-order for $189.90 through GL.iNet’s official webite. For more details, please contact: marketing@gl-inet.com
About GL.iNet
Founded in 2010, GL.iNet is a leading provider of OpenWrt-based routers and innovative remote networking solutions. From compact travel routers to cutting-edge remote KVMs, GL.iNet delivers award-winning networking technology designed for performance and security.
GL.iNet gives people and organizations the power to connect with confidence. By putting control in the hands of users, GL.iNet supports the productivity and collaboration that shape a Good Life.
