☀️ Summer Deals Are Here – Save Up to 20% | Shop Now ➜
gl-inet products GL-MT300N
GL-MT300N
  • Powered by MTK 7620N 580Mhz SoC
  • 300Mbps high speed
  • Small, light, easy to use
  • OpenWrt pre-installed
  • IO ports reserved for function extending
CPUMTK 7620N @580Mhz
Memory/StorageDDR1 64MB/ FLASH 16MB
Interfaces1 WAN, 1 LAN, 1 USB2.0, 1 micro USB (power), 1 Reset button
Frequency2.4GHz
Transmission rate300Mbps
Max Tx Power20dBm
ProtocolIEEE 802.11b/g/n
External Storage supportFAT32/EXFAT/EXT4/EXT3/EXT2/NTFS
Webcam supportMJPG, YUV
DIY featuresUART, 4GPIO, 3.3V & 5V power port
External antenna supportYes (Optional)
PoE supportYes (Optional)
Power input5V/1A
Power consumption<2W
Dimension, Weight58*58*25mm, 39g
GL-MT300N Docs
Firmware and User Guide can be download blow:
Router ModelDefault ReleasePre-releaseOpenWrt OnlyTorUser Guide
GL-MT300NDownloadDownloadDownloadDownloadDownload
The "Default Release" is recommended for most users.
