🛍️ Amazon Prime Day 2025 – Save Up to 55% on Bestsellers | Explore Deals ➜
GL-MiFi
GL-MiFi 4G Smart Router
MEET GL-MiFi
Industrial Grade 4G LTE to Wi-Fi Designed for Privacy Protection
Discontinued
4G Smart Router
GL-MiFi has a mini size and travel friendly, which is applicable for small Enterprise, Business and Family scenarios. It's your best choice that provide internet surfing together with wireless.
PCIe 4G LTE Modem
128GB Max MicroSD
Built-in 5000mAh Battery
Learn More View Online Guide
Your Portable Travel Mate
  • 4G LTE to Wi-Fi Converter: sharing a 4G mobile broadband Internet connection from a micro SIM card
  • Larger Storage and Extendibility: further extended using the external microSD slot and USB sticks
  • Open Source and Programmable:: pre-installed with an OpenVPN client which works with 20+ VPN service providers
MiFi Scene
ENJOY REMOTE WORKING
Portable Usage for Travel, Home, and Business
GL-MiFi brings all of your workplaces under a digital roof with a secure VPN. It can connect your global offices with GL-MiFi so the staff from all locations can communicate with teach other remotely and all data is shared securely. You don't need to think about how your workplaces might change your network preference.
LARGE STORAGE COMPATIBILITY
Share Files Across Devices
GL-MiFi has a built-in MicroSD slot that supports maximum 128GB MicroSD card. With the extra storage, you can create a local network drive in order to store data and share them with your laptop and other compatible devices as long as it is connected to the Wi-Fi.
Card Slot
Interchangeable Module
CUSTOMIZE YOUR INTERNET USER CASE
Interchangeable Module Tailored to Your Needs
GL-MiFi router is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules from various brands.
Work or Play Securely Anywhere, and Anytime
Apart from its powerful built-in firewall, microuter also supports OpenVPN, WireGuard and customized DNS server in order to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely and remotely as if you were at home.
WireGuard
Max. 35Mbps
OpenVPN
Max. 7Mbps
Web UI
Cloudflare
PREVENT MAN-IN-THE-MIDDLE ATTACKS
DNS Encryption with Cloudflare
Opal supports Cloudflare DNS over TLS, it keeps users' online actions secure and private. DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS). The goal is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Cloudflare X GL.iNet
OpenWrt Pre-installed
OpenWrt
Pre-installed
4G LTE
Module
Built-in
Battery
External
Storage
VPN Client/Server
VPN Client /
Server
Specifications
Interface1 x WAN Ethernet Port
1 x LAN Ethernet Port
1 x USB 2.0 port
1 x MicroSD card slot
1 x SIM card slot
1 x Reset button
CPUAR9331, @400MHz Soc
Memory / StorageDDR2 64MB / FLASH 16MB
4G AntennaInternal full-band antenna (700MHz ~ 2.7GHz)
ProtocolIEEE 802.11b/g/n
Wi-Fi AntennasInternal 2dBi
Wi-Fi Speed150Mbps (2.4GHz)
Ethernet Speed10/100Mbps
LEDsPower supply indicator, WAN status indicator, LAN status indicator,
Wireless status indicator, 3G/4G status indicator,
Battery power indicator (with battery version)
Power SupplyMicro USB, 5V/2A
Power Consumption<3W
Operating Temperature0 ~ 40°C (32 ~ 104°F)
Storage Temperature-20 ~ 60°C (-4 ~ 140°F)
Dimension / Weight105 x 72 x 27mm / 170g
Tools & Downloadables Firmware | App | Tutorials
Looking for Bulk Purchase?
Contact Our Sales Manager
