Keeping Your Network Private During Travels
Slate Plus (GL-A1300) is a Wi-Fi 5 pocket-sized travel router with a powerful CPU optimized for network stability and processing VPN encryption efficiently. It includes our latest security features and runs on the latest OpenWrt operating system. It is designed for frequent travelers who have a heavy demand on using VPN networks.
VPN speed of 28 Mbps (OpenVPN); 170 Mbps (WireGuard®)
A highly stable and powerful IPQ4018 @710MHz CPU
Runs on OpenWrt 21.02
Slate Plus runs on the latest OpenWrt 21.02 operating system, with mass device connection capabilities, and significantly reduced signal interference. You can customize the router and install applications based on your preferences.
Fast and Secure Browsing with VPN Encryption
Supporting OpenVPN and WireGuard®, Slate Plus allows you to browse securely when on public wi-fi, work remotely when abroad, and access geo-restricted sites. Set up your VPN on the admin panel and shield the network on all connected devices. With saved settings, you won't have to set it up again every time.
WireGuardOpenVPN
Block Ads & Tracking for Free
AdGuard Home Ready on Router
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit CloudflareThe Evolution of GL.iNet's Travel Routers
2022
Slate Plus
(GL-A1300)
Slate Plus
(GL-A1300)
Our most powerful Wi-Fi 5 travel router since Slate. Supports OpenWrt 21.02 to provide unlimited ready-to-install packages.
Specification
Interface | 1 x WAN Ethernet port 2 x LAN Ethernet ports 1 x USB 3.0 port 1 x Type-C Power port 1 x Reset button 1 x Toggle button |
CPU | IPQ4018, Quad Core@717MHz |
Memory / Storage | DDR3L 256MB / NOR Flash 4MB + NAND Flash 128MB |
Protocol | IEEE 802.11a/b/g/n/ac |
Wi-Fi Speed | 400Mbps (2.4GHz), 867Mbps (5GHz) |
Ethernet Speed | 10/100/1000Mbps |
Antennas | 2 x undetachable external Wi-Fi antennas |
Power Input | Type-C, 5V/3A |
Power Consumption | <6.5W |
Operating Temperature | 0 ~ 40°C (32 ~ 104°F) |
Storage Temperature | -20 ~ 70°C (-4 ~ 158°F) |
Dimension / Weight | 118 x 85 x 30mm / 181g |
Tools & Downloadables | Datasheet | Firmware | App | Unboxing | Tutorials | Media Kit |
